[GRASS-SVN] r56279 - grass/trunk/vector/v.generalize
Thu May 16 08:47:52 PDT 2013
Author: mmetz
Date: 2013-05-16 08:47:52 -0700 (Thu, 16 May 2013)
New Revision: 56279
   grass/trunk/vector/v.generalize/smoothing.c
v.generalize: fix chaiken loop support
Modified: grass/trunk/vector/v.generalize/smoothing.c
--- grass/trunk/vector/v.generalize/smoothing.c	2013-05-16 10:26:22 UTC (rev 56278)
+++ grass/trunk/vector/v.generalize/smoothing.c	2013-05-16 15:47:52 UTC (rev 56279)
@@ -318,81 +318,64 @@
     head.next = NULL;
     cur = &head;
-    point_assign(Points, 0, with_z, &p0, 0);
     if (!is_loop) {
-	point_list_add(cur, p0); /* always keep first point */
-	cur = cur->next;
+	/* always keep first point */
+	point_assign(Points, 0, with_z, &p0, 0);
+    else {
+	point_assign(Points, 0, with_z, &p1, 0);
+	point_assign(Points, 1, with_z, &p2, 0);
+	point_add(p1, p2, &tmp);
+	point_scalar(tmp, 0.5, &p0);
-	for (i = 2; i <= n; i++) {
+    point_list_add(cur, p0);
+    cur = cur->next;
+    for (i = 2; i <= n; i++) {
+	if (!is_loop) {
 	    if (i == n)
 		point_assign(Points, i - 1, with_z, &p2, 0);
 	    else
 		point_assign(Points, i, with_z, &p2, 0);
-	    point_assign(Points, i - 1, with_z, &p1, 0);
+	else
+	    point_assign(Points, i, with_z, &p2, 1);
+	point_assign(Points, i - 1, with_z, &p1, 0);
-	    while (1) {
-		point_add(p1, p2, &tmp);
-		point_scalar(tmp, 0.5, &m1);
+	while (1) {
+	    point_scalar(tmp, 0.5, &m1);
-		point_list_add(cur, m1);
+	    point_list_add(cur, m1);
-		if (point_dist_square(p0, m1) > thresh) {
-		    point_add(p1, m1, &tmp);	/* need to refine the partition */
-		    point_scalar(tmp, 0.5, &p2);
-		    point_add(p1, p0, &tmp);
-		    point_scalar(tmp, 0.5, &p1);
-		else {
-		    break;		/* good approximation */
+	    if (point_dist_square(p0, m1) > thresh) {
+		point_add(p1, m1, &tmp);	/* need to refine the partition */
+		point_scalar(tmp, 0.5, &p2);
+		point_add(p1, p0, &tmp);
+		point_scalar(tmp, 0.5, &p1);
+	    else {
+		break;		/* good approximation */
-	    while (cur->next != NULL)
-		cur = cur->next;
+	while (cur->next != NULL)
+	    cur = cur->next;
-	    p0 = cur->p;
+	p0 = cur->p;
+    if (!is_loop) {
 	point_assign(Points, n - 1, with_z, &p0, 0);
 	point_list_add(cur, p0); /* always keep last point */
-    else {
-	    if (i == n)
-		point_assign(Points, 1, with_z, &p2, 0);
-	    else
-		point_assign(Points, i, with_z, &p2, 0);
-	    while (1) {
-		else {
-		cur = cur->next;
-	    p0 = cur->p;
     if (point_list_copy_to_line_pnts(head, Points) == -1) {
 	G_fatal_error(_("Out of memory"));
     point_list_free(head);
     return Points->n_points;
