[GRASS-SVN] r56414 - grass/trunk/macosx/app
svn_grass at osgeo.org
Sat May 25 10:37:22 PDT 2013
Author: kyngchaos
Date: 2013-05-25 10:37:22 -0700 (Sat, 25 May 2013)
New Revision: 56414
grass/trunk/macosx/app/build_gui_user_menu.sh
grass/trunk/macosx/app/grass.sh.in
handle script extensions, more for #854
Modified: grass/trunk/macosx/app/build_gui_user_menu.sh
--- grass/trunk/macosx/app/build_gui_user_menu.sh 2013-05-25 17:27:44 UTC (rev 56413)
+++ grass/trunk/macosx/app/build_gui_user_menu.sh 2013-05-25 17:37:22 UTC (rev 56414)
@@ -13,7 +13,9 @@
GRASS_MMVER=`cut -d . -f 1-2 "$GISBASE/etc/VERSIONNUMBER"`
BINDIR="$GISBASE_USER/Modules/bin"
+SCRIPTDIR="$GISBASE_USER/Modules/scripts"
BINDIRG="$GISBASE_SYSTEM/Modules/bin"
+SCRIPTDIRG="$GISBASE_SYSTEM/Modules/scripts"
MENUDIR="$GISBASE_USER/Modules/etc"
echo "Rebuilding Addon menu..."
@@ -25,17 +27,26 @@
# global addons:
if [ -d "$BINDIRG" ] ; then
cd "$BINDIRG"
- CMDLISTG=`ls -1 2> /dev/null | sort -u`
+ CMDLISTG=`ls -1 2> /dev/null`
else
CMDLISTG=""
fi
+if [ -d "$SCRIPTDIRG" ] ; then
+ cd "$SCRIPTDIRG"
+ CMDLISTG="$CMDLISTG"$'\n'"`ls -1 2> /dev/null`"
+fi
+CMDLISTG=`echo "$CMDLISTG" | sort -u`
CMDGFOUND=""
if [ "$CMDLISTG" != "" ] ; then
for i in $CMDLISTG
do
- ftype="`file "$BINDIRG/$i"`"
- if [ "`echo $ftype | grep 'Mach-O'`" ] || [ "`grep '#% *Module' "$BINDIRG/$i"`" ] ; then
+ if [ -f "$BINDIRG/$i" ] ; then
+ ftype="`file $BINDIRG/$i`"
+ else
+ ftype="`file $SCRIPTDIRG/$i`"
+ fi
+ if [ "`echo $ftype | grep 'Mach-O'`" ] || [ "`grep '#% *Module' $BINDIRG/$i 2> /dev/null`" ] || [ "`grep '#% *Module' $SCRIPTDIRG/$i 2> /dev/null`" ] ; then
echo "main:$i:$i:$i" >> "$MENUDIR/xtnmenu.dat"
CMDGFOUND="1"
fi
@@ -45,13 +56,22 @@
# user addons:
CMDFIRST="1"
cd "$BINDIR"
-CMDLIST=`ls -1 2> /dev/null | sort -u`
+CMDLIST=`ls -1 2> /dev/null`
+if [ -d "$SCRIPTDIR" ] ; then
+ cd "$SCRIPTDIR"
+ CMDLIST="$CMDLIST"$'\n'"`ls -1 2> /dev/null`"
+fi
+CMDLIST=`echo "$CMDLIST" | sort -u`
if [ "$CMDLIST" != "" ] ; then
for i in $CMDLIST
do
- ftype="`file "$BINDIR/$i"`"
- if [ "`echo $ftype | grep 'Mach-O'`" ] || [ "`grep '#% *Module' "$BINDIR/$i"`" ] ; then
+ if [ -f "$BINDIR/$i" ] ; then
+ ftype="`file $BINDIR/$i`"
+ else
+ ftype="`file $SCRIPTDIR/$i`"
+ fi
+ if [ "`echo $ftype | grep 'Mach-O'`" ] || [ "`grep '#% *Module' $BINDIR/$i 2> /dev/null`" ] || [ "`grep '#% *Module' $SCRIPTDIR/$i 2> /dev/null`" ] ; then
if [ "$CMDFIRST" ] && [ "$CMDGFOUND" ] ; then
echo "separator" >> "$MENUDIR/xtnmenu.dat"
CMDFIRST=""
Modified: grass/trunk/macosx/app/grass.sh.in
--- grass/trunk/macosx/app/grass.sh.in 2013-05-25 17:27:44 UTC (rev 56413)
+++ grass/trunk/macosx/app/grass.sh.in 2013-05-25 17:37:22 UTC (rev 56414)
@@ -46,24 +46,27 @@
# add some OS X style app support paths, and create user one if missing.
mkdir -p "$GISBASE_USER/Modules/bin"
+mkdir -p "$GISBASE_USER/Modules/scripts"
if [ ! "$GRASS_ADDON_BASE" ] ; then
GRASS_ADDON_BASE="$GISBASE_USER/Modules"
fi
export GRASS_ADDON_BASE
mkdir -p "$GISBASE_USER/Modules/etc"
+addpath="$GISBASE_USER/Modules/etc:$GISBASE_SYSTEM/Modules/etc"
if [ "$GRASS_ADDON_ETC" ] ; then
- GRASS_ADDON_ETC="$GRASS_ADDON_ETC:$GISBASE_USER/Modules/etc:$GISBASE_SYSTEM/Modules/etc"
+ GRASS_ADDON_ETC="$GRASS_ADDON_ETC:$addpath"
else
- GRASS_ADDON_ETC="$GISBASE_USER/Modules/etc:$GISBASE_SYSTEM/Modules/etc"
+ GRASS_ADDON_ETC="$addpath"
fi
export GRASS_ADDON_ETC
mkdir -p "$GISBASE_USER/Modules/lib"
+addpath="$GISBASE_USER/Modules/lib:$GISBASE_SYSTEM/Modules/lib"
if [ "$DYLD_LIBRARY_PATH" ] ; then
- DYLD_LIBRARY_PATH="$GISBASE_USER/Modules/lib:$GISBASE_SYSTEM/Modules/lib:$DYLD_LIBRARY_PATH"
+ DYLD_LIBRARY_PATH="$addpath:$DYLD_LIBRARY_PATH"
else
- DYLD_LIBRARY_PATH="$GISBASE_USER/Modules/lib:$GISBASE_SYSTEM/Modules/lib"
+ DYLD_LIBRARY_PATH="$addpath"
fi
export DYLD_LIBRARY_PATH
