[GRASS-SVN] r56426 - in grass/trunk: db/db.connect display/d.erase display/d.his display/d.path display/d.rgb general/g.mremove general/g.version gui/wxpython/animation gui/wxpython/dbmgr gui/wxpython/gmodeler gui/wxpython/iclass gui/wxpython/mapswipe gui/wxpython/psmap gui/wxpython/rlisetup gui/wxpython/vdigit imagery/i.albedo imagery/i.biomass imagery/i.cca imagery/i.class imagery/i.gensig imagery/i.his.rgb imagery/i.landsat.acca imagery/i.maxlik imagery/i.modis.qc imagery/i.rgb.his misc/m.transform raster/r.composite raster/r.his raster/r.in.arc raster/r.in.ascii raster/r.in.png raster/r.in.xyz raster/r.info raster/r.li raster/r.li/r.li.daemon raster/r.los raster/r.out.arc raster/r.out.ascii raster/r.out.png raster/r.shaded.relief2 raster3d/r3.in.ascii raster3d/r3.info raster3d/r3.mask raster3d/r3.out.ascii scripts/d.redraw scripts/r.in.wms scripts/r.out.xyz scripts/r.rgb scripts/r.shaded.relief scripts/r3.in.xyz scripts/v.in.wfs temporal/t.rename temporal/t.support vector/v. in.ascii vector/v.in.dxf vector/v.in.ogr vector/v.net vector/v.net.visibility vector/v.out.ascii vector/v.out.ogr
Sun May 26 12:52:19 PDT 2013
Author: neteler
Date: 2013-05-26 12:52:19 -0700 (Sun, 26 May 2013)
New Revision: 56426
   grass/trunk/db/db.connect/main.c
   grass/trunk/display/d.erase/main.c
   grass/trunk/display/d.his/main.c
   grass/trunk/display/d.path/main.c
   grass/trunk/display/d.rgb/main.c
   grass/trunk/general/g.mremove/main.c
   grass/trunk/general/g.version/main.c
   grass/trunk/gui/wxpython/animation/g.gui.animation.py
   grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
   grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
   grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
   grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
   grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
   grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
   grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
   grass/trunk/imagery/i.albedo/main.c
   grass/trunk/imagery/i.biomass/main.c
   grass/trunk/imagery/i.cca/main.c
   grass/trunk/imagery/i.class/main.c
   grass/trunk/imagery/i.gensig/main.c
   grass/trunk/imagery/i.his.rgb/main.c
   grass/trunk/imagery/i.landsat.acca/main.c
   grass/trunk/imagery/i.maxlik/main.c
   grass/trunk/imagery/i.modis.qc/main.c
   grass/trunk/imagery/i.rgb.his/main.c
   grass/trunk/misc/m.transform/main.c
   grass/trunk/raster/r.composite/main.c
   grass/trunk/raster/r.composite/r.composite.html
   grass/trunk/raster/r.his/main.c
   grass/trunk/raster/r.in.arc/main.c
   grass/trunk/raster/r.in.ascii/main.c
   grass/trunk/raster/r.in.png/main.c
   grass/trunk/raster/r.in.xyz/main.c
   grass/trunk/raster/r.info/main.c
   grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
   grass/trunk/raster/r.li/r.li.html
   grass/trunk/raster/r.los/main.c
   grass/trunk/raster/r.out.arc/main.c
   grass/trunk/raster/r.out.ascii/main.c
   grass/trunk/raster/r.out.png/main.c
   grass/trunk/raster/r.shaded.relief2/main.c
   grass/trunk/raster3d/r3.in.ascii/main.c
   grass/trunk/raster3d/r3.info/r3.info.main.c
   grass/trunk/raster3d/r3.mask/main.c
   grass/trunk/raster3d/r3.out.ascii/main.c
   grass/trunk/scripts/d.redraw/d.redraw.py
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.out.xyz/r.out.xyz.py
   grass/trunk/scripts/r.rgb/r.rgb.py
   grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
   grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/temporal/t.rename/t.rename.py
   grass/trunk/temporal/t.support/t.support.py
   grass/trunk/vector/v.in.ascii/main.c
   grass/trunk/vector/v.in.dxf/main.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.net.visibility/main.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.out.ascii/main.c
   grass/trunk/vector/v.out.ogr/main.c
keyword cleanup cont'ed
Modified: grass/trunk/db/db.connect/main.c
--- grass/trunk/db/db.connect/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/db/db.connect/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -44,6 +44,7 @@
     G_add_keyword(_("database"));
     G_add_keyword(_("attribute table"));
     G_add_keyword(_("connection settings"));
+    G_add_keyword(_("drivers"));
     module->description =
 	_("Prints/sets general DB connection for current mapset.");
Modified: grass/trunk/display/d.erase/main.c
--- grass/trunk/display/d.erase/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/display/d.erase/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -29,7 +29,6 @@
     G_add_keyword(_("display"));
     G_add_keyword(_("graphics"));
     G_add_keyword(_("monitors"));
-    G_add_keyword(_("CLI"));
 	_("Erases the contents of the active graphics display frame with user defined color.");
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/display/d.his/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -62,8 +62,8 @@
     G_add_keyword(_("color transformation"));
-    G_add_keyword(_("RGB"));
-    G_add_keyword(_("HIS"));
+    G_add_keyword("RGB");
+    G_add_keyword("HIS");
 	_("Displays the result obtained by combining "
 	  "hue, intensity, and saturation (his) values "
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/display/d.path/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -47,7 +47,7 @@
     module = G_define_module();
     G_add_keyword(_("network"));
-    G_add_keyword(_("path"));
+    G_add_keyword(_("shortest path"));
 	_("Finds shortest path for selected starting and ending node.");
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/display/d.rgb/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -53,7 +53,7 @@
     G_add_keyword(_("raster"));
 	_("Displays three user-specified raster maps "
 	  "as red, green, and blue overlays in the active graphics frame.");
Modified: grass/trunk/general/g.mremove/main.c
--- grass/trunk/general/g.mremove/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/general/g.mremove/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -61,7 +61,6 @@
     G_add_keyword(_("general"));
     G_add_keyword(_("map management"));
     G_add_keyword(_("remove"));
-    G_add_keyword(_("multi"));
 	_("Removes data base element files from "
 	  "the user's current mapset using regular expressions.");
Modified: grass/trunk/general/g.version/main.c
--- grass/trunk/general/g.version/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/general/g.version/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -58,7 +58,7 @@
-    G_add_keyword(_("supporting"));
+    G_add_keyword(_("support"));
     module->label = _("Displays GRASS version info.");
     module->description = _("Optionally also print build or copyright information.");
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -22,7 +22,7 @@
 #%module
 #% description: Tool for animating a series of raster and vector maps or a space time raster ot vector dataset.
 #% keywords: general
-#% keywords: gui
+#% keywords: GUI
 #% keywords: display
 #%end
 #%option G_OPT_R_INPUTS
Modified: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -21,7 +21,7 @@
 #%module
 #% description: Launches graphical attribute table manager.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: attribute table
 #% keywords: database
 #%end
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -22,7 +22,7 @@
 #% label: Graphical Modeler.
 #% description: Allows to interactively create, edit and manage models.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: graphical modeler
 #% keywords: workflow
 #%end
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -23,9 +23,10 @@
 #% label: Tool for supervised classification of imagery data.
 #% description: Generates spectral signatures for an image by allowing the user to outline regions of interest.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: imagery
 #% keywords: classification
+#% keywords: Maximum Likelihood Classification
 #% keywords: signatures
 #%end
 #%flag
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -22,7 +22,7 @@
 #%module
 #% description: Interactively compares two maps by swiping a visibility bar.
-#% keywords: gui
+#% keywords: GUI
 #%end
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -21,7 +21,7 @@
 #%module
 #% description: Tool for creating hardcopy map outputs.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: printing
 #%end
 #%option G_OPT_F_INPUT
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -21,7 +21,7 @@
 #%module
 #% description: Configuration tool for r.li modules.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: raster
 #% keywords: landscape structure analysis
 #%end
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -21,9 +21,9 @@
 #%module
 #% description: Interactive editing and digitization of vector maps.
-#% keywords: gui
+#% keywords: GUI
 #% keywords: vector
-#% keywords: editig
+#% keywords: editing
 #% keywords: digitization
 #%end
 #%option G_OPT_V_MAP
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.albedo/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -87,7 +87,7 @@
     G_add_keyword(_("imagery"));
     G_add_keyword(_("albedo"));
-    G_add_keyword(_("surface reflectance"));
+    G_add_keyword(_("reflectance"));
     module->description = _("Computes broad band albedo from surface reflectance.");
     /* Define the different options */
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.biomass/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -49,7 +49,7 @@
     G_add_keyword(_("biomass"));
-    G_add_keyword(_("fpar"));
+    G_add_keyword("FPAR");
     G_add_keyword(_("yield"));
 	_("Computes biomass growth, precursor of crop yield calculation.");
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.cca/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -83,9 +83,9 @@
     G_add_keyword(_("statistics"));
-    G_add_keyword(_("CCA"));
+    G_add_keyword("CCA");
-	_("Canonical components analysis (cca) "
+	_("Canonical components analysis (CCA) "
 	  "program for image processing.");
     grp_opt = G_define_standard_option(G_OPT_I_GROUP);
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.class/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -91,6 +91,7 @@
     G_add_keyword(_("classification"));
     G_add_keyword(_("signatures"));
+    G_add_keyword(_("Maximum Likelihood Classification"));
     module->label =
 	_("Generates spectral signatures for an image by allowing the user "
 	  "to outline regions of interest.");
Modified: grass/trunk/imagery/i.gensig/main.c
--- grass/trunk/imagery/i.gensig/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.gensig/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -39,7 +39,8 @@
     G_add_keyword(_("supervised"));
-    G_add_keyword(_("MLC"));
+    G_add_keyword("MLC");
 	_("Generates statistics for i.maxlik from raster map.");
Modified: grass/trunk/imagery/i.his.rgb/main.c
--- grass/trunk/imagery/i.his.rgb/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.his.rgb/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -45,8 +45,8 @@
 	_("Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
 	  "RGB (Red-Green-Blue) color space.");
Modified: grass/trunk/imagery/i.landsat.acca/main.c
--- grass/trunk/imagery/i.landsat.acca/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.landsat.acca/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -104,7 +104,7 @@
 	_("Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).");
     G_add_keyword(_("Landsat"));
-    G_add_keyword(_("acca"));
+    G_add_keyword("ACCA");
     band_prefix = G_define_option();
     band_prefix->key = "input_prefix";
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.maxlik/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -60,7 +60,8 @@
     module->label =
 	_("Classifies the cell spectral reflectances in imagery data.");
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.modis.qc/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -117,7 +117,7 @@
     G_add_keyword(_("imagery quality assessment"));
     G_add_keyword(_("land surface temperature"));
     G_add_keyword(_("vegetation"));
     G_add_keyword(_("MODIS"));
Modified: grass/trunk/imagery/i.rgb.his/main.c
--- grass/trunk/imagery/i.rgb.his/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/imagery/i.rgb.his/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -45,8 +45,8 @@
 	_("Transforms raster maps from RGB (Red-Green-Blue) color space to "
 	  "HIS (Hue-Intensity-Saturation) color space.");
Modified: grass/trunk/misc/m.transform/main.c
--- grass/trunk/misc/m.transform/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/misc/m.transform/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -315,7 +315,7 @@
     G_add_keyword(_("transformation"));
-    G_add_keyword(_("GCP"));
+    G_add_keyword("GCP");
 	_("Computes a coordinate transformation based on the control points.");
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.composite/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -71,6 +71,7 @@
     G_add_keyword(_("composite"));
 	_("Combines red, green and blue raster maps into "
 	  "a single composite raster map.");
Modified: grass/trunk/raster/r.composite/r.composite.html
--- grass/trunk/raster/r.composite/r.composite.html	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.composite/r.composite.html	2013-05-26 19:52:19 UTC (rev 56426)
@@ -30,7 +30,8 @@
 <a href="d.rast.html">d.rast</a>,
 <a href="d.rgb.html">d.rgb</a>,
 <a href="r.blend.html">r.blend</a>,
-<a href="r.colors.html">r.colors</a>
+<a href="r.colors.html">r.colors</a>,
+<a href="r.rgb.html">r.rgb</a>,
 </em>
 <p><em>
 <a href="http://en.wikipedia.org/wiki/Floyd-Steinberg_dithering">Wikipedia Entry: Floyd-Steinberg dithering</a>
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.his/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -61,8 +61,8 @@
 	_("Generates red, green and blue raster map layers "
 	  "combining hue, intensity and saturation (HIS) "
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.in.arc/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -59,6 +59,7 @@
     G_add_keyword(_("import"));
+    G_add_keyword("ASCII");
 	_("Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map.");
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.in.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -69,7 +69,7 @@
     G_add_keyword(_("conversion"));
-    G_add_keyword("ascii");
 	_("Converts a GRASS ASCII raster file to binary raster map.");
Modified: grass/trunk/raster/r.in.png/main.c
--- grass/trunk/raster/r.in.png/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.in.png/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -518,7 +518,7 @@
-    G_add_keyword("png");
+    G_add_keyword("PNG");
     module->description = _("Imports non-georeferenced PNG format image.");
     inopt = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.in.xyz/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -159,6 +159,8 @@
+    G_add_keyword(_("conversion"));
     G_add_keyword(_("LIDAR"));
 	_("Create a raster map from an assemblage of many coordinates using univariate statistics.");
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.info/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -68,6 +68,7 @@
     G_add_keyword(_("metadata"));
+    G_add_keyword(_("extent"));
     G_add_keyword(_("history"));
 	_("Outputs basic information about a raster map.");
Modified: grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
--- grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html	2013-05-26 19:52:19 UTC (rev 56426)
@@ -85,7 +85,7 @@
 <p>
 <i>Last changed: $Date$</i>
-<HR>
-<p><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
+<hr>
+<p><a href="index.html">Main index</a> - <a href="raster.html">Raster index</a> - <a href="topics.html">Topics index</a> - <a href="keywords.html">Keywords Index</a> - <a href="full_index.html">Full index</a>
 </body>
 </html>
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.li/r.li.html	2013-05-26 19:52:19 UTC (rev 56426)
@@ -13,7 +13,7 @@
 <em><b>r.li</b></em> - Landscape structure analysis package overview.
 <h2>KEYWORDS</h2>
-raster, landscape structure analysis, overview, landscape metrics, landscape pattern, landscape analysis
+raster, landscape structure analysis, landscape metrics, landscape pattern, landscape analysis
 <h2>DESCRIPTION</h2>
@@ -180,7 +180,6 @@
 <p><i>Last changed: $Date$</i>
 <hr>
-  - <a href="full_index.html">Full index</a>
 </body>
 </html>
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.los/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -92,6 +92,7 @@
     G_add_keyword(_("viewshed"));
+    G_add_keyword(_("line of sight"));
     module->description = _("Line-of-sight raster analysis program.");
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.out.arc/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -59,6 +59,7 @@
     G_add_keyword(_("export"));
 	_("Converts a raster map layer into an ESRI ARCGRID file.");
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.out.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -58,6 +58,7 @@
 	_("Converts a raster map layer into a GRASS ASCII text file.");
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.out.png/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -111,7 +111,7 @@
 	_("Export a GRASS raster map as a non-georeferenced PNG image.");
Modified: grass/trunk/raster/r.shaded.relief2/main.c
--- grass/trunk/raster/r.shaded.relief2/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster/r.shaded.relief2/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -104,6 +104,7 @@
+    G_add_keyword(_("elevation"));
     G_add_keyword(_("terrain"));
     module->label = _("Creates shaded relief map from an elevation map (DEM).");
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster3d/r3.in.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -316,6 +316,8 @@
     G_add_keyword(_("raster3d"));
     G_add_keyword(_("voxel"));
         _("Converts a 3D ASCII raster text file into a (binary) 3D raster map.");
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -74,6 +74,7 @@
 	_("Outputs basic information about a user-specified 3D raster map layer.");
Modified: grass/trunk/raster3d/r3.mask/main.c
--- grass/trunk/raster3d/r3.mask/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster3d/r3.mask/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -130,6 +130,7 @@
+    G_add_keyword(_("mask"));
 	_("Establishes the current working 3D raster mask.");
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/raster3d/r3.out.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -305,6 +305,8 @@
         _("Converts a 3D raster map layer into a ASCII text file.");
Modified: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/d.redraw/d.redraw.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -17,7 +17,6 @@
 #% keywords: graphics
 #% keywords: monitors
-#% keywords: CLI
 #%end
 import sys
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -16,7 +16,7 @@
 #% description: Downloads and imports data from WMS server.
 #% keywords: raster
 #% keywords: import
-#% keywords: wms
+#% keywords: WMS
 #%end
 #%option
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -20,6 +20,8 @@
 #% description: Exports a raster map to a text file as x,y,z values based on cell centers.
 #% keywords: raster
 #% keywords: export
+#% keywords: ASCII
+#% keywords: conversion
 #%end
 #%end
Modified: grass/trunk/scripts/r.rgb/r.rgb.py
--- grass/trunk/scripts/r.rgb/r.rgb.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/r.rgb/r.rgb.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -16,7 +16,7 @@
 #%module
 #% description: Splits a raster map into red, green and blue maps.
 #% keywords: raster
-#% keywords: rgb
+#% keywords: RGB
 #%end
 #%end
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -52,6 +52,7 @@
 #% description: Creates shaded relief map from an elevation map (DEM).
 #% keywords: raster
 #% keywords: elevation
+#% keywords: terrain
 #%end
 #% description: Name of input elevation raster map
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -22,7 +22,10 @@
 #%Module
 #% description: Create a 3D raster map from an assemblage of many coordinates using univariate statistics
-#% keywords: raster3d, import, voxel, LiDAR
+#% keywords: raster3d
+#% keywords: import
+#% keywords: voxel
+#% keywords: LIDAR
 #%End
 #%Flag
 #% key: s
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -26,7 +26,7 @@
 #% description: Imports GetFeature from a WFS server.
 #% keywords: vector
 #% keywords: import
-#% keywords: wfs
+#% keywords: WFS
 #%end
 #%option
 #% key: url
Modified: grass/trunk/temporal/t.rename/t.rename.py
--- grass/trunk/temporal/t.rename/t.rename.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/temporal/t.rename/t.rename.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -17,7 +17,8 @@
 #%module
 #% description: Renames a space time dataset
 #% keywords: temporal
-#% keywords: support
+#% keywords: map management
+#% keywords: rename
 #%end
 #%option G_OPT_STDS_INPUT
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/temporal/t.support/t.support.py	2013-05-26 19:52:19 UTC (rev 56426)
@@ -17,7 +17,7 @@
 #%module
 #% description: Modifies the metadata of a space time dataset.
+#% keywords: metadata
 #%end
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.in.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -48,6 +48,7 @@
     G_add_keyword(_("vector"));
 	_("Creates a vector map from an ASCII points file or ASCII vector file.");
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.in.dxf/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -63,7 +63,7 @@
-    G_add_keyword(_("dxf"));
+    G_add_keyword("DXF");
 	_("Converts file in DXF format to GRASS vector map.");
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.in.ogr/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -124,6 +124,7 @@
+    G_add_keyword("OGR");
     module->description = _("Imports vector data into a GRASS vector map using OGR library.");
     param.dsn = G_define_option();
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.net/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -44,7 +44,7 @@
-    G_add_keyword(_("maintenance"));
+    G_add_keyword(_("network maintenance"));
     module->description = _("Performs network maintenance.");
     define_options(&opt);
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.net.visibility/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -44,7 +44,7 @@
     G_add_keyword(_("visibility"));
     module->description = _("Visibility graph construction.");
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.out.ascii/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -46,7 +46,7 @@
-    G_add_keyword(_("ascii"));
     module->label =
 	_("Exports a vector map to a GRASS ASCII vector representation.");
     module->description = _("By default only features with category are exported. "
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2013-05-26 18:31:09 UTC (rev 56425)
+++ grass/trunk/vector/v.out.ogr/main.c	2013-05-26 19:52:19 UTC (rev 56426)
@@ -83,7 +83,7 @@
-    G_add_keyword(_("ogr"));
 	_("Converts a vector map to any of the supported OGR vector formats.");
