[GRASS-SVN] r56387 - grass/branches/releasebranch_6_4/vector/v.net.path
svn_grass at osgeo.org
Thu May 23 09:32:08 PDT 2013
Author: neteler
Date: 2013-05-23 09:32:08 -0700 (Thu, 23 May 2013)
New Revision: 56387
grass/branches/releasebranch_6_4/vector/v.net.path/description.html
v.net.path: explain that nodes can be inserted interactively; HTML cosmetics
Modified: grass/branches/releasebranch_6_4/vector/v.net.path/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.path/description.html 2013-05-23 16:31:19 UTC (rev 56386)
+++ grass/branches/releasebranch_6_4/vector/v.net.path/description.html 2013-05-23 16:32:08 UTC (rev 56387)
@@ -22,13 +22,19 @@
<p>
Least cost paths are written to the output vector map with an
attached attribute table.
-<p>
-Nodes can be piped into the program from file or from stdin. The
-syntax is as follows:
+<p>Nodes can be
+<ul>
+<li> piped into the program from file or from stdin, or
+<li> defined in the graphical user interface ("enter values interactively").
+</ul>
+The syntax is as follows:
<div class="code"><pre>
id start_point_category end_point_category
</pre></div>
+(Example: 1 1 2)
+<p>
or
@@ -45,17 +51,17 @@
<p>
The attribute table will contain the following attributes:
-</ul>
+<ul>
<li>cat - path unique category assigned by module</li>
<li>id - path id (read from input)</li>
<li>fcat - from point category</li>
<li>tcat - to point category</li>
<li>sp - result status:
- </ul>
+ <ul>
<li> 0 - OK, path found</li>
<li> 1 - node is not reachable</li>
<li> 2 - point of given category does not exist</li>
- </ul></li>
+ </ul>
<li>cost - travelling costs (on the network, not to/from network)</li>
<li>fdist - the distance from first point to the network</li>
<li>tdist - the distance from the network to second point</li>
@@ -72,9 +78,9 @@
accurate results, the line length must be taken into account when
assigning costs as attributes. For example, to get the <b>fastest path</b>,
the columns 'max_speed' and 'length' are required. The correct fastest
-path can then be found by specifying <tt>afcol=length/max_speed</tt>. If needed,
-the line length can be calculated and written to the attributes table
-by <em>v.to.db</em>.
+path can then be found by specifying <tt>afcol=length/max_speed</tt>. If not yet
+existing, the column containing the line length ("length") has to added to the
+attributes table using <em>v.to.db</em>.
<h2>EXAMPLE</h2>
