[GRASS-SVN] r56336 - grass-addons/grass7/raster/r.agent/libagent
Mon May 20 12:42:52 PDT 2013
Author: mic
Date: 2013-05-20 12:42:51 -0700 (Mon, 20 May 2013)
New Revision: 56336
   grass-addons/grass7/raster/r.agent/libagent/grassland.py
fix write out and numpy passing
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-20 17:09:03 UTC (rev 56335)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-05-20 19:42:51 UTC (rev 56336)
@@ -76,7 +76,7 @@
         if not grassmapname:
             if self.grassmapnames.has_key(layername):
-                grassmapname=layername
+                grassmapname=self.grassmapnames[layername]
             else:
                 raise error.DataError(Grassland.ME,
                                         "Grass Map name is empty.")
@@ -89,6 +89,8 @@
                                         "Grass map already exists.")
             self.layers[layername].write(grassmapname, overwrite=force)
+        else:
+            raise error.DataError(Grassland.ME, "Layer is not in list.")
     def parsevectorlayer(self, layername, grassmapname, value=1, force=False):
@@ -127,13 +129,11 @@
         @param long halflife or number of years when to reach half of the value
         @param long minimum value to keep on cell
-        layer = self.layers[layername]
         if halflife > 0:
-            layer = layer*0.5**(1.0/halflife)
+            self.layers[layername] = self.layers[layername]*0.5**(1.0/halflife)
             #TODO find out why 'filename' is lost - numpy vs. garray..
-            #self.layers[layername] = layer
         #TODO think about moving 'minimum' to a predifined matrix in anthill
         if minimum > 0:
-            mask = garray.numpy.ones_like(layer) + minimum
-            garray.numpy.maximum(layer, mask)
+            mask = garray.numpy.ones_like(self.layers[layername]) + minimum
+            garray.numpy.maximum(self.layers[layername], mask)
