[GRASS-SVN] r56417 - in grass-addons/grass7/raster/r.agent: . libagent
svn_grass at osgeo.org
Sat May 25 14:47:15 PDT 2013
Author: mic
Date: 2013-05-25 14:47:15 -0700 (Sat, 25 May 2013)
New Revision: 56417
grass-addons/grass7/raster/r.agent/libagent/anthill.py
grass-addons/grass7/raster/r.agent/r.agent.aco
support multiple output per run
Modified: grass-addons/grass7/raster/r.agent/libagent/anthill.py
--- grass-addons/grass7/raster/r.agent/libagent/anthill.py 2013-05-25 19:59:06 UTC (rev 56416)
+++ grass-addons/grass7/raster/r.agent/libagent/anthill.py 2013-05-25 21:47:15 UTC (rev 56417)
@@ -41,6 +41,8 @@
self.addlayertopg(Anthill.COST)
## allow overwriting the cost map
self.overwritepenalty = False
+ # TODO probably delete all these stuff here related to output..
+ self.addsequencenumber = False
## and finally the markings from the agents
self.addlayertopg(Anthill.RESULT)
## allow overwriting the main map (if it exists)
@@ -97,7 +99,6 @@
Let the agents do their job. The actual main loop in such a world.
while rounds > 0:
-# grass.info(rounds)
if len(self.agents) < self.maxants:
# grass.info(len(self.agents))
# as there is still space on the pg, produce another ant
Modified: grass-addons/grass7/raster/r.agent/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco 2013-05-25 19:59:06 UTC (rev 56416)
+++ grass-addons/grass7/raster/r.agent/r.agent.aco 2013-05-25 21:47:15 UTC (rev 56417)
@@ -35,6 +35,10 @@
#% description: Allow overwriting existing pheromone maps
#%end
#%flag
+#% key: s
+#% description: Produce a sequence of pheromone maps (by appending a number)
+#%end
+#%flag
#% key: c
#% description: Overwrite existing cost map (only used with penalty conversion)
#%end
@@ -267,6 +271,9 @@
Organize the agents and the pheromone on the playground.
+ if world.addsequencenumber:
+ outputmapbasename = \
+ world.playground.grassmapnames[anthill.Anthill.RESULT].split("@")
if 0 < outrounds < rounds:
# calculate when to write output
mainloops = rounds / outrounds
@@ -275,7 +282,13 @@
# produce output only at the end
mainloops = 1
nextwrite = rounds
- while mainloops > 0:
+ run = 0
+ while run < mainloops:
+ print(run)
+ if outputmapbasename:
+ outputmapname = outputmapbasename[0] + str(run) + "@" + \
+ outputmapbasename[1]
+ print(outputmapname)
# grass.info(mainloops)
# loop and write out the contents at the end
world.letantsdance(nextwrite)
@@ -288,13 +301,13 @@
world.playground.layers[anthill.Anthill.RESULT][0])):
world.playground.layers["copy"][i][j] = \
world.playground.layers[anthill.Anthill.RESULT][i][j]
- world.playground.writelayer("copy", False,
+ world.playground.writelayer("copy", outputmapname,
world.overwritepheormone)
#TODO world.playground.writelayer(anthill.Anthill.RESULT, False,
#TODO world.overwritepheormone)
# print "nrofpaths:", world.nrop
# count down outer
- mainloops -= 1
+ run += 1
# print "nrofrounds", nrofrounds
def main():
@@ -305,6 +318,10 @@
options['inputmap'], options['outputmap'], flags['p'])
# world.playground.setboundsfromlayer("costs")
+ if not options['outrounds']:
+ options['outrounds'] = 0
+ elif flags['s'] and options['outrounds'] > 0:
+ world.addsequencenumber = True
if options['maxpheromone']:
world.maxpheromone = int(options['maxpheromone'])
@@ -335,10 +352,7 @@
#if arglist[0] == "stability":
#TODO ask silvia..
# world.checkvalues()
- if not options['outrounds']:
- options['outrounds'] = 0
except error.DataError:
grass.fatal("Failed to parse args..")
sys.exit(1)
