[GRASS-SVN] r56379 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu May 23 07:42:42 PDT 2013
Author: martinl
Date: 2013-05-23 07:42:41 -0700 (Thu, 23 May 2013)
New Revision: 56379
grass/trunk/lib/vector/Vlib/copy.c
vlib: report number of skipped area when copying vector features (as simple features)
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2013-05-23 14:34:45 UTC (rev 56378)
+++ grass/trunk/lib/vector/Vlib/copy.c 2013-05-23 14:42:41 UTC (rev 56379)
@@ -295,7 +295,7 @@
if (nskipped > 0)
- G_warning(_("%d features without category or from different layer skipped"), nskipped);
+ G_important_message(_("%d features without category or from different layer skipped"), nskipped);
Vect_destroy_line_struct(Points);
Vect_destroy_line_struct(CPoints);
@@ -407,7 +407,7 @@
int copy_areas(const struct Map_info *In, int field, struct Map_info *Out)
- int i, area, nareas, cat, isle, nisles, nparts_alloc;
+ int i, area, nareas, cat, isle, nisles, nparts_alloc, nskipped;
struct line_pnts **Points;
struct line_cats *Cats;
@@ -418,6 +418,7 @@
Cats = Vect_new_cats_struct();
/* copy areas */
+ nskipped = 0;
nareas = Vect_get_num_areas(In);
G_message(_("Exporting areas..."));
for (area = 1; area <= nareas; area++) {
@@ -428,8 +429,10 @@
Vect_reset_cats(Cats);
if (field > 0) {
cat = Vect_get_area_cat(In, area, field);
- if (cat == -1)
+ if (cat == -1) {
+ nskipped++;
continue; /* skip area without category in given layer */
Vect_cat_set(Cats, field, cat);
@@ -473,6 +476,9 @@
return -1;
+ if (nskipped > 0)
+ G_important_message(_("%d areas without category or from different layer skipped"), nskipped);
/* free allocated space for isles */
for (i = 0; i < nparts_alloc; i++)
