[GRASS-SVN] r56398 - grass/trunk/vector/v.out.postgis
svn_grass at osgeo.org
Fri May 24 05:05:12 PDT 2013
Author: martinl
Date: 2013-05-24 05:05:12 -0700 (Fri, 24 May 2013)
New Revision: 56398
grass/trunk/vector/v.out.postgis/args.c
grass/trunk/vector/v.out.postgis/local_proto.h
grass/trunk/vector/v.out.postgis/main.c
grass/trunk/vector/v.out.postgis/v.out.postgis.html
v.out.postgis: added force2D flag (see v.out.ogr)
Modified: grass/trunk/vector/v.out.postgis/args.c
--- grass/trunk/vector/v.out.postgis/args.c 2013-05-24 11:45:07 UTC (rev 56397)
+++ grass/trunk/vector/v.out.postgis/args.c 2013-05-24 12:05:12 UTC (rev 56398)
@@ -68,5 +68,12 @@
flags->topo->description =
_("Export PostGIS topology instead of simple features");
flags->topo->guisection = _("Output settings");
+ flags->force2d = G_define_flag();
+ flags->force2d->key = '2';
+ flags->force2d->label = _("Force 2D output even if input is 3D ");
+ flags->force2d->description = _("Useful if input is 3D but all z coordinates are identical");
+ flags->force2d->guisection = _("Output settings");
Modified: grass/trunk/vector/v.out.postgis/local_proto.h
--- grass/trunk/vector/v.out.postgis/local_proto.h 2013-05-24 11:45:07 UTC (rev 56397)
+++ grass/trunk/vector/v.out.postgis/local_proto.h 2013-05-24 12:05:12 UTC (rev 56398)
@@ -8,7 +8,7 @@
struct flags {
- struct Flag *table, *topo;
+ struct Flag *table, *topo, *force2d;
/* args.c */
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c 2013-05-24 11:45:07 UTC (rev 56397)
+++ grass/trunk/vector/v.out.postgis/main.c 2013-05-24 12:05:12 UTC (rev 56398)
@@ -129,7 +129,8 @@
/* don't use temporary maps, writes vector features immediately to
the output PostGIS layer */
putenv("GRASS_VECTOR_EXTERNAL_IMMEDIATE=1");
- if (-1 == Vect_open_new(&Out, olayer, Vect_is_3d(&In)))
+ if (-1 == Vect_open_new(&Out, olayer,
+ !flags.force2d->answer ? Vect_is_3d(&In) : WITHOUT_Z))
G_fatal_error(_("Unable to create PostGIS layer <%s>"),
olayer);
G_add_error_handler(output_handler, &Out);
Modified: grass/trunk/vector/v.out.postgis/v.out.postgis.html
--- grass/trunk/vector/v.out.postgis/v.out.postgis.html 2013-05-24 11:45:07 UTC (rev 56397)
+++ grass/trunk/vector/v.out.postgis/v.out.postgis.html 2013-05-24 12:05:12 UTC (rev 56398)
@@ -66,7 +66,10 @@
<em>v.out.postgis</em> currently supports only three basic output
simple feature types: Points, Linestrings and Polygons. Also 3D
features of the same type are supported, eg. 3D points are exported
-as <tt>PointZ</tt> simple feature. Faces are exported as 3D polygons.
+as <tt>PointZ</tt> simple feature. Faces are exported as 3D
+polygons. 3D features are written to the output automatically if input
+vector map is 3D. If <b>-2</b> flag is given then the output is always
+2D (z-coordinate is silently ignored for 3D input vector maps).
<p>
Multigeometries are not currently supported. Features with the same
@@ -231,7 +234,7 @@
<li>Allow mixed features (points, lines)</li>
<li>Support other simple feature types like GeometryCollection and others</li>
<li>Implement missing options
- from <em><a href="v.out.ogr.html">v.out.ogr</a></em>: <b>-a</b>, <b>-s</b>, <b>-c</b>, <b>-2</b>, <b>-p</b>, <b>-n</b></li>
+ from <em><a href="v.out.ogr.html">v.out.ogr</a></em>: <b>-a</b>, <b>-s</b>, <b>-c</b>, <b>-p</b>, <b>-n</b></li>
<li>Add options: <b>cats</b>, <b>where</b></li>
</ul>
