[GRASS-SVN] r56411 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Sat May 25 08:51:12 PDT 2013
Author: neteler
Date: 2013-05-25 08:51:11 -0700 (Sat, 25 May 2013)
New Revision: 56411
grass/trunk/gui/wxpython/docs/wxGUI.nviz.html
manual: HTML cosmetics
Modified: grass/trunk/gui/wxpython/docs/wxGUI.nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.nviz.html 2013-05-25 15:51:07 UTC (rev 56410)
+++ grass/trunk/gui/wxpython/docs/wxGUI.nviz.html 2013-05-25 15:51:11 UTC (rev 56411)
@@ -326,8 +326,8 @@
</center>
<p>
The <em>Fringe</em> panel allows you to draw fringes in different directions
-(North & East, South & East, South & West, North & West). It is possible
-to set fringe color and height of the bottom edge.
+(North & East, South & East, South & West, North & West).
+It is possible to set the fringe color and height of the bottom edge.
<p>
The <em>Decorations</em> panel enables to display north arrow and simple
scale bar. North arrow and scale bar length is determined in map units.
@@ -370,10 +370,11 @@
Please note that with wxGTK port of wxPython (Linux systems),
a problem might appear during wxNviz initialization (nothing is rendered at all)
or when rendering vectors (bad order of rendering surfaces and vectors).
-If you encounter such problems, try to change a depth buffer number
-in GUI Settings > Map Display > Advanced (possible numbers are 0, 16, 24, 32).
-It is currently not possible to automatically find out the right number which is working for your computer.
-</p>
+If you encounter such problems, try to change a depth buffer number in
+<i>wxGUI Settings > Preferences > Map Display > Advanced</i>
+(possible numbers are 0, 16, 24, 32).
+It is currently not possible to automatically determine the right number
+which is working for your computer.
<h2>SEE ALSO</h2>
