[GRASS-SVN] r56366 - grass/trunk/raster/r.cost
svn_grass at osgeo.org
Wed May 22 12:49:48 PDT 2013
Author: mmetz
Date: 2013-05-22 12:49:48 -0700 (Wed, 22 May 2013)
New Revision: 56366
grass/trunk/raster/r.cost/main.c
r.cost: cumulative costs must be DCELL
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2013-05-22 19:44:31 UTC (rev 56365)
+++ grass/trunk/raster/r.cost/main.c 2013-05-22 19:49:48 UTC (rev 56366)
@@ -125,7 +125,10 @@
} costs;
void *ptr2;
- RASTER_MAP_TYPE data_type, dir_data_type = FCELL_TYPE, nearest_data_type = CELL_TYPE;
+ RASTER_MAP_TYPE data_type, /* input cost type */
+ cum_data_type = DCELL_TYPE, /* output cumulative cost type */
+ dir_data_type = FCELL_TYPE, /* output direction type */
+ nearest_data_type = CELL_TYPE; /* output nearest type */
struct History history;
double peak = 0.0;
int dsize, nearest_size;
@@ -253,7 +256,7 @@
dir = 1;
/* Get database window parameters */
- G_get_window(&window);
+ Rast_get_window(&window);
/* Find north-south, east_west and diagonal factors */
EW_fac = 1.0;
@@ -1022,8 +1025,8 @@
free_heap();
/* Open cumulative cost layer for writing */
- cum_fd = Rast_open_new(cum_cost_layer, data_type);
- cell = Rast_allocate_buf(data_type);
+ cum_fd = Rast_open_new(cum_cost_layer, cum_data_type);
+ cell = Rast_allocate_buf(cum_data_type);
/* Open nearest start point layer */
if (nearest_layer) {
@@ -1047,6 +1050,7 @@
void *p;
void *p2;
void *p3;
+ int cum_dsize = Rast_cell_size(cum_data_type);
Rast_set_null_value(cell2, ncols, data_type);
@@ -1061,8 +1065,8 @@
for (col = 0; col < ncols; col++) {
if (keep_nulls) {
if (Rast_is_null_value(p2, data_type)) {
- Rast_set_null_value(p, 1, data_type);
- p = G_incr_void_ptr(p, dsize);
+ Rast_set_null_value(p, 1, cum_data_type);
+ p = G_incr_void_ptr(p, cum_dsize);
p2 = G_incr_void_ptr(p2, dsize);
Rast_set_null_value(p3, 1, nearest_data_type);
@@ -1076,7 +1080,7 @@
min_cost = costs.cost_out;
nearest = costs.nearest;
if (Rast_is_d_null_value(&min_cost)) {
if (nearest_layer)
@@ -1084,7 +1088,7 @@
if (min_cost > peak)
peak = min_cost;
- switch (data_type) {
+ switch (cum_data_type) {
case CELL_TYPE:
*(CELL *)p = (CELL)(min_cost + .5);
break;
@@ -1110,12 +1114,12 @@
if (nearest_layer)
p3 = G_incr_void_ptr(p3, nearest_size);
- Rast_put_row(cum_fd, cell, data_type);
+ Rast_put_row(cum_fd, cell, cum_data_type);
if (nearest_layer)
Rast_put_row(nearest_fd, nearest_cell, nearest_data_type);
