[GRASS-SVN] r58185 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Sun Nov 10 04:31:13 PST 2013
Author: martinl
Date: 2013-11-10 04:31:13 -0800 (Sun, 10 Nov 2013)
New Revision: 58185
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gmodeler/frame.py
wxGUI/gmodeler: fix defining items in the loop (including order change)
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-11-10 06:16:40 UTC (rev 58184)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-11-10 12:31:13 UTC (rev 58185)
@@ -408,10 +408,11 @@
value = shape.GetText())
self.itemList = ItemCheckListCtrl(parent = self.panel,
- window = self,
columns = [_("Name"),
_("Command")],
- shape = shape)
+ shape = shape,
+ frame = parent)
self.itemList.Populate(self.parent.GetModel().GetItems())
self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
@@ -582,7 +583,7 @@
listmix.ListCtrlAutoWidthMixin,
# listmix.TextEditMixin,
listmix.ColumnSorterMixin):
- def __init__(self, parent, columns, id = wx.ID_ANY,
+ def __init__(self, parent, columns, frame, id = wx.ID_ANY,
style = wx.LC_REPORT | wx.BORDER_NONE |
wx.LC_SORT_ASCENDING |wx.LC_HRULES |
wx.LC_VRULES, **kwargs):
@@ -590,10 +591,7 @@
self.parent = parent
self.columns = columns
self.shape = None
- try:
- self.frame = parent.parent
- except AttributeError:
- self.frame = None
+ self.frame = frame
wx.ListCtrl.__init__(self, parent, id = id, style = style, **kwargs)
listmix.ListCtrlAutoWidthMixin.__init__(self)
@@ -755,11 +753,11 @@
menu.Destroy()
class ItemListCtrl(ModelListCtrl):
- def __init__(self, parent, columns, disablePopup = False, **kwargs):
+ def __init__(self, parent, columns, frame, disablePopup = False, **kwargs):
"""!List of model actions"""
self.disablePopup = disablePopup
- ModelListCtrl.__init__(self, parent, columns, **kwargs)
+ ModelListCtrl.__init__(self, parent, columns, frame, **kwargs)
self.SetColumnWidth(1, 100)
self.SetColumnWidth(2, 65)
@@ -782,7 +780,8 @@
else:
shapeItems = map(lambda x: x.GetId(), self.shape.GetItems()['if'])
else:
- shapeItems = map(lambda x: x.GetId(), self.shape.GetItems())
+ shapeItems = map(lambda x: x.GetId(),
+ self.shape.GetItems(self.frame.GetModel().GetItems(objType=ModelAction)))
else:
shapeItems = list()
@@ -930,11 +929,12 @@
self.Populate(model.GetItems(objType=ModelAction))
class ItemCheckListCtrl(ItemListCtrl, listmix.CheckListCtrlMixin):
- def __init__(self, parent, shape, columns, window = None, **kwargs):
+ def __init__(self, parent, shape, columns, frame, **kwargs):
- self.window = window
- ItemListCtrl.__init__(self, parent, columns, disablePopup = True, **kwargs)
+ ItemListCtrl.__init__(self, parent, columns, frame,
+ disablePopup = True, **kwargs)
listmix.CheckListCtrlMixin.__init__(self)
self.SetColumnWidth(0, 100)
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2013-11-10 06:16:40 UTC (rev 58184)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2013-11-10 12:31:13 UTC (rev 58185)
@@ -1122,16 +1122,17 @@
dlg.CentreOnParent()
if dlg.ShowModal() == wx.ID_OK:
shape.SetText(dlg.GetCondition())
+ model = self.frame.GetModel()
+ ids = dlg.GetItems()
alist = list()
- ids = dlg.GetItems()
for aId in ids['unchecked']:
- action = self.frame.GetModel().GetItem(aId)
+ action = model.GetItem(aId, objType=ModelAction)
action.UnSetBlock(shape)
for aId in ids['checked']:
action.SetBlock(shape)
if action:
- alist.append(action)
+ alist.append(aId)
shape.SetItems(alist)
self.frame.DefineLoop(shape)
self.frame.SetStatusText(shape.GetLog(), 0)
@@ -1145,18 +1146,17 @@
- modelActions = model.GetItems(objType=ModelAction)
for b in ids.keys():
alist = list()
- for idx in ids[b]['unchecked']:
- action = modelActions[idx]
+ for aId in ids[b]['unchecked']:
- for idx in ids[b]['checked']:
+ for aId in ids[b]['checked']:
if action:
+ alist.append(aId)
shape.SetItems(alist, branch = b)
self.frame.DefineCondition(shape)
self.frame.GetCanvas().Refresh()
@@ -1328,7 +1328,8 @@
self.list = VariableListCtrl(parent = self,
columns = [_("Name"), _("Data type"),
- _("Default value"), _("Description")])
+ _("Default value"), _("Description")],
+ frame = self.parent)
# add new category
self.addBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
@@ -1473,7 +1474,8 @@
self.list = ItemListCtrl(parent = self,
columns = [_("Name"), _("In loop"),
- _("Command")])
+ _("Command")],
self.btnMoveUp = wx.Button(parent=self, id=wx.ID_UP)
self.btnMoveDown = wx.Button(parent=self, id=wx.ID_DOWN)
