[GRASS-SVN] r56358 - grass/trunk/gui/wxpython/core
Wed May 22 08:29:25 PDT 2013
Author: annakrat
Date: 2013-05-22 08:29:25 -0700 (Wed, 22 May 2013)
New Revision: 56358
   grass/trunk/gui/wxpython/core/toolboxes.py
wxGUI/toolboxes: fix case when grass7 directory in home is missing
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py	2013-05-21 21:52:12 UTC (rev 56357)
+++ grass/trunk/gui/wxpython/core/toolboxes.py	2013-05-22 15:29:25 UTC (rev 56358)
@@ -39,6 +39,7 @@
 from core.gcmd import GError
 import grass.script.task as gtask
+import grass.script.core as gcore
 from grass.script.core import ScriptError
@@ -122,14 +123,28 @@
 def _setupToolboxes():
     """!Create 'toolboxes' directory if doesn't exist."""
-    path = os.path.join(GetSettingsPath(), 'toolboxes')
+    basePath = GetSettingsPath()
+    path = os.path.join(basePath, 'toolboxes')
+    if not os.path.exists(basePath):
+        return None
+    if _createPath(path):
+           return path
+    return None
+def _createPath(path):
+    """!Creates path (for toolboxes) if it doesn't exist'"""
     if not os.path.exists(path):
         try:
             os.mkdir(path)
-        except:
-            GError(_('Unable to create toolboxes directory.'))
-            return None
-    return path
+        except OSError, e:
+            # we cannot use GError or similar because the gui doesn''t start at all
+            gcore.warning('%(reason)s\n%(detail)s' %
+                    ({'reason':_('Unable to create toolboxes directory.'),
+                      'detail': str(e)}))
+            return False
+    return True
 def toolboxes2menudata(userDefined=True):
