[GRASS-SVN] r56288 - grass/trunk/misc/m.nviz.image
Sat May 18 01:27:47 PDT 2013
Author: martinl
Date: 2013-05-18 01:27:47 -0700 (Sat, 18 May 2013)
New Revision: 56288
   grass/trunk/misc/m.nviz.image/vector.c
m.nviz.image/vector: add error handlers to close vector map and db driver
Modified: grass/trunk/misc/m.nviz.image/vector.c
--- grass/trunk/misc/m.nviz.image/vector.c	2013-05-17 23:07:10 UTC (rev 56287)
+++ grass/trunk/misc/m.nviz.image/vector.c	2013-05-18 08:27:47 UTC (rev 56288)
@@ -23,6 +23,8 @@
 static int load_vectors(const struct Option *, const struct Option *,
 			const struct Option *, const struct Option *, int, nv_data *);
+static void error_handler_vector(void *);
+static void error_handler_db(void *);
   \brief Load vector maps (lines)
@@ -244,6 +246,8 @@
     for (i = 0; map->answers[i]; i++) {
 	if (1 > Vect_open_old(&Map, map->answers[i], ""))
 	    G_fatal_error(_("Unable to open vector map <%s>"), map->answers[i]);
+        G_add_error_handler(error_handler_vector, &Map);
 	Fi = Vect_get_field2(&Map, layer->answers[i]);
 	if (!Fi)
 	    continue;
@@ -251,7 +255,8 @@
 	if (!driver)
 	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  Fi->database, Fi->driver);
+	G_add_error_handler(error_handler_db, driver);
 	if (color->answers && color->answers[i]) {
 	    db_get_column(driver, Fi->table, color->answers[i], &column);
 	    if (!column)
@@ -292,9 +297,31 @@
 		G_fatal_error(_("Data type of marker column must be character"));
+    G_remove_error_handler(error_handler_vector, &Map);
+    G_remove_error_handler(error_handler_db, driver);
+    db_close_database_shutdown_driver(driver);
     if (Fi)
 	return Fi->number;
     return 1;
+void error_handler_vector(void *p)
+    struct Map_info *Map;
+    Map = (struct Map_info *)p;
+    Vect_close(Map);
+void error_handler_db(void *p)
+    dbDriver *driver;
+    driver = (dbDriver *)p;
