[GRASS-SVN] r56404 - grass-addons/grass7/raster/r.agent/tests
svn_grass at osgeo.org
Sat May 25 01:46:01 PDT 2013
Author: mic
Date: 2013-05-25 01:46:00 -0700 (Sat, 25 May 2013)
New Revision: 56404
grass-addons/grass7/raster/r.agent/tests/test_ant.py
add ant tests
Modified: grass-addons/grass7/raster/r.agent/tests/test_ant.py
--- grass-addons/grass7/raster/r.agent/tests/test_ant.py 2013-05-25 08:44:28 UTC (rev 56403)
+++ grass-addons/grass7/raster/r.agent/tests/test_ant.py 2013-05-25 08:46:00 UTC (rev 56404)
@@ -20,20 +20,41 @@
self.pg.layers[anthill.Anthill.SITE][1][1] = 0
self.assertFalse(self.agent.check(positions))
self.assertIsNone(self.agent.nextstep[0])
+ self.assertEqual(0, self.world.numberofpaths)
# set the value of interest but at the homeplace
self.pg.layers[anthill.Anthill.SITE][1][1] = -1
# and this time at a good position
self.pg.layers[anthill.Anthill.SITE][0][0] = -1
self.assertTrue(self.agent.check(positions))
self.assertIsNotNone(self.agent.nextstep[0])
self.assertEqual(1, self.agent.nextstep[0])
+ self.assertEqual(1, self.world.numberofpaths)
def test_choose(self):
- # This one is quite difficult to test as it is mainly a fork of
- # possible other methods which are directly testable
- pass
+ # every second step should be a goal..
+ self.pg.layers[anthill.Anthill.SITE][0][0] = -1
+ self.pg.layers[anthill.Anthill.SITE][2][0] = -1
+ self.pg.layers[anthill.Anthill.SITE][0][2] = -1
+ self.pg.layers[anthill.Anthill.SITE][2][2] = -1
+ self.world.sites = [[0,0],[2,0],[0,2],[2,2]]
+ self.agent = self.world.bear()
+ # we exclude home here to be a goal node, as the return
+ # statement in choose is mainly a shortcut and a goal node
+ # so close to home just does not make much sense
+ self.pg.layers[anthill.Anthill.SITE]\
+ [self.agent.position[0]][self.agent.position[1]] = 0
+ self.assertIsNone(self.agent.nextstep[0])
+ self.agent.choose()
+ self.assertIsNotNone(self.agent.nextstep[0])
+ self.agent.laststeps.append(self.agent.position)
+ self.agent.position = self.agent.nextstep
+ self.agent.nextstep = [None,None,None,0]
def test_walkhome(self):
#TODO walking home
@@ -57,7 +78,27 @@
def test_work(self):
# This is the ants main-loop and not that simple to test, every
# method that is called from here is tested directly
- pass
+ # (also see test_choose)
+ # see test_choose() for why we exclude home here
+ self.pg.layers[anthill.Anthill.SITE][0][0] = 0
+ self.pg.layers[anthill.Anthill.SITE][2][1] = -1
+ self.pg.layers[anthill.Anthill.SITE][1][2] = -1
+ self.world.sites = [[0,0],[2,1],[1,2]]
+ self.agent = ant.Ant(1, self.world, [0,0])
+ self.world.agents.append(self.agent)
+ self.agent.work()
+ self.assertEqual(0, self.agent.ttl)
+ self.agent.ttl = 1
+ self.agent.work()
+ if self.agent.nextstep[0] is None:
+ self.agent.work()
def test_setposition(self):
# This is an Agent method, tested there..
@@ -79,5 +120,8 @@
pass
-# def tearDown(self):
+ def tearDown(self):
+ self.pg = None
+ self.world = None
+ self.agent = None
