[GRASS-SVN] r56475 - grass/trunk/lib/vector/Vlib
Wed May 29 05:48:07 PDT 2013
Author: martinl
Date: 2013-05-29 05:48:06 -0700 (Wed, 29 May 2013)
New Revision: 56475
   grass/trunk/lib/vector/Vlib/open.c
vlib: report map format for created maps in verbose mode
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2013-05-29 12:43:15 UTC (rev 56474)
+++ grass/trunk/lib/vector/Vlib/open.c	2013-05-29 12:48:06 UTC (rev 56475)
@@ -526,6 +526,7 @@
                 unlink(file_path);
     G_free(path);
     return level;
@@ -810,6 +811,19 @@
     Map->dblnk = Vect_new_dblinks_struct();
+    if (Map->fInfo.ogr.driver_name) {
+        G_verbose_message(_("Using OGR/%s format"), Map->fInfo.ogr.driver_name);
+    else if (Map->fInfo.pg.conninfo) {
+        if (Map->fInfo.pg.toposchema_name)
+            G_verbose_message(_("Using PostGIS Topology format"));
+        else
+            G_verbose_message(_("Using PostGIS format"));
+    else {
+        G_verbose_message(_("Using native format"));
     return 1;
