[GRASS-SVN] r56381 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu May 23 08:21:33 PDT 2013
Author: martinl
Date: 2013-05-23 08:21:33 -0700 (Thu, 23 May 2013)
New Revision: 56381
grass/trunk/lib/vector/Vlib/write_pg.c
vlib: write_line_sf() - clarify message (skipping features)
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2013-05-23 15:16:24 UTC (rev 56380)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2013-05-23 15:21:33 UTC (rev 56381)
@@ -561,7 +561,6 @@
dbString dbtable_name;
dbHandle handle;
dbDriver *driver;
- dbCursor cursor;
dbTable *table;
dbColumn *column;
@@ -1057,26 +1056,31 @@
/* determine matching PostGIS feature geometry type */
if (type & (GV_POINT | GV_KERNEL)) {
if (sf_type != SF_POINT && sf_type != SF_POINT25D) {
- G_warning(_("Feature is not a point. Skipping."));
- return -1;
+ G_warning(_("Point skipped (output feature type: %s)"),
+ Vect_get_finfo_geometry_type(Map));
+ return 0;
else if (type & GV_LINE) {
if (sf_type != SF_LINESTRING && sf_type != SF_LINESTRING25D) {
- G_warning(_("Feature is not a line. Skipping."));
- return -1;
+ G_warning(_("Line skipped (output feature type: %s)"),
+ return 0;
else if (type & GV_BOUNDARY || type & GV_CENTROID) {
if (sf_type != SF_POLYGON) {
+ G_warning(_("Boundary/centroid skipped (output feature type: %s)"),
G_warning(_("Feature is not a polygon. Skipping."));
- return -1;
+ return 0;
else if (type & GV_FACE) {
if (sf_type != SF_POLYGON25D) {
- G_warning(_("Feature is not a face. Skipping."));
- return -1;
+ G_warning(_("Face skipped (output feature type: %s)"),
+ return 0;
else {
