[GRASS-SVN] r56283 - grass-addons/grass7/raster/r.mess
svn_grass at osgeo.org
Fri May 17 05:01:10 PDT 2013
Author: pvanbosgeo
Date: 2013-05-17 05:01:10 -0700 (Fri, 17 May 2013)
New Revision: 56283
grass-addons/grass7/raster/r.mess/r.mess
Added uption to calculate areas with negative mess values + bugfix
Modified: grass-addons/grass7/raster/r.mess/r.mess
--- grass-addons/grass7/raster/r.mess/r.mess 2013-05-17 12:00:50 UTC (rev 56282)
+++ grass-addons/grass7/raster/r.mess/r.mess 2013-05-17 12:01:10 UTC (rev 56283)
@@ -107,9 +107,23 @@
#% description: Calculate median of IES layers
#%end
+#%flag
+#% key: n
+#% description: Area with negative MESS
+#%end
+#%option
+#% key: liblocs
+#% type: string
+#% description: Location R libraries
+#% key_desc: folder
+#% required: no
+#%end
## Set easier variable names
OUTMAPS="${GIS_OPT_OUTPUT}"
-INMAPS="${GIS_OPT_ENV_VAR}"
+export INMAPS="${GIS_OPT_ENV_VAR}"
## GRASS team recommandations
@@ -186,10 +200,10 @@
counter=0
IFS=,
for nvar in ${INMAPS} ; do
- arrOUT="$arrOUT;${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
+ export arrOUT="$arrOUT;${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
counter=`expr $counter + 1`
- tmpLY="${tmpLY};tmp_mess_$$_$counter"
- arrIN="${arrIN};`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
+ export tmpLY="${tmpLY};tmp_mess_$$_$counter"
+ export arrIN="${arrIN};`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
done
if [ -z "$GIS_OPT_REF_VECT" -a -z "$GIS_OPT_REF_RAST" ];
@@ -199,15 +213,15 @@
else
if [ -n "$GIS_OPT_REF_VECT" -a -n "$GIS_OPT_REF_RAST" ]; then
g.message message='You gave a vector and raster layer as reference distribution layer. !Using the raster layer!'
- REF_LAY="${GIS_OPT_REF_RAST}"
- REF_TYPE="R"
+ export REF_LAY="${GIS_OPT_REF_RAST}"
+ export REF_TYPE="R"
else
if [ -n "$GIS_OPT_REF_RAST" ]; then
- REF_TYPE="R"
else
- REF_LAY="${GIS_OPT_REF_VECT}"
- REF_TYPE="V"
+ export REF_LAY="${GIS_OPT_REF_VECT}"
+ export REF_TYPE="V"
fi
fi
fi
@@ -262,36 +276,62 @@
options(echo = TRUE)
# Install (if not present) and load required packages
tmp.pack <- tempdir()
-if (!"spgrass6" %in% installed.packages()){
- install.packages("spgrass6", dep=TRUE, repos='http://star-www.st-andrews.ac.uk/cran/', tmp.pack)
- require(spgrass6, lib.loc=tmp.pack)
-}else{require(spgrass6)}
+libLocs <- Sys.getenv("GIS_OPT_LIBLOCS") # Location R packages
+if(libLocs!=""){
+ libLocs <- c(.libPaths(), libLocs, tmp.pack)
+}else{
+ libLocs <- c(.libPaths(), tmp.pack)
+if (!"XML" %in% installed.packages(lib.loc=libLocs)){
+ install.packages("XML", dep=TRUE, repos='http://cran.us.r-project.org', tmp.pack)
+ require(XML, lib.loc=libLocs)
+}else{require(XML, lib.loc=libLocs)}
+if (!"sp" %in% installed.packages(lib.loc=libLocs)){
+ install.packages("sp", dep=TRUE, repos='http://cran.us.r-project.org', tmp.pack)
+ require(sp, lib.loc=libLocs)
+}else{require(sp, lib.loc=libLocs)}
+if (!"spgrass6" %in% installed.packages(lib.loc=libLocs)){
+ install.packages("spgrass6", dep=TRUE, repos='http://cran.us.r-project.org', tmp.pack)
+ require(spgrass6, lib.loc=libLocs)
+}else{require(spgrass6, lib.loc=libLocs)}
# Check grass version
grassversion <- as.numeric(system("g.version | cut -c7", intern=T))
## Get vector with variables
-argus <- commandArgs(trailingOnly=TRUE)
-ipn <- unlist(strsplit(argus[1],";"))[-1] # variable names
-ipl <- unlist(strsplit(argus[2],",")) # environmental layers
-opl <- unlist(strsplit(argus[3],";")) # output layers
-opi <- opl[-1] # base name individual layers
-opc <- opl[1] # name of MESS layer
-tml <- unlist(strsplit(argus[4], ";"))[-1] # temporary layers
-vtl <- argus[5] # reference distribution raster layer
-rtl <- argus[10] # raster or vector layer
-digits <- as.numeric(argus[9]) # Precision
+ipn <- Sys.getenv("arrIN") # variable names
+ipn <- unlist(strsplit(ipn,";"))[-1]
+ipl <- Sys.getenv("INMAPS") # environmental layers
+ipl <- unlist(strsplit(ipl,","))
+opl <- Sys.getenv("arrOUT") # output layers
+opl <- unlist(strsplit(opl,";"))
+opi <- opl[-1] # base name individual layers
+opc <- opl[1] # name of MESS layer
+tml <- Sys.getenv("tmpLY") # temporary layers
+tml <- unlist(strsplit(tml,";"))[-1]
+vtl <- Sys.getenv("REF_LAY") # reference distribution raster layer
+rtl <- Sys.getenv("REF_TYPE") # raster or vector layer
+flm <- Sys.getenv("GIS_FLAG_M")
+flk <- Sys.getenv("GIS_FLAG_K")
+fll <- Sys.getenv("GIS_FLAG_L")
+fln <- Sys.getenv("GIS_FLAG_N")
+digits <- as.numeric(Sys.getenv("GIS_OPT_DIGITS")) # Precision
rdigits <- nchar((1/digits)-1)
options(echo=TRUE, digits=rdigits+1, scipen=rdigits+1)
# Create the r.mapcalc expressions to calculate the mess for the
# individual layers. The main step is to define the graph function to
# be used -
-if(rtl=="R"){
+if(rtl=="R"){
# Reference distribution layer is raster
@@ -307,8 +347,8 @@
# One option is to convert the floating layers to integer layers after
# multiplying first with a number equal to the reciprocal of the value
# given under the digits option. This may deal better with rounding errors too.
- fft <- system("g.findfile --quiet element=cell file=MASK", ignore.stdout = TRUE)
+ fft <- system("g.findfile --quiet element=cell file=MASK", ignore.stdout = TRUE)
if(fft==0){
rname <- paste("MASK",paste(sample(c(0:9, letters, LETTERS), 12, replace=TRUE), collapse=""), sep="_")
execGRASS("g.copy", rast=paste("MASK", rname, sep=","))
@@ -321,24 +361,31 @@
}else{
execGRASS("r.mask", input=vtl)
execGRASS("r.out.xyz", input=ipl[i], output=flnm1, flags="overwrite")
system(paste("awk -F \"|\" '{print $3}' ", flnm1, " > ", flnm2, sep=""))
spld <- scan(file=flnm2)
- #unlink(c(flnm1, flnm2))
+ unlink(c(flnm1, flnm2))
spld <- round(spld, rdigits)
+ # Make sure numbers < 2^31 (need better solution!!)
+ envmin <- min(spld)
+ envmax <- max(spld)
+ ch <- max(abs(envmin), abs(envmax))
+ a <- (2^31/10) - ch/digits
+ b <- nchar(floor(2^31/(ch*10)))
+ rdigits2 <- ifelse(a<=0, b ,rdigits)
+ digits2 <- 10^(-rdigits2)
# Calculate the frequency distribution
a <- table(spld)
- envmin <- min(spld)
- envmax <- max(spld)
Drange <- execGRASS("r.info", flags=c("r", "verbose"), map=ipl[i], intern=T)
Dmin <- as.numeric(sub("min=", "", Drange[1]))
Dmax <- as.numeric(sub("max=", "", Drange[2]))
system("g.remove -f rast=MASK")
# Create recode rules
- x1 <- c(Dmin, as.numeric(rownames(a))+digits)
+ x1 <- c(Dmin, as.numeric(rownames(a)))#+digits)
x2 <- c(envmin, as.numeric(rownames(a))[-1],Dmax)
y1 <- c(0,cumsum(as.numeric(a))/sum(a)*100)
xy1 <- format(cbind(x1,x2,y1), scientific=F, trim=T, nsmall=rdigits)
@@ -353,7 +400,7 @@
# Create the recode layer and calculate the IES
execGRASS("r.recode", input=ipl[i], output=tml[i], rules=tmp.rule)
- calcc <- paste(opi[i], " = if(", tml[i], "==0, (round(", ipl[i], "/",digits,")-", round(envmin/digits), ")/(", round(envmax/digits), "-", round(envmin/digits), ") *100.0, if(", tml[i], "<=50, 2 * ", tml[i], ", if(", tml[i], "<100.0, 2 * (100.0- ", tml[i], "), (", round(envmax/digits), "- round(", ipl[i], "/", digits, "))/(", round(envmax/digits), "-", round(envmin/digits), ") * 100.0)))", sep="")
+ calcc <- paste(opi[i], " = if(", tml[i], "==0, (round(", ipl[i], "/",digits2,")*1.0-", round(envmin/digits2), ")/(", round(envmax/digits2)*1.0, "-", round(envmin/digits2)*1.0, ") *100.0, if(", tml[i], "<=50, 2.0 * ", tml[i], ", if(", tml[i], "<100, 2.0 * (100.0- ", tml[i], "), (", round(envmax/digits2)*1.0, "- round(", ipl[i], "/", digits2, ")*1.0)/(", round(envmax/digits2)*1.0, "-", round(envmin/digits2)*1.0, ") * 100.0)))", sep="")
execGRASS("r.mapcalc", expression=calcc, flags="overwrite")
execGRASS("g.remove", rast=tml[i])
unlink(tmp.rule)
@@ -364,7 +411,7 @@
# Reference distribution layer is vector
- execGRASS("v.extract", flags="t", input=vtl, type=point, output=tmpMESS976543210)
+ execGRASS("v.extract", flags="t", input=vtl, type="point", output=tmpMESS976543210)
system(paste("v.db.addtable tmpMESS976543210 columns='", paste(ipn, " double precision", collapse=","), "'", sep=""))
# make compatible for both v6.4 and 7
@@ -401,7 +448,7 @@
@@ -409,9 +456,16 @@
tmp.rule <- tempfile(pattern = "file", tmpdir = tempdir(), fileext = ".rules")
write.table(xy2, file=tmp.rule, quote=F, row.names=F, col.names=F)
unlink(tmp.rule)
@@ -428,7 +482,11 @@
# Calculate other stats
-if(argus[6]==1){
+if(fln==1){
+ execGRASS("r.mapcalc", expression=paste(opc, "_neg = if(", opc, "<0,1)", sep=""))
+if(flm==1){
system(paste("r.series output=", opc, "_MoD input=", paste(opi, collapse=","), " method=min_raster", sep=""))
nuvto <- length(ipn)-1
nuv <- cbind(seq(from=0, to=nuvto, by=1), ipn)
@@ -442,13 +500,12 @@
system(paste("r.category map=", opc, "_MoD rules=", tmpclas, sep=""))
unlink(tmpclas)
-if(argus[7]==1){
+if(flk==1){
system(paste("r.series output=", opc, "_mean input=", paste(opi, collapse=","), " method=average", sep=""))
-if(argus[8]==1){
+if(fll==1){
system(paste("r.series output=", opc, "_median input=", paste(opi, collapse=","), " method=median", sep=""))
EOF
@@ -470,8 +527,8 @@
g.message message='Calculating MESS layers.. this may take some time'
##using R to create MESS layers
-#--slave
-R --vanilla --args "$arrIN" "${INMAPS}" "$arrOUT" "$tmpLY" "${REF_LAY}" "$GIS_FLAG_M" "$GIS_FLAG_K" "$GIS_FLAG_L" "${GIS_OPT_DIGITS}" "${REF_TYPE}" < "$RGRASSSCRIPT" >> "$LOGFILE" 2>&1
+# R --no-save --no-restore --no-site-file --no-init-file --args "$arrIN" "${INMAPS}" "$arrOUT" "$tmpLY" "$REF_LAY" "$GIS_FLAG_M" "$GIS_FLAG_K" "$GIS_FLAG_L" "$GIS_OPT_DIGITS" "$REF_TYPE"
+R --no-save --no-restore < "$RGRASSSCRIPT" >> "$LOGFILE" 2>&1
if [ $? -ne 0 ] ; then
echo "ERROR: an error occurred during R script execution" 1>&2
exit 1
@@ -481,3 +538,4 @@
