[GRASS-SVN] r56504 - grass-addons/grass6/display/d.anaglyph
svn_grass at osgeo.org
Wed May 29 23:35:59 PDT 2013
Author: hamish
Date: 2013-05-29 23:35:58 -0700 (Wed, 29 May 2013)
New Revision: 56504
grass-addons/grass6/display/d.anaglyph/d.anaglyph
fix -f, add some vector points controls
Modified: grass-addons/grass6/display/d.anaglyph/d.anaglyph
--- grass-addons/grass6/display/d.anaglyph/d.anaglyph 2013-05-30 06:30:28 UTC (rev 56503)
+++ grass-addons/grass6/display/d.anaglyph/d.anaglyph 2013-05-30 06:35:58 UTC (rev 56504)
@@ -58,6 +58,15 @@
#% answer: 640,480
#%End
#%Option
+#% key: viewing_height
+#% type: double
+#% required: no
+#% multiple: no
+#% key_desc: value
+#% label: Viewing height (map units)
+#% description: default: automatic based on map extent
+#%End
+#%Option
#% key: z_exaggeration
#% type: double
#% required: no
@@ -77,6 +86,29 @@
#% guisection: Vector overlay
#%End
#%Option
+#% key: vpoints_size
+#% type: integer
+#% required: no
+#% multiple: no
+#% options: 1-10000
+#% key_desc: value
+#% description: Icon size (map units)
+#% answer: 100
+#% guisection: Vector overlay
+#%End
+#%Option
+#% key: vpoints_mode
+#% type: string
+#% required: no
+#% multiple: yes
+#% options: surface,3D
+#% key_desc: string
+#% description: Vector points display mode
+#% descriptions: surface;drape on raster surface;3D;place at 3D point's z-elevation
+#% answer: surface
+#%End
+#%Option
#% key: vlines
#% type: string
#% required: no
@@ -128,8 +160,10 @@
g.remove "$TEMP_IMG" --quiet
rm -f "$TEMPFILE" "${TEMPFILE}."*
- unset WIND_OVERRIDE
- g.remove region="tmp_anaglyph.$$" --quiet
+ if [ -n "$WIND_OVERRIDE" ] ; then
+ unset WIND_OVERRIDE
+ g.remove region="tmp_anaglyph.$$" --quiet
+ fi
# what to do in case of user break:
@@ -191,10 +225,18 @@
if [ -n "$GIS_OPT_VPOINTS" ] ; then
VPOINTS="vpoint=$GIS_OPT_VPOINTS vpoint_color=yellow"
+ if [ -n "$GIS_OPT_VPOINTS_SIZE" ] ; then
+ VPOINTS="$VPOINTS vpoint_size=$GIS_OPT_VPOINTS_SIZE"
+ fi
+ if [ -n "$GIS_OPT_VPOINTS_MODE" ] ; then
+ VPOINTS="$VPOINTS vpoint_mode=$GIS_OPT_VPOINTS_MODE"
+ fi
else
VPOINTS=""
fi
if [ -n "$GIS_OPT_VLINES" ] ; then
eval `g.region -g`
VLINES="vline=$GIS_OPT_VLINES vline_color=black vline_height=$nsres"
@@ -220,7 +262,7 @@
extent1_45=`echo "$avg_extentN" | awk '{print 1.45 * $1}'`
#extent2=`echo "$avg_extentN" | awk '{print 2 * $1}'`
#extent3=`echo "$avg_extentN" | awk '{print 3 * $1}'`
-#extent_frac=`echo "$avg_extentN" | awk '{print 0.005 * $1}'`
+extent_frac=`echo "$avg_extentN" | awk '{print 0.005 * $1}'`
g.message "Preparing map ..."
@@ -230,24 +272,36 @@
if [ $GIS_FLAG_F -eq 1 ] ; then
#### flat image ####
+ if [ -n "$GIS_OPT_VIEWING_HEIGHT" ] ; then
+ height="$GIS_OPT_VIEWING_HEIGHT"
+ else
+ height="$extent1_45"
+ fi
+ g.message "Viewing height: $height `g.proj -g | grep units | cut -f2- -d=`"
RENDER_OPTS="resolution_fine=1 perspective=15 twist=180 \
- position=0.5,0.5 $VLINES $VPOINTS"
+ position=0.5,0.5 bgcolor=black $VLINES $VPOINTS"
g.message "Rendering 3D scenes ..."
m.nviz.image elevation_map="$TEMP_IMG" output="$TEMPFILE.right" \
- $RENDER_OPTS size="$SIZE" height="$extent1_45" zexag="$ZEXAG" \
- surface_position=$extent_frac,0,0 --quiet &
+ $RENDER_OPTS size="$SIZE" height="$height" zexag="$ZEXAG" \
+ surface_position="$extent_frac,0,0" --quiet &
m.nviz.image elevation_map="$TEMP_IMG" output="$TEMPFILE.left" \
- surface_position=-$extent_frac,0,0 --quiet
+ surface_position="-$extent_frac,0,0" --quiet
check_ret
wait
else
#### 3D relief ####
+ else
+ height="$extent1_25"
+ fi
# setup internal region
g.region save="tmp_anaglyph.$$"
@@ -267,16 +321,16 @@
g.region n="n+$BUFDIST_EVEN" s="s-$BUFDIST_EVEN"
fi
- RENDER_OPTS="resolution_fine=1 perspective=15 $VLINES $VPOINTS"
+ RENDER_OPTS="resolution_fine=1 perspective=15 bgcolor=black $VLINES $VPOINTS"
- $RENDER_OPTS size="$SIZE" height="$extent1_25" zexag="$ZEXAG" \
position=0.52,0.5 twist=90 --quiet &
position=0.48,0.5 twist=-90 --quiet
check_ret
