[GRASS-SVN] r56275 - grass-addons/grass7/imagery/i.wavelet
svn_grass at osgeo.org
Thu May 16 02:41:28 PDT 2013
Author: ychemin
Date: 2013-05-16 02:41:27 -0700 (Thu, 16 May 2013)
New Revision: 56275
grass-addons/grass7/imagery/i.wavelet/main.c
brackets for options
Modified: grass-addons/grass7/imagery/i.wavelet/main.c
--- grass-addons/grass7/imagery/i.wavelet/main.c 2013-05-16 06:17:40 UTC (rev 56274)
+++ grass-addons/grass7/imagery/i.wavelet/main.c 2013-05-16 09:41:27 UTC (rev 56275)
@@ -86,26 +86,26 @@
/* Define the different options for decomposition */
input = G_define_standard_option(G_OPT_I_GROUP);
- input->key = "input_group_to_decompose";
+ input->key = _("input_group_to_decompose");
input->required = NO;
- input->guisection = "Decomposition";
+ input->guisection = _("Decomposition");
olp1 = G_define_standard_option(G_OPT_R_OUTPUT);
- olp1->key = "output_lp1_from_decomposition";
+ olp1->key = _("output_lp1_from_decomposition");
olp1->required = NO;
- olp1->guisection = "Decomposition";
+ olp1->guisection = _("Decomposition");
olp2 = G_define_standard_option(G_OPT_R_OUTPUT);
- olp2->key = "output_lp2_from_decomposition";
+ olp2->key = _("output_lp2_from_decomposition");
olp2->required = NO;
- olp2->guisection = "Decomposition";
+ olp2->guisection = _("Decomposition");
ohp1 = G_define_standard_option(G_OPT_R_OUTPUT);
- ohp1->key = "output_hp1_from_decomposition";
+ ohp1->key = _("output_hp1_from_decomposition");
ohp1->required = NO;
- ohp1->guisection = "Decomposition";
+ ohp1->guisection = _("Decomposition");
ohp2 = G_define_standard_option(G_OPT_R_OUTPUT);
- ohp2->key = "output_hp2_from_decomposition";
+ ohp2->key = _("output_hp2_from_decomposition");
ohp2->required = NO;
- ohp2->guisection = "Decomposition";
+ ohp2->guisection = _("Decomposition");
/* Define the different options for recomposition */
ilp2 = G_define_standard_option(G_OPT_I_GROUP);
@@ -150,18 +150,19 @@
resolution->multiple = NO;
resolution->description = _("4,6,8,10,12,14,16,18,20");
resolution->required = NO;
- resolution->guisection = _("Optional");
+ resolution->guisection = _("Wavelets");
nfiles = 1;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- res=atoi(resolution->answer);
+ res = atoi(resolution->answer);
if((flag3->answer) && (res==4||res==6||res==8||res==10||res==12
||res==14||res==16||res==18||res==20)){
/** Good to go with Flag3 => Daubechies **/
- }else{ G_fatal_error(_("To use Daubechies, you need a valid resolution"));}
+ }else{
+ G_fatal_error(_("To use Daubechies, you need a valid resolution"));
nrows = Rast_window_rows();
ncols = Rast_window_cols();
