[GRASS-SVN] r58140 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Sat Nov 2 12:40:36 PDT 2013
Author: hcho
Date: 2013-11-02 12:40:36 -0700 (Sat, 02 Nov 2013)
New Revision: 58140
grass/trunk/raster/r.topmodel/infiltration.c
grass/trunk/raster/r.topmodel/topmodel.c
variables renamed
Modified: grass/trunk/raster/r.topmodel/infiltration.c
--- grass/trunk/raster/r.topmodel/infiltration.c 2013-11-02 13:56:29 UTC (rev 58139)
+++ grass/trunk/raster/r.topmodel/infiltration.c 2013-11-02 19:40:36 UTC (rev 58140)
@@ -6,9 +6,9 @@
/* The Green-and-Ampt Model */
double calculate_infiltration(int timestep, double R)
- static double cumf = 0.0, f_ = 0.0;
+ static double cumf = 0.0, f = 0.0;
static char ponding = 0;
- double t, f, f1, f2, fc, R2, cnst, pt, psi_dtheta, sum;
+ double t, df, f1, f2, fc, R2, cnst, pt, psi_dtheta, sum;
int factorial;
int i, j;
@@ -16,7 +16,7 @@
/* reset if there is no rainfall */
if (R <= 0.0) {
cumf = 0.0;
- f_ = 0.0;
+ f = 0.0;
ponding = 0;
return 0.0;
@@ -32,7 +32,7 @@
/* rainfall intensity is greater than infiltration
* rate, so ponding starts */
if (R2 < R) {
- f_ = cumf;
+ f = cumf;
pt = t - input.dt;
ponding = 1;
goto cont1;
@@ -45,57 +45,57 @@
/* rainfall intensity is less than infiltration rate. all
* rainfall will be infiltrated. */
if (f2 == 0.0 || R2 > R) {
- f = R;
- cumf += f * input.dt;
+ df = R;
+ cumf += df * input.dt;
ponding = 0;
- return f;
+ return df;
/* rainfall intensity is greater than infiltration rate. */
- f_ = cumf + R2 * input.dt;
+ f = cumf + R2 * input.dt;
for (i = 0; i < MAXITER; i++) {
R2 = -params.K0 / params.m *
- (psi_dtheta + f_) / (1 - exp(f_ / params.m));
+ (psi_dtheta + f) / (1 - exp(f / params.m));
if (R2 > R) {
- f1 = f_;
- f_ = (f_ + f2) / 2.0;
- f = f_ - f1;
+ f1 = f;
+ f = (f + f2) / 2.0;
+ df = f - f1;
else {
- f2 = f_;
- f_ = (f_ + f1) / 2.0;
- f = f_ - f2;
+ f2 = f;
+ f = (f + f1) / 2.0;
+ df = f - f2;
- if (fabs(f) < TOLERANCE)
+ if (fabs(df) < TOLERANCE)
break;
if (i == MAXITER)
G_warning(
- _("Maximum number of iterations exceeded at timestep %d!"),
+ _("Maximum number of iterations exceeded at timestep %d."),
timestep);
- pt = t - input.dt + (f_ - cumf) / R;
+ pt = t - input.dt + (f - cumf) / R;
if (pt > t) {
- f = R;
+ df = R;
ponding = 0;
- return f;
+ return df;
cont1:
cnst = 0.0;
factorial = 1;
- fc = (f_ + psi_dtheta);
+ fc = f + psi_dtheta;
for (j = 1; j <= NTERMS; j++) {
factorial *= j;
cnst += pow(fc / params.m, (double)j) / (double)(j * factorial);
cnst = log(fc) - (log(fc) + cnst) / exp(psi_dtheta / params.m);
- f_ += R * (t - pt) / 2.0;
+ f += R * (t - pt) / 2.0;
ponding = 1;
/* Newton-Raphson */
- fc = f_ + psi_dtheta;
sum = 0.0;
factorial = 1;
@@ -105,23 +105,23 @@
f1 = -(log(fc) - (log(fc) + sum) /
exp(psi_dtheta / params.m) - cnst) /
(params.K0 / params.m) - (t - pt);
- f2 = (exp(f_ / params.m) - 1.0) / (fc * params.K0 / params.m);
- f = -f1 / f2;
- f_ += f;
+ f2 = (exp(f / params.m) - 1.0) / (fc * params.K0 / params.m);
+ df = -f1 / f2;
+ f += df;
+ if (fabs(df) <= TOLERANCE)
break;
if (i == MAXITER)
- G_warning(_("Maximum number of iterations exceeded at timestep %d!"),
+ G_warning(_("Maximum number of iterations exceeded at timestep %d."),
timestep);
- if (f_ < cumf + R * input.dt) {
- f = (f_ - cumf) / input.dt;
- cumf = f_;
+ if (f < cumf + R * input.dt) {
+ df = (f - cumf) / input.dt;
+ cumf = f;
/* initial guess for next time step */
- f_ += f * input.dt;
+ f += df * input.dt;
- return f;
+ return df;
Modified: grass/trunk/raster/r.topmodel/topmodel.c
--- grass/trunk/raster/r.topmodel/topmodel.c 2013-11-02 13:56:29 UTC (rev 58139)
+++ grass/trunk/raster/r.topmodel/topmodel.c 2013-11-02 19:40:36 UTC (rev 58140)
@@ -285,7 +285,7 @@
denominator += pow(misc.Qobs[i] - misc.Qobs_mean, 2.0);
if (denominator == 0.0) {
- G_warning("Em can not be resolved due to constant " "observed Q");
+ G_warning("Em can not be resolved due to constant observed Q");
Rast_set_d_null_value(&Em, 1);
else {
