[GRASS-SVN] r56488 - in grass-addons/grass6/display: . d.anaglyph
svn_grass at osgeo.org
Wed May 29 10:00:41 PDT 2013
Author: hamish
Date: 2013-05-29 10:00:41 -0700 (Wed, 29 May 2013)
New Revision: 56488
Added:
grass-addons/grass6/display/d.anaglyph/
grass-addons/grass6/display/d.anaglyph/Makefile
grass-addons/grass6/display/d.anaglyph/d.anaglyph
grass-addons/grass6/display/d.anaglyph/description.html
grass-addons/grass6/display/Makefile
+ module to create 3D stereo anaglyphs
Modified: grass-addons/grass6/display/Makefile
--- grass-addons/grass6/display/Makefile 2013-05-29 16:30:59 UTC (rev 56487)
+++ grass-addons/grass6/display/Makefile 2013-05-29 17:00:41 UTC (rev 56488)
@@ -1,6 +1,8 @@
MODULE_TOPDIR = ..
SUBDIRS = \
+ d.anaglyph \
+ d.barb \
d.edit.rast \
d.frontline \
d.hyperlink \
Copied: grass-addons/grass6/display/d.anaglyph/Makefile (from rev 55245, grass-addons/grass6/display/d.region.box/Makefile)
--- grass-addons/grass6/display/d.anaglyph/Makefile (rev 0)
+++ grass-addons/grass6/display/d.anaglyph/Makefile 2013-05-29 17:00:41 UTC (rev 56488)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = d.anaglyph
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/display/d.anaglyph/d.anaglyph
--- grass-addons/grass6/display/d.anaglyph/d.anaglyph (rev 0)
+++ grass-addons/grass6/display/d.anaglyph/d.anaglyph 2013-05-29 17:00:41 UTC (rev 56488)
@@ -0,0 +1,315 @@
+#!/bin/sh
+# MODULE: d.anaglyph
+# AUTHOR(S): M. Hamish Bowman, Dunedin, New Zealand
+# Based on the method by Peter Loewe
+# PURPOSE: Creates a sterographic 3D image suitable for viewing with
+# red/cyan glasses.
+# COPYRIGHT: (c) 2013 Hamish Bowman, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# FIXME: ~~NVIZ's "x" viewing position does not preserve the map rotation, but
+# the "y" viewing position does. So currently we use the "y" to tilt,
+# but that would require everyone to also tilt their heads 90 degrees
+# to see the 3D effect, so we use some inefficient rotations to get
+# around that.~~ --update-- That's wrong, it's the *minor axis* which
+# does not preserve the map rotation.
+#%Module
+#% description: Creates a sterographic 3D image suitable for viewing with red/cyan glasses.
+#% keywords: raster
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% key_desc: name
+#% description: Name of input raster map
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: no
+#% label: Name for output PNG image
+#% description: If not given will be input map + ".png"
+#% gisprompt: new,file,file
+#%End
+#%Option
+#% key: size
+#% type: integer
+#% required: no
+#% multiple: no
+#% key_desc: width,height
+#% description: Width and height of output image
+#% answer: 640,480
+#%End
+#%Option
+#% key: z_exaggeration
+#% type: double
+#% required: no
+#% multiple: no
+#% key_desc: value
+#% description: Z-exaggeration
+#% answer: 2.0
+#%End
+#%Option
+#% key: vpoints
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of point vector overlay map
+#% gisprompt: old,vector,vector
+#% guisection: Vector overlay
+#%End
+#%Option
+#% key: vlines
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of line vector overlay map
+#%End
+#%Flag
+#% key: f
+#% description: Flatten terrain
+#%End
+#%Flag
+#% key: e
+#% description: Equalize contrast
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ g.message -e "awk is required, please install awk or gawk first"
+ exit 1
+fi
+# set environment so that awk works properly in all locales
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+if [ ! -x "`which pnmtopng`" ]\
+ || [ ! -x "`which ppmtorgb3`" ] \
+ || [ ! -x "`which rgb3toppm`" ] ; then
+ g.message -e "The NetPBM tools are required, please install them first"
+ exit 1
+fi
+if [ $GIS_FLAG_F -eq 0 ] ; then
+ #### check if we have the r.rot90 module
+ if [ ! -x "`which r.rot90`" ] ; then
+ g.message -e "The r.rot90 addon module is required, please install it first or use the -f flag."
+ exit 1
+ fi
+fi
+TEMP_IMG="tmp_anaglyph_$$"
+cleanup()
+ g.remove "$TEMP_IMG" --quiet
+ rm -f "$TEMPFILE" "${TEMPFILE}."*
+ unset WIND_OVERRIDE
+ g.remove region="tmp_anaglyph.$$" --quiet
+# what to do in case of user break:
+exitprocedure()
+ g.message -e 'User break!'
+ cleanup
+ exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+check_ret()
+ if [ $? -ne 0 ] ; then
+ g.message "There was a problem. Aborting."
+ cleanup
+ exit 1
+ fi
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
+ g.message -e "Unable to create temporary files"
+ exit 1
+fi
+INMAP="$GIS_OPT_INPUT"
+if [ -z "$GIS_OPT_OUTPUT" ] ; then
+ OUTFILE1="$GIS_OPT_INPUT.png"
+else
+ OUTFILE1="$GIS_OPT_OUTPUT"
+fi
+#ensure the extension
+#is there a simpler way of testing for --overwrite?
+if [ -e "$OUTFILE" ] ; then
+ if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+ g.message -e "File <$OUTFILE> already exists"
+ exit 1
+ fi
+fi
+SIZE="$GIS_OPT_SIZE"
+if [ "$GIS_FLAG_E" -eq 1 ] ; then
+ EFLAG="-e"
+else
+ EFLAG=""
+fi
+ZEXAG="$GIS_OPT_Z_EXAGGERATION"
+if [ -n "$GIS_OPT_VPOINTS" ] ; then
+ VPOINTS="vpoint=$GIS_OPT_VPOINTS vpoint_color=yellow"
+else
+ VPOINTS=""
+fi
+if [ -n "$GIS_OPT_VLINES" ] ; then
+ eval `g.region -g`
+ VLINES="vline=$GIS_OPT_VLINES vline_color=black vline_height=$nsres"
+else
+ VLINES=""
+fi
+OLDDIR="`pwd`"
+cd `dirname "$TEMPFILE"`
+#### dynamic viewpoint height calculations
+eval `g.region -ge`
+# various scales of the average map extent to use for the viewing height
+avg_extent=`echo "$ns_extent $ew_extent" | awk '{print ($1 + $2)/2.0}'`
+# need to adjust viewing height and vertical exaggeration in tandem, at zex=2 it's about right.
+avg_extentN=`echo "$avg_extent $ZEXAG" | awk '{print $1 * (2 / $2)}'`
+# TODO: at higher z-exag the viewpoint separation should be increased
+extent1_25=`echo "$avg_extentN" | awk '{print 1.25 * $1}'`
+extent1_45=`echo "$avg_extentN" | awk '{print 1.45 * $1}'`
+#extent2=`echo "$avg_extentN" | awk '{print 2 * $1}'`
+#extent3=`echo "$avg_extentN" | awk '{print 3 * $1}'`
+#extent_frac=`echo "$avg_extentN" | awk '{print 0.005 * $1}'`
+g.message "Preparing map ..."
+r.mapcalc "$TEMP_IMG = $INMAP"
+r.colors $EFLAG "$TEMP_IMG" color=grey --quiet
+if [ $GIS_FLAG_F -eq 1 ] ; then
+ #### flat image ####
+ RENDER_OPTS="resolution_fine=1 perspective=15 twist=180 \
+ position=0.5,0.5 $VLINES $VPOINTS"
+ g.message "Rendering 3D scenes ..."
+ m.nviz.image elevation_map="$TEMP_IMG" output="$TEMPFILE.right" \
+ $RENDER_OPTS size="$SIZE" height="$extent1_45" zexag="$ZEXAG" \
+ surface_position=$extent_frac,0,0 --quiet &
+ m.nviz.image elevation_map="$TEMP_IMG" output="$TEMPFILE.left" \
+ surface_position=-$extent_frac,0,0 --quiet
+ check_ret
+ wait
+else
+ #### 3D relief ####
+ # setup internal region
+ g.region save="tmp_anaglyph.$$"
+ WIND_OVERRIDE="tmp_anaglyph.$$"
+ export WIND_OVERRIDE
+ g.region rast="$TEMP_IMG"
+ # really annoying: Nviz rotates along the shorter of the two axes, so
+ # we have to grow so that the region is taller than it is wide, so that
+ # we don't have to turn our heads sideways to get the 3D effect, and that
+ # the viewpoint doesn't spin out of control at the inflection mid-point.
+ LARGER=`echo "$ew_extent $ns_extent" | awk '{if ($1 > $2) { print "ew" } else { print "ns" }}'`
+ if [ "ew" = "$LARGER" ] ; then
+ BUFDIST=`echo "$ew_extent $ns_extent" | awk '{print int(0.5 + ($1 - $2)/2.0)}'`
+ BUFDIST_EVEN=`echo "$BUFDIST $nsres" | awk '{print $1 + (10 * $2) - ($1 % $2)}'`
+ g.region n="n+$BUFDIST_EVEN" s="s-$BUFDIST_EVEN"
+ fi
+ RENDER_OPTS="resolution_fine=1 perspective=15 $VLINES $VPOINTS"
+ $RENDER_OPTS size="$SIZE" height="$extent1_25" zexag="$ZEXAG" \
+ position=0.52,0.5 twist=90 --quiet &
+ position=0.48,0.5 twist=-90 --quiet
+ check_ret
+ wait
+fi
+BASENM=`basename "$TEMPFILE"`
+# split into R,G,B components
+g.message "Creating anaglyph ..."
+ppmtorgb3 "$BASENM.left.ppm" &
+ppmtorgb3 "$BASENM.right.ppm"
+check_ret
+wait
+rgb3toppm "$BASENM.left.red" "$BASENM.right.grn" "$BASENM.right.blu" \
+ > "$BASENM.anaglyph.ppm"
+check_ret
+pnmtopng "$BASENM.anaglyph.ppm" > "$OLDDIR/$OUTFILE"
+check_ret
+g.message "<$OUTFILE> created."
+cleanup
Property changes on: grass-addons/grass6/display/d.anaglyph/d.anaglyph
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-sh
Added: svn:eol-style
+ native
Copied: grass-addons/grass6/display/d.anaglyph/description.html (from rev 55245, grass-addons/grass6/display/d.barb/description.html)
--- grass-addons/grass6/display/d.anaglyph/description.html (rev 0)
+++ grass-addons/grass6/display/d.anaglyph/description.html 2013-05-29 17:00:41 UTC (rev 56488)
@@ -0,0 +1,61 @@
+<h2>DESCRIPTION</h2>
+<em>d.anaglyph</em> creates a sterographic 3D image suitable for viewing
+with red/cyan glasses. Vector line and point maps may be draped over the
+raster surface.
+<h2>NOTES</h2>
+The NetPBM image manipulation tools are required.
+The output file will be a PNG image.
+<h2>EXAMPLES</h2>
+North Carolina dataset:
+<div class="code"><pre>
+g.region rast=elevation
+d.anaglyph input=elevation output=wake_anaglyph.png size=1280,960 \
+ vlines=roadsmajor vpoints=schools_wake
+</pre></div>
+Spearfish dataset:
+g.region rast=elevation.10m
+d.anaglyph -e input=elevation.10m output=spearfish_anaglyph.png \
+ size=1280,960 z_exag=1.5 vlines=roads vpoints=archsites
+</pre></div>
+<h2>TODO</h2>
+Fine tuning; needs more viewpoint separation when the z-exaggeration is high.
+View is currently limited to top-down.
+<em>m.nviz.image</em> currently Segfaults if more vector maps are passed than
+attributes to go with them. We should fix that so if there are more maps than
+attributes the later maps reuse the attributes of the earlier ones.
+<h2>SEE ALSO</h2>
+<em>
+<a href="m.nviz.image.html">m.nviz.image</a>,
+<a href="nviz.html">NVIZ</a><br>
+</em>
+The <a href="http://grasswiki.osgeo.org/wiki/Stereo_anaglyphs">Stereo anaglyphs</a>
+page on the GRASS Wiki
+<h2>AUTHOR</h2>
+Hamish Bowman<br> <i>
+Department of Geology<br>
+University of Otago<br>
+New Zealand</i><br>
+<br>
+Based on a method by Peter Loewe
+<p>
+<i>Last changed: $Date$</i></p>
