[GRASS-SVN] r56307 - in grass-addons/grass7/raster/r.agent: . libagent tests
Sun May 19 02:18:13 PDT 2013
Author: mic
Date: 2013-05-19 02:18:13 -0700 (Sun, 19 May 2013)
New Revision: 56307
   grass-addons/grass7/raster/r.agent/libagent/agent.py
   grass-addons/grass7/raster/r.agent/libagent/ant.py
   grass-addons/grass7/raster/r.agent/libagent/anthill.py
   grass-addons/grass7/raster/r.agent/libagent/grassland.py
   grass-addons/grass7/raster/r.agent/r.agent.aco
   grass-addons/grass7/raster/r.agent/tests/test_agent.py
ants start walking, first time output is produced
Modified: grass-addons/grass7/raster/r.agent/libagent/agent.py
--- grass-addons/grass7/raster/r.agent/libagent/agent.py	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/libagent/agent.py	2013-05-19 09:18:13 UTC (rev 56307)
@@ -8,6 +8,8 @@
               License (>=v2). Read the file COPYING that comes with GRASS
               for details.
+#from random import choice, randint
+from random import randint
 class Agent(object):
@@ -44,6 +46,14 @@
 #TODO not very meaningfull yet..
         return self.position
+    def randomposition(self, positions):
+        Pick a random position out of a list of positions
+        @param positions list of possible positions
+        @return position the decision for a position
+        return positions[randint(0, len(positions)-1)]
 #    def move(self, nrofsteps, direction):
 # not implemented yet
Modified: grass-addons/grass7/raster/r.agent/libagent/ant.py
--- grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-19 09:18:13 UTC (rev 56307)
@@ -9,7 +9,7 @@
               for details.
-from random import choice, randint
+from random import choice #, randint
 import agent
 import error
@@ -32,6 +32,11 @@
         self.nextstep = [None,None,0,0,0,0]
         self.goal = []
         self.penalty = 0.0
+        if self.world.decisionbase == "default":
+            # TODO: for now like 'else'..
+            self.chooseposition = self.randomposition
+        else:
     def work(self):
@@ -42,4 +47,7 @@
         # we are all only getting older..
         if self.age() == False:
             return False
+        self.position = self.chooseposition(
+                self.world.getneighbourpositions(self.position))
+        self.world.setsteppheromone(self.position)
Modified: grass-addons/grass7/raster/r.agent/libagent/anthill.py
--- grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-19 09:18:13 UTC (rev 56307)
@@ -71,7 +71,7 @@
         self.maxants = 100
         ## the ants ttl will be set by user or based on playground size
         self.antslife = 0
-#TODO        self.decisionbase = "default"
+        self.decisionbase = "default"
 #TODO        self.rememberbase = "default"
     def bear(self):
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-19 09:18:13 UTC (rev 56307)
@@ -108,10 +108,13 @@
                 # TODO do they all look like this??
                 if len(v) == 4 and v[0] == v[3]:
                     p = self.stringcoordinate(v[1],v[2])
+                    # TODO - as with grass numpy array it seems that
+                    # [0,0] is north-most west-most..
                     p[0] = int(round(
-                        ( p[0] - self.region["s"] ) / self.region["nsres"] ))
+                        ( self.region["n"] - p[0] ) / self.region["nsres"] ))
                     p[1] = int(round(
                         ( p[1] - self.region["w"] ) / self.region["ewres"] ))
+                    grass.info(str(p[0]) + " " + str(p[1]))
                     vectors.append(p)
                     self.layers[layername][p[0]][p[1]] = value
         return vectors
Modified: grass-addons/grass7/raster/r.agent/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-19 09:18:13 UTC (rev 56307)
@@ -277,8 +277,8 @@
         # loop and write out the contents at the end
         world.letantsdance(nextwrite)
         # export the value maps
-        world.playground.writelayer(anthill.Anthill.RESULT,
-                                        world.overwritepheormone)
+        world.playground.writelayer(anthill.Anthill.RESULT, False,
+                                            world.overwritepheormone)
 #        print "nrofpaths:", world.nrop
         # count down outer
         mainloops -= 1
Modified: grass-addons/grass7/raster/r.agent/tests/test_agent.py
--- grass-addons/grass7/raster/r.agent/tests/test_agent.py	2013-05-19 08:42:37 UTC (rev 56306)
+++ grass-addons/grass7/raster/r.agent/tests/test_agent.py	2013-05-19 09:18:13 UTC (rev 56307)
@@ -20,6 +20,11 @@
     def test_getposition(self):
         self.assertTrue(self.agent.getposition() == [1,1])
+    def test_randomposition(self):
+        position = [1,2]
+        self.assertEqual(position,
+                    self.agent.randomposition([position, position]))
 #    def test_move(self):
 #        pass
