[GRASS-SVN] r56472 - grass-addons/grass6/raster/r.fidimo
Wed May 29 05:10:46 PDT 2013
Author: jradinger
Date: 2013-05-29 05:10:46 -0700 (Wed, 29 May 2013)
New Revision: 56472
   grass-addons/grass6/raster/r.fidimo/r.fidimo.py
Modified: grass-addons/grass6/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-05-29 12:10:21 UTC (rev 56471)
+++ grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-05-29 12:10:46 UTC (rev 56472)
@@ -191,7 +191,7 @@
 	global tmp_map_rast
 	global tmp_map_vect
-	tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'shreve_tmp_', 'source_populations_scalar_', 'strahler_tmp_', 'stream_segments_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
+	tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'shreve_tmp_', 'source_populations_scalar_','source_populations_scalar_corrected_', 'strahler_tmp_', 'stream_segments_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
 	tmp_map_vect = ['river_points_tmp_', 'river_vector_tmp_', 'river_vector_nocat_tmp_','source_points_']
