[GRASS-SVN] r56501 - grass/branches/develbranch_6/misc/m.nviz.image
svn_grass at osgeo.org
Wed May 29 22:59:51 PDT 2013
Author: hamish
Date: 2013-05-29 22:59:51 -0700 (Wed, 29 May 2013)
New Revision: 56501
grass/branches/develbranch_6/misc/m.nviz.image/args.c
grass/branches/develbranch_6/misc/m.nviz.image/local_proto.h
grass/branches/develbranch_6/misc/m.nviz.image/vector.c
add a vpoint_mode option to respect 3D map points placement
Modified: grass/branches/develbranch_6/misc/m.nviz.image/args.c
--- grass/branches/develbranch_6/misc/m.nviz.image/args.c 2013-05-29 22:20:25 UTC (rev 56500)
+++ grass/branches/develbranch_6/misc/m.nviz.image/args.c 2013-05-30 05:59:51 UTC (rev 56501)
@@ -339,6 +339,8 @@
params->vline_mode->multiple = YES;
params->vline_mode->description = _("Vector line display mode");
params->vline_mode->options = "surface,flat";
+ params->vline_mode->descriptions = _("surface;drape on raster surface;"
+ "flat;draw at constant elevation");
params->vline_mode->answer = "surface";
params->vline_mode->guisection = _("Vector lines");
@@ -411,6 +413,21 @@
params->vpoint_color->guisection = _("Vector points");
/* point mode */
+ params->vpoint_mode = G_define_option();
+ params->vpoint_mode->key = "vpoint_mode";
+ params->vpoint_mode->key_desc = "string";
+ params->vpoint_mode->type = TYPE_STRING;
+ params->vpoint_mode->required = NO;
+ params->vpoint_mode->multiple = YES;
+ params->vpoint_mode->description = _("Vector point display mode");
+ params->vpoint_mode->options = "surface,3D";
+ params->vpoint_mode->descriptions = _("surface;drape on raster surface;"
+ "3D;place at 3D point's z-elevation");
+ /* TODO: "flat", place at a constant elevation */
+ params->vpoint_mode->answer = "surface";
+ params->vpoint_mode->guisection = _("Vector points");
+ /* point icon type */
params->vpoint_marker = G_define_option();
params->vpoint_marker->key = "vpoint_marker";
params->vpoint_marker->key_desc = "string";
Modified: grass/branches/develbranch_6/misc/m.nviz.image/local_proto.h
--- grass/branches/develbranch_6/misc/m.nviz.image/local_proto.h 2013-05-29 22:20:25 UTC (rev 56500)
+++ grass/branches/develbranch_6/misc/m.nviz.image/local_proto.h 2013-05-30 05:59:51 UTC (rev 56501)
@@ -18,7 +18,8 @@
/* vector lines */
*vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
/* vector points */
- *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
+ *vpoints, *vpoint_size, *vpoint_mode, *vpoint_marker, *vpoint_color,
+ *vpoint_width, *vpoint_pos,
/* volumes */
*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
*isosurf_color_map, *isosurf_color_const, *isosurf_transp_map, *isosurf_transp_const,
Modified: grass/branches/develbranch_6/misc/m.nviz.image/vector.c
--- grass/branches/develbranch_6/misc/m.nviz.image/vector.c 2013-05-29 22:20:25 UTC (rev 56500)
+++ grass/branches/develbranch_6/misc/m.nviz.image/vector.c 2013-05-30 05:59:51 UTC (rev 56501)
@@ -159,6 +159,12 @@
width = atoi(params->vpoint_width->answers[i]);
marker_str = params->vpoint_marker->answers[i];
+ if (strcmp(params->vpoint_mode->answers[i], "3D") == 0)
+ GP_set_zmode(site_list[i], 1); /* respect z-value of 3D points */
+ /* if you pass this a 2D map it drapes on DEM */
+ else
+ GP_set_zmode(site_list[i], 0); /* drape points on raster surface */
if (strcmp(marker_str, "x") == 0)
marker = ST_X;
else if (strcmp(marker_str, "sphere") == 0)
