[GRASS-SVN] r56401 - in grass/trunk/vector: v.build v.build.polylines v.edit v.split
svn_grass at osgeo.org
Fri May 24 13:16:32 PDT 2013
Author: neteler
Date: 2013-05-24 13:16:32 -0700 (Fri, 24 May 2013)
New Revision: 56401
grass/trunk/vector/v.build.polylines/v.build.polylines.html
grass/trunk/vector/v.build/v.build.html
grass/trunk/vector/v.edit/v.edit.html
grass/trunk/vector/v.split/v.split.html
manual: cross-references added
Modified: grass/trunk/vector/v.build/v.build.html
--- grass/trunk/vector/v.build/v.build.html 2013-05-24 19:28:08 UTC (rev 56400)
+++ grass/trunk/vector/v.build/v.build.html 2013-05-24 20:16:32 UTC (rev 56401)
@@ -65,16 +65,20 @@
from other mapsets.
<div class="code"><pre>
-v.build map=urbanareas at PERMANENT option=dump
+v.build map=urbanareas option=dump
</pre></div>
<h2>SEE ALSO</h2>
<em>
- <a href="v.build.all.html">v.build.all</a>,
- <a href="v.build.polylines.html">v.build.polylines</a>
+<a href="v.build.all.html">v.build.all</a>,
+<a href="v.build.polylines.html">v.build.polylines</a>,
+<a href="v.edit.html">v.edit</a>,
+<a href="v.split.html">v.split</a>
</em>
+<p>See also <em><a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a></em>.
<h2>AUTHORS</h2>
Dave Gerdes, U.S.Army Construction Engineering Research
Modified: grass/trunk/vector/v.build.polylines/v.build.polylines.html
--- grass/trunk/vector/v.build.polylines/v.build.polylines.html 2013-05-24 19:28:08 UTC (rev 56400)
+++ grass/trunk/vector/v.build.polylines/v.build.polylines.html 2013-05-24 20:16:32 UTC (rev 56401)
@@ -68,10 +68,10 @@
<h2>SEE ALSO</h2>
<em>
- <a href="v.build.html">v.build</a>,
- <a href="v.in.ascii.html">v.in.ascii</a>,
- <a href="v.split.html">v.split</a>,
- <a href="v.edit.html">v.edit</a>
+<a href="v.build.html">v.build</a>,
+<a href="v.in.ascii.html">v.in.ascii</a>,
</em>
<h2>AUTHORS</h2>
Modified: grass/trunk/vector/v.edit/v.edit.html
--- grass/trunk/vector/v.edit/v.edit.html 2013-05-24 19:28:08 UTC (rev 56400)
+++ grass/trunk/vector/v.edit/v.edit.html 2013-05-24 20:16:32 UTC (rev 56401)
@@ -418,11 +418,13 @@
<h2>SEE ALSO</h2>
<em>
- <a href="v.info.html">v.info</a>,
- <a href="v.clean.html">v.clean</a>,
- <a href="v.extrude.html">v.extrude</a>
+<a href="v.info.html">v.info</a>,
+<a href="v.clean.html">v.clean</a>,
+<a href="v.extrude.html">v.extrude</a>,
</em>
Modified: grass/trunk/vector/v.split/v.split.html
--- grass/trunk/vector/v.split/v.split.html 2013-05-24 19:28:08 UTC (rev 56400)
+++ grass/trunk/vector/v.split/v.split.html 2013-05-24 20:16:32 UTC (rev 56401)
@@ -26,6 +26,7 @@
<h2>SEE ALSO</h2>
<em>
<a href="v.segment.html">v.segment</a>
</em>
