[GRASS-SVN] r56493 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Wed May 29 12:53:39 PDT 2013
Author: mmetz
Date: 2013-05-29 12:53:39 -0700 (Wed, 29 May 2013)
New Revision: 56493
grass/trunk/gui/wxpython/gui_core/dialogs.py
wxGUI: disable nonsense subgroup support, TODO: add subgroup support with name of subgroup
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-05-29 18:08:46 UTC (rev 56492)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-05-29 19:53:39 UTC (rev 56493)
@@ -906,7 +906,8 @@
flag = wx.ALIGN_CENTER_VERTICAL | wx.TOP, border = 10)
self.groupSelect = Select(parent = self, type = 'group',
mapsets = [grass.gisenv()['MAPSET']],
- size = globalvar.DIALOG_GSELECT_SIZE) # searchpath?
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ fullyQualified = False) # searchpath?
bodySizer.Add(item = self.groupSelect, flag = wx.TOP | wx.EXPAND, border = 5)
@@ -937,10 +938,12 @@
bodySizer.Add(item = self.infoLabel,
flag = wx.ALIGN_CENTER_VERTICAL | wx.TOP | wx.BOTTOM, border = 5)
- self.subGroup = wx.CheckBox(parent = self, id = wx.ID_ANY,
- label = _("Define also sub-group (same name as group)"))
- self.subGroup.SetValue(True) # most of imagery modules requires also subgroup
- bodySizer.Add(item = self.subGroup, flag = wx.BOTTOM | wx.EXPAND, border = 5)
+ # TODO: subgroup can have a different name than the group
+ # self.subGroup must be a text field, not a checkbox
+ #self.subGroup = wx.CheckBox(parent = self, id = wx.ID_ANY,
+ # label = _("Define also sub-group (same name as group)"))
+ #self.subGroup.SetValue(True) # most of imagery modules requires also subgroup
+ #bodySizer.Add(item = self.subGroup, flag = wx.BOTTOM | wx.EXPAND, border = 5)
# bindings
self.groupSelect.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnGroupSelected)
@@ -1027,8 +1030,9 @@
remove.append(layerOld)
kwargs = {}
- if self.subGroup.IsChecked():
- kwargs['subgroup'] = group
+ # TODO: self.subGroup must be a text field
+ #if self.subGroup.IsChecked():
+ # kwargs['subgroup'] = group
ret = None
if remove:
@@ -1057,8 +1061,9 @@
return 1
kwargs = {}
return RunCommand('i.group',
parent = self,
@@ -1097,8 +1102,9 @@
"""!Get layers in group"""
kwargs = dict()
kwargs['group'] = group
res = RunCommand('i.group',
parent = self,
