[GRASS-SVN] r58182 - grass/trunk/gui/wxpython/animation
svn_grass at osgeo.org
Sat Nov 9 20:00:04 PST 2013
Author: annakrat
Date: 2013-11-09 20:00:04 -0800 (Sat, 09 Nov 2013)
New Revision: 58182
grass/trunk/gui/wxpython/animation/controller.py
grass/trunk/gui/wxpython/animation/dialogs.py
wxGUI/animations: use new grass.imaging lib for exporting animations
Modified: grass/trunk/gui/wxpython/animation/controller.py
--- grass/trunk/gui/wxpython/animation/controller.py 2013-11-10 03:58:13 UTC (rev 58181)
+++ grass/trunk/gui/wxpython/animation/controller.py 2013-11-10 04:00:04 UTC (rev 58182)
@@ -16,20 +16,9 @@
import os
import wx
-try:
- import visvis.vvmovie as vv
- hasVisvis = True
-except ImportError:
- # if visvis.vvmovie is in grass python library
- # import grass.visvis as vv
- # question: if integrate visvis, if integrate visvis.vvmovie or only
- # images2swf.py, images2gif.py?
- hasVisvis = False
from core.gcmd import GException, GError, GMessage
from core.utils import _
-import grass.script as grass
+from grass.imaging import writeAvi, writeGif, writeIms, writeSwf
from temporal_manager import TemporalManager
from dialogs import InputDialog, EditDialog, AnimationData, ExportDialog
@@ -472,7 +461,7 @@
self._dialogs['export'].Raise()
else:
dlg = ExportDialog(self.frame, temporal=self.temporalMode,
- timeTick=self.timeTick, visvis=hasVisvis)
+ timeTick=self.timeTick)
dlg.doExport.connect(self._export)
self._dialogs['export'] = dlg
dlg.Show()
@@ -549,56 +538,32 @@
del busy
# export
- if exportInfo['method'] == 'sequence':
- busy = wx.BusyInfo(message = _("Exporting images, please wait..."), parent = self.frame)
- wx.Yield()
- zeroPadding = len(str(len(images)))
- for i, image in enumerate(images):
- filename = "%s_%s.%s" % (exportInfo['prefix'], str(i + 1).zfill(zeroPadding),
- exportInfo['format']['ext'])
- image.SaveFile(os.path.join(exportInfo['directory'], filename), exportInfo['format']['type'])
+ pilImages = [WxImageToPil(image) for image in images]
+ busy = wx.BusyInfo(message=_("Exporting animation, please wait..."),
+ parent=self.frame)
+ wx.Yield()
+ try:
+ if exportInfo['method'] == 'sequence':
+ filename = os.path.join(exportInfo['directory'],
+ exportInfo['prefix'] + '.' + exportInfo['format'].lower())
+ writeIms(filename=filename, images=pilImages)
+ elif exportInfo['method'] == 'gif':
+ writeGif(filename=exportInfo['file'], images=pilImages,
+ duration=self.timeTick / float(1000), repeat=True)
+ elif exportInfo['method'] == 'swf':
+ writeSwf(filename=exportInfo['file'], images=pilImages,
+ elif exportInfo['method'] == 'avi':
+ writeAvi(filename=exportInfo['file'], images=pilImages,
+ encoding=exportInfo['encoding'],
+ inputOptions='-sameq')
+ except Exception, e:
del busy
+ GError(parent=self.frame, message=str(e))
+ return
+ del busy
- elif exportInfo['method'] in ('gif', 'swf', 'avi'):
- pilImages = [WxImageToPil(image) for image in images]
- busy = wx.BusyInfo(message = _("Exporting animation, please wait..."), parent = self.frame)
- wx.Yield()
- try:
- if exportInfo['method'] == 'gif':
- vv.writeGif(filename = exportInfo['file'], images = pilImages,
- duration = self.timeTick / float(1000), repeat = True)
- elif exportInfo['method'] == 'swf':
- vv.writeSwf(filename = exportInfo['file'], images = pilImages,
- elif exportInfo['method'] == 'avi':
- vv.writeAvi(filename = exportInfo['file'], images = pilImages,
- encoding = exportInfo['encoding'],
- inputOptions = '-sameq')
- except Exception, e:
- del busy
- GError(parent = self.frame, message = str(e))
- return
- del busy
- # image.SaveFile('/home/anna/testy/grass/export/export_%s.png' % frameIndex, wx.BITMAP_TYPE_PNG)
- # for anim in self.animationData
#def test():
# import grass.script as grass
# import wx
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2013-11-10 03:58:13 UTC (rev 58181)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2013-11-10 04:00:04 UTC (rev 58182)
@@ -846,14 +846,13 @@
class ExportDialog(wx.Dialog):
- def __init__(self, parent, temporal, timeTick, visvis):
+ def __init__(self, parent, temporal, timeTick):
wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = _("Export animation"),
style = wx.DEFAULT_DIALOG_STYLE)
self.decorations = []
self.temporal = temporal
self.timeTick = timeTick
- self.visvis = visvis
self._layout()
# export animation
@@ -1006,18 +1005,8 @@
panel = wx.Panel(notebook, id = wx.ID_ANY)
borderSizer = wx.BoxSizer(wx.VERTICAL)
- if not self.visvis:
- isVisvisText = wx.StaticText(panel, id = wx.ID_ANY,
- label = _("To enable export to GIF and SWF, please install visvis library."))
- isVisvisText.Wrap(400)
- borderSizer.Add(item = isVisvisText, proportion = 0,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND | wx.ALL, border = 5)
hSizer = wx.BoxSizer(wx.HORIZONTAL)
- choices = [_("image sequence")]
- else:
- choices = [_("image sequence"), _("animated GIF"), _("SWF"), _("AVI")]
+ choices = [_("image sequence"), _("animated GIF"), _("SWF"), _("AVI")]
self.formatChoice = wx.Choice(parent = panel, id = wx.ID_ANY,
choices = choices)
self.formatChoice.Bind(wx.EVT_CHOICE, lambda event: self.ChangeFormat(event.GetSelection()))
@@ -1037,13 +1026,10 @@
# panel for image sequence
imSeqPanel = wx.Panel(parent = panel, id = wx.ID_ANY)
prefixLabel = wx.StaticText(imSeqPanel, id = wx.ID_ANY, label = _("File prefix:"))
- self.prefixCtrl = wx.TextCtrl(imSeqPanel, id = wx.ID_ANY, value = _("animation"))
+ self.prefixCtrl = wx.TextCtrl(imSeqPanel, id = wx.ID_ANY, value = _("animation_"))
formatLabel = wx.StaticText(imSeqPanel, id = wx.ID_ANY, label = _("File format:"))
- self.imSeqFormatChoice = wx.Choice(imSeqPanel, id = wx.ID_ANY)
- wildcard, ltype = GetImageHandlers(wx.EmptyImage(10, 10))
- formats = [format for format in wildcard.split('|') if 'file' in format]
- for format, cdata in zip(formats, ltype):
- self.imSeqFormatChoice.Append(format, cdata)
+ imageTypes = ['PNG', 'JPEG', 'GIF', 'TIFF', 'PPM', 'BMP']
+ self.imSeqFormatChoice = wx.Choice(imSeqPanel, choices=imageTypes)
self.imSeqFormatChoice.SetSelection(0)
self.dirBrowse = filebrowse.DirBrowseButton(parent = imSeqPanel, id = wx.ID_ANY,
labelText = _("Directory:"),
@@ -1277,7 +1263,7 @@
info['method'] = 'sequence'
info['directory'] = self.dirBrowse.GetValue()
info['prefix'] = self.prefixCtrl.GetValue()
- info['format'] = self.imSeqFormatChoice.GetClientData(self.imSeqFormatChoice.GetSelection())
+ info['format'] = self.imSeqFormatChoice.GetStringSelection()
elif self.formatChoice.GetSelection() == 1:
info['method'] = 'gif'
