[GRASS-SVN] r58154 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Nov 6 05:17:27 PST 2013
Author: lucadelu
Date: 2013-11-06 05:17:27 -0800 (Wed, 06 Nov 2013)
New Revision: 58154
grass/trunk/lib/python/temporal/univar_statistics.py
replace print with string variable and only at the end print the string
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2013-11-06 12:44:00 UTC (rev 58153)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2013-11-06 13:17:27 UTC (rev 58154)
@@ -57,18 +57,19 @@
'sp': sp.get_new_map_instance(None).get_type(), 'i': id})
if header == True:
- print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + \
- "min" + fs + "max" + fs,
- print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
+ string = ""
+ string += "id" + fs + "start" + fs + "end" + fs + "mean" + fs
+ string += "min" + fs + "max" + fs
+ string += "mean_of_abs" + fs + "stddev" + fs + "variance" + fs
+ string += "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells"
if extended == True:
- print "coeff_var" + fs + "sum" + fs + \
- "null_cells" + fs + "cells" + fs,
- print "first_quartile" + fs + "median" + fs + \
- "third_quartile" + fs + "percentile_90"
- else:
- print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells"
+ string += "first_quartile" + fs + "median" + fs
+ string += "third_quartile" + fs + "percentile_90"
+ print string
for row in rows:
+ string = ""
id = row["id"]
start = row["start_time"]
end = row["end_time"]
@@ -83,21 +84,17 @@
elif type == "str3ds":
stats = core.parse_command("r3.univar", map=id, flags=flag)
- print str(id) + fs + str(start) + fs + str(end),
- print fs + str(stats["mean"]) + fs + str(stats["min"]) + \
- fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
- print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + \
- fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
+ string += str(id) + fs + str(start) + fs + str(end)
+ string += fs + str(stats["mean"]) + fs + str(stats["min"])
+ string += fs + str(stats["max"]) + fs + str(stats["mean_of_abs"])
+ string += fs + str(stats["stddev"]) + fs + str(stats["variance"])
+ string += fs + str(stats["coeff_var"]) + fs + str(stats["sum"])
+ string += fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs
+ if extended == True:
+ string += str(stats["first_quartile"]) + fs + str(stats["median"])
+ string += fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
+ print string
- if extended == True:
- print fs + str(stats["null_cells"]) + fs + str(
- stats["cells"]) + fs,
- print str(stats["first_quartile"]) + fs + str(stats["median"]) + \
- fs + str(stats["third_quartile"]) + \
- fs + str(stats["percentile_90"])
- else:
- print fs + str(stats["null_cells"]) + fs + str(stats["cells"])
dbif.close()
