[GRASS-SVN] r58138 - grass/trunk/gui/wxpython/lmgr
Sat Nov 2 05:41:48 PDT 2013
Author: annakrat
Date: 2013-11-02 05:41:48 -0700 (Sat, 02 Nov 2013)
New Revision: 58138
   grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI: fix wrong order of layers when reading from workspace file
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2013-11-01 12:42:50 UTC (rev 58137)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2013-11-02 12:41:48 UTC (rev 58138)
@@ -1164,16 +1164,16 @@
             displayId += 1
             mapdisp.Show() # show mapdisplay
-        maptree = None
-        selected = [] # list of selected layers
+        maptree = None
+        selectList = []  # list of selected layers
         # load list of map layers
         for layer in gxwXml.layers:
             display = layer['display']
             maptree = self.notebookLayers.GetPage(display).maptree
             newItem = maptree.AddLayer(ltype = layer['type'],
                                        lname = layer['name'],
                                        lchecked = layer['checked'],
@@ -1182,17 +1182,17 @@
                                        lgroup = layer['group'],
                                        lnviz = layer['nviz'],
                                        lvdigit = layer['vdigit'])
-            if layer.has_key('selected'):
-                if layer['selected']:
-                    selected.append((maptree, newItem))
-                else:
-                    maptree.SelectItem(newItem, select = False)
-        for maptree, layer in selected:
-            if not maptree.IsSelected(layer):
-                maptree.SelectItem(layer, select = True)
+            if 'selected' in layer:
+                selectList.append((maptree, newItem, layer['selected']))
+        for maptree, layer, selected in selectList:
+            if selected:
+                if not layer.IsSelected():
+                    maptree.SelectItem(layer, select=True)
+            else:
+                maptree.SelectItem(layer, select=False)
         busy.Destroy()
         for idx, mdisp in enumerate(mapdisplay):
