[GRASS-SVN] r56455 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue May 28 06:35:48 PDT 2013
Author: martinl
Date: 2013-05-28 06:35:47 -0700 (Tue, 28 May 2013)
New Revision: 56455
grass/trunk/lib/vector/Vlib/build_pg.c
vlib(pg): fix writing nodes/areas/isles into DB for large array (allocate dynamic buffer for SQL command)
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2013-05-28 12:55:35 UTC (rev 56454)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2013-05-28 13:35:47 UTC (rev 56455)
@@ -534,9 +534,8 @@
const struct Format_info_pg *pg_info)
int i, node_id;
- size_t stmt_lines_size, stmt_angles_size;
- char *stmt_lines, *stmt_angles;
- char stmt[DB_SQL_MAX];
+ size_t stmt_lines_size, stmt_angles_size, stmt_size;
+ char *stmt_lines, *stmt_angles, *stmt;
const struct P_node *Node;
const struct Format_info_offset *offset;
@@ -545,6 +544,9 @@
if (plus->n_nodes != offset->array_num)
return -1;
+ stmt_size = 2 * DB_SQL_MAX + 512;
+ stmt = (char *) G_malloc(stmt_size);
stmt_lines = stmt_angles = NULL;
for (i = 1; i <= plus->n_nodes; i++) {
Node = plus->Node[i];
@@ -559,6 +561,10 @@
build_stmt_id(Node->angles, Node->n_lines, FALSE, NULL, &stmt_angles, &stmt_angles_size);
/* build SQL statement to add new node into 'node_grass' */
+ if (stmt_lines_size + stmt_angles_size + 512 > stmt_size) {
+ stmt_size = stmt_lines_size + stmt_angles_size + 512;
+ stmt = (char *) G_realloc(stmt, stmt_size);
sprintf(stmt, "INSERT INTO \"%s\".%s VALUES ("
"%d, '{%s}', '{%s}')", pg_info->toposchema_name, TOPO_TABLE_NODE,
node_id, stmt_lines, stmt_angles);
@@ -569,6 +575,7 @@
G_free(stmt_lines);
G_free(stmt_angles);
+ G_free(stmt);
return 0;
@@ -591,13 +598,15 @@
int area, centroid;
- size_t stmt_lines_size, stmt_isles_size;
- char *stmt_lines, *stmt_isles;
+ size_t stmt_lines_size, stmt_isles_size, stmt_size;
+ char *stmt_lines, *stmt_isles, *stmt;
const struct P_line *Line;
const struct P_area *Area;
stmt_lines = stmt_isles = NULL;
for (area = 1; area <= plus->n_areas; area++) {
Area = plus->Area[area];
@@ -625,6 +634,10 @@
+ if (stmt_lines_size + stmt_isles_size + 512 > stmt_size) {
+ stmt_size = stmt_lines_size + stmt_isles_size + 512;
"%d, '{%s}', %d, '{%s}')", pg_info->toposchema_name, TOPO_TABLE_AREA,
area, stmt_lines, centroid, stmt_isles);
@@ -635,6 +648,7 @@
G_free(stmt_lines);
G_free(stmt_isles);
+ G_free(stmt);
return 0;
@@ -656,12 +670,14 @@
int isle;
- size_t stmt_lines_size;
- char *stmt_lines;
+ size_t stmt_lines_size, stmt_size;
+ char *stmt_lines, *stmt;
const struct P_isle *Isle;
+ stmt_size = DB_SQL_MAX + 512;
stmt_lines = NULL;
for (isle = 1; isle <= plus->n_isles; isle++) {
Isle = plus->Isle[isle];
@@ -672,6 +688,10 @@
build_stmt_id(Isle->lines, Isle->n_lines, TRUE, NULL, &stmt_lines, &stmt_lines_size);
+ if (stmt_lines_size + 512 > stmt_size) {
+ stmt_size = stmt_lines_size + 512;
"%d, '{%s}', %d)", pg_info->toposchema_name, TOPO_TABLE_ISLE,
isle, stmt_lines, Isle->area);
@@ -681,7 +701,8 @@
G_free(stmt_lines);
+ G_free(stmt);
return 0;
