[GRASS-SVN] r56424 - in grass/trunk: imagery imagery/i.aster.toar imagery/i.class imagery/i.gensig imagery/i.gensigset imagery/i.landsat.acca imagery/i.landsat.toar scripts/i.tasscap
svn_grass at osgeo.org
Sun May 26 11:09:00 PDT 2013
Author: neteler
Date: 2013-05-26 11:09:00 -0700 (Sun, 26 May 2013)
New Revision: 56424
grass/trunk/imagery/i.aster.toar/i.aster.toar.html
grass/trunk/imagery/i.class/main.c
grass/trunk/imagery/i.gensig/main.c
grass/trunk/imagery/i.gensigset/main.c
grass/trunk/imagery/i.landsat.acca/main.c
grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
grass/trunk/imagery/i.landsat.toar/main.c
grass/trunk/imagery/imageryintro.html
grass/trunk/scripts/i.tasscap/i.tasscap.py
manual and keyword improvements
Modified: grass/trunk/imagery/i.aster.toar/i.aster.toar.html
--- grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2013-05-26 18:09:00 UTC (rev 56424)
@@ -29,8 +29,8 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.landsat.toar.html">i.landsat.toar</a><br>
-<a href="r.in.aster.html">r.in.aster</a><br>
+<a href="i.landsat.toar.html">i.landsat.toar</a>,
+<a href="r.in.aster.html">r.in.aster</a>
</em>
<h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.class/main.c 2013-05-26 18:09:00 UTC (rev 56424)
@@ -90,6 +90,7 @@
module = G_define_module();
G_add_keyword(_("imagery"));
G_add_keyword(_("classification"));
+ G_add_keyword(_("signatures"));
module->label =
_("Generates spectral signatures for an image by allowing the user "
"to outline regions of interest.");
Modified: grass/trunk/imagery/i.gensig/main.c
--- grass/trunk/imagery/i.gensig/main.c 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.gensig/main.c 2013-05-26 18:09:00 UTC (rev 56424)
@@ -40,6 +40,7 @@
G_add_keyword(_("supervised"));
G_add_keyword(_("MLC"));
module->description =
_("Generates statistics for i.maxlik from raster map.");
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.gensigset/main.c 2013-05-26 18:09:00 UTC (rev 56424)
@@ -41,6 +41,7 @@
G_add_keyword(_("SMAP"));
_("Generates statistics for i.smap from raster map.");
Modified: grass/trunk/imagery/i.landsat.acca/main.c
--- grass/trunk/imagery/i.landsat.acca/main.c 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.landsat.acca/main.c 2013-05-26 18:09:00 UTC (rev 56424)
@@ -103,7 +103,7 @@
_("Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).");
- G_add_keyword(_("landsat"));
+ G_add_keyword(_("Landsat"));
G_add_keyword(_("acca"));
band_prefix = G_define_option();
Modified: grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
--- grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2013-05-26 18:09:00 UTC (rev 56424)
@@ -202,9 +202,10 @@
<h2>SEE ALSO</h2>
<em>
- <a href="i.atcorr.html">i.atcorr</a>,
- <a href="r.mapcalc.html">r.mapcalc</a>,
- <a href="r.in.gdal.html">r.in.gdal</a>
+<a href="i.aster.toar.html">i.aster.toar</a>,
+<a href="i.atcorr.html">i.atcorr</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.in.gdal.html">r.in.gdal</a>
</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2013-05-26 18:09:00 UTC (rev 56424)
@@ -67,9 +67,11 @@
_("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+.");
G_add_keyword(_("radiometric conversion"));
- G_add_keyword(_("top-of-atmosphere reflectance"));
- G_add_keyword(_("dos-type simple atmospheric correction"));
+ G_add_keyword(_("radiance"));
+ G_add_keyword(_("reflectance"));
+ G_add_keyword(_("brightness temperature"));
+ G_add_keyword(_("atmospheric correction"));
module->overwrite = TRUE;
/* It defines the different parameters */
Modified: grass/trunk/imagery/imageryintro.html
--- grass/trunk/imagery/imageryintro.html 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/imagery/imageryintro.html 2013-05-26 18:09:00 UTC (rev 56424)
@@ -61,8 +61,9 @@
defining a certain number of ground control points
(<a href="i.group.html">i.group</a>, <a href="i.target.html">i.target</a>,
<a href="i.points.html">i.points</a>, <a href="i.rectify.html">i.rectify</a>)</li>
+<li>interactive graphical <a href="wxGUI.gcp.html">Ground Control Point (GCP) manager</a></li>
-<li>orthophoto based on DEM: <a href="i.ortho.photo.html">i.ortho.photo</a></li>
+<li>orthophoto generation based on DEM: <a href="i.ortho.photo.html">i.ortho.photo</a></li>
<li>digital handheld camera geocoding: modified procedure for
@@ -119,12 +120,11 @@
or <a href="g.gui.iclass.html">g.gui.iclass</a>, <a href="i.maxlik.html">i.maxlik</a>)
using the Maximum Likelihood classification method</li>
</ul>
-<li> Combined radiometric/geometric (segmentation based) supervised
- classification (<a href="i.gensigset.html">i.gensigset</a>,
+<li> Combined radiometric/geometric (segmentation based) classification:
+ <ul>
+ <li> Supervised classification (<a href="i.gensigset.html">i.gensigset</a>,
<a href="i.smap.html">i.smap</a>)
-</ul>
-<ul>
+ </ul>
<li> Object-oriented classification:
<ul>
<li> Unsupervised classification (segmentation based:
@@ -133,7 +133,8 @@
</ul>
Kappa statistic can be calculated to validate the results
-(<a href="r.kappa.html">r.kappa</a>).
+(<a href="r.kappa.html">r.kappa</a>). Covariance/correlation matrices can be
+calculated with <a href="r.covar.html">r.covar</a>.
<h3>Image fusion</h3>
@@ -143,6 +144,16 @@
<a href="i.his.rgb.html">i.his.rgb</a>) and the Brovey and PCA transform
(<a href="i.pansharpen.html">i.pansharpen</a>) methods.
+<h3>Radiometric corrections</h3>
+Atmospheric effects can be removed with <a href="i.atcorr.html">i.atcorr</a>.
+Correction for topographic/terrain effects is offered in <a href="i.topo.corr.html">i.topo.corr</a>.
+Clouds in LANDSAT data can be identified and removed with
+<a href="i.landsat.acca.html">i.landsat.acca</a>.
+Calibrated digital numbers of LANDSAT and ASTER imagery may be converted to
+top-of-atmosphere radiance or reflectance and temperature (<a href="i.aster.toar.html">i.aster.toar</a>,
+<a href="i.landsat.toar.html">i.landsat.toar</a>).
<h3>Time series processing</h3>
GRASS also offers support for time series processing (<a
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2013-05-26 13:28:33 UTC (rev 56423)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2013-05-26 18:09:00 UTC (rev 56424)
@@ -36,6 +36,8 @@
#% description: Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data.
#% keywords: imagery
#% keywords: transformation
+#% keywords: Landsat
+#% keywords: Tasseled Cap transformation
#%end
#%flag
#% key: 4
