[GRASS-SVN] r56470 - grass/trunk/vector/v.out.postgis
Wed May 29 05:09:47 PDT 2013
Author: martinl
Date: 2013-05-29 05:09:46 -0700 (Wed, 29 May 2013)
New Revision: 56470
   grass/trunk/vector/v.out.postgis/main.c
v.out.postgis: correct done message
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c	2013-05-29 12:08:34 UTC (rev 56469)
+++ grass/trunk/vector/v.out.postgis/main.c	2013-05-29 12:09:46 UTC (rev 56470)
@@ -162,9 +162,14 @@
         G_fatal_error(_("No features exported. PostGIS layer <%s> not created."),
                       Vect_get_name(&Out));
-    G_done_msg(_("%d features (%s) written to <%s>."),
-               Vect_get_num_lines(&Out), Vect_get_finfo_geometry_type(&Out),
-               Vect_get_name(&Out));
+    if (!flags.topo->answer)
+        G_done_msg(_("%d features (%s type) written to <%s>."),
+                   Vect_sfa_get_num_features(&Out), Vect_get_finfo_geometry_type(&Out),
+                   Vect_get_name(&Out));
+    else
+        G_done_msg(_("%d primitives written to <%s>."),
+                   Vect_get_num_lines(&Out), Vect_get_finfo_geometry_type(&Out),
     /* close output map */
     Vect_close(&Out);
