[GRASS-SVN] r56506 - grass/branches/develbranch_6/misc/m.nviz.image
svn_grass at osgeo.org
Thu May 30 01:49:30 PDT 2013
Author: hamish
Date: 2013-05-30 01:49:29 -0700 (Thu, 30 May 2013)
New Revision: 56506
grass/branches/develbranch_6/misc/m.nviz.image/vector.c
avoid some segfaults (but not others) if multiple maps are defined but not attrs to go along with them. in that case just repeat what the last map did. e.g. 7 point maps, all as red dots. (not needed in trunk AFAICT, stricter parser limits there disallow this situation/shortcut)
Modified: grass/branches/develbranch_6/misc/m.nviz.image/vector.c
--- grass/branches/develbranch_6/misc/m.nviz.image/vector.c 2013-05-30 08:24:06 UTC (rev 56505)
+++ grass/branches/develbranch_6/misc/m.nviz.image/vector.c 2013-05-30 08:49:29 UTC (rev 56506)
@@ -57,14 +57,13 @@
const struct Option *position,
int map_obj_type, nv_data * data)
- int i, id;
- int nvects;
+ int i, j, id;
+ int nvects, num_with_posn;
char *mapset;
double x, y, z;
- if ((!elev_map->answer || elev_const->answer) && GS_num_surfs() == 0) { /* load base surface if no loaded */
+ /* load base surface if none is loaded */
+ if ((!elev_map->answer || elev_const->answer) && GS_num_surfs() == 0) {
int *surf_list, nsurf;
Nviz_new_map_obj(MAP_OBJ_SURF, NULL, 0.0, data);
@@ -74,8 +73,13 @@
nvects = 0;
+ x = y = z = 0.0;
+ for (j = 0; position->answers[j]; j++) ;
+ num_with_posn = j / 3;
for (i = 0; vect->answers[i]; i++) {
+ G_debug(3, "loading [%s] ... i=%d", vect->answers[i], i);
mapset = G_find_vector2(vect->answers[i], "");
if (mapset == NULL) {
G_fatal_error(_("Vector map <%s> not found"), vect->answers[i]);
@@ -85,9 +89,14 @@
0.0, data);
/* set position */
- x = atof(position->answers[i*3+0]);
- y = atof(position->answers[i*3+1]);
- z = atof(position->answers[i*3+2]);
+ if(i+1 <= num_with_posn) {
+ if (position->answers[i*3+0])
+ x = atof(position->answers[i*3+0]);
+ if (position->answers[i*3+1])
+ y = atof(position->answers[i*3+1]);
+ if (position->answers[i*3+2])
+ z = atof(position->answers[i*3+2]);
if (map_obj_type == MAP_OBJ_VECT)
GV_set_trans(id, x, y, z);
@@ -117,17 +126,23 @@
for (i = 0; i < nvects; i++) {
/* mode -- use memory by default */
- color = Nviz_color_from_str(params->vline_color->answers[i]);
- width = atoi(params->vline_width->answers[i]);
- if (strcmp(params->vline_mode->answers[i], "flat") == 0)
- flat = 1;
- else
- flat = 0;
+ if (params->vline_color->answers[i])
+ color = Nviz_color_from_str(params->vline_color->answers[i]);
+ if (params->vline_width->answers[i])
+ width = atoi(params->vline_width->answers[i]);
+ if (params->vline_mode->answers[i]) {
+ if (strcmp(params->vline_mode->answers[i], "flat") == 0)
+ flat = 1;
+ else
+ flat = 0;
if (GV_set_vectmode(vect_list[i], 1, color, width, flat) < 0)
return 0;
/* height */
- height = atoi(params->vline_height->answers[i]);
+ if (params->vline_height->answers[i])
+ height = atoi(params->vline_height->answers[i]);
if (height > 0)
GV_set_trans(vect_list[i], 0.0, 0.0, height);
@@ -147,23 +162,33 @@
int i;
int *site_list, nsites;
- int marker, color, width;
+ int marker, color, width, do_3d;
float size;
char *marker_str;
site_list = GP_get_site_list(&nsites);
for (i = 0; i < nsites; i++) {
- color = Nviz_color_from_str(params->vpoint_color->answers[i]);
- size = atof(params->vpoint_size->answers[i]);
- width = atoi(params->vpoint_width->answers[i]);
- marker_str = params->vpoint_marker->answers[i];
+ if (params->vpoint_color->answers[i])
+ color = Nviz_color_from_str(params->vpoint_color->answers[i]);
+ if (params->vpoint_size->answers[i])
+ size = atof(params->vpoint_size->answers[i]);
+ if (params->vpoint_width->answers[i])
+ width = atoi(params->vpoint_width->answers[i]);
+ if (params->vpoint_marker->answers[i])
+ marker_str = params->vpoint_marker->answers[i];
+ if (params->vpoint_mode->answers[i]) {
+ if (strcmp(params->vpoint_mode->answers[i], "3D") == 0)
+ do_3d = TRUE; /* respect z-value of 3D points */
+ /* if you pass this a 2D map it drapes on DEM */
+ else
+ do_3d = FALSE; /* drape points on raster surface */
- if (strcmp(params->vpoint_mode->answers[i], "3D") == 0)
- GP_set_zmode(site_list[i], 1); /* respect z-value of 3D points */
- /* if you pass this a 2D map it drapes on DEM */
+ if(do_3d)
+ GP_set_zmode(site_list[i], 1);
else
- GP_set_zmode(site_list[i], 0); /* drape points on raster surface */
+ GP_set_zmode(site_list[i], 0);
if (strcmp(marker_str, "x") == 0)
marker = ST_X;
