[GRASS-SVN] r58200 - in grass/trunk/lib: init python/script
svn_grass at osgeo.org
Tue Nov 12 05:49:11 PST 2013
Author: martinl
Date: 2013-11-12 05:49:10 -0800 (Tue, 12 Nov 2013)
New Revision: 58200
grass/trunk/lib/init/grass.py
grass/trunk/lib/python/script/core.py
attemt to fix failure when user name contains non-ascii characters
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2013-11-12 02:30:59 UTC (rev 58199)
+++ grass/trunk/lib/init/grass.py 2013-11-12 13:49:10 UTC (rev 58200)
@@ -33,6 +33,8 @@
import re
import platform
import tempfile
+import codecs
+import locale
# Variables substituted during build process
if 'GISBASE' in os.environ:
@@ -135,15 +137,24 @@
sys.stderr.flush()
+def openfile(path, mode='r'):
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ f = codecs.open(path, encoding=enc, mode=mode)
+ else:
+ f = open(path, mode)
+ return f
def readfile(path):
- f = open(path, 'r')
+ f = openfile(path, 'r')
s = f.read()
f.close()
return s
def writefile(path, s):
- f = open(path, 'w')
+ f = openfile(path, 'w')
f.write(s)
f.close()
@@ -238,6 +249,7 @@
tmp = os.getenv('TMP')
if not tmp:
tmp = tempfile.gettempdir()
if tmp:
tmpdir = os.path.join(tmp, "grass7-%(user)s-%(lock)s" % {'user': user,
'lock': gis_lock})
@@ -265,7 +277,11 @@
global gisrc, gisrcrc
# Set the session grassrc file
gisrc = os.path.join(tmpdir, "gisrc")
- os.environ['GISRC'] = gisrc
+ if enc:
+ os.environ['GISRC'] = gisrc.encode(enc)
+ else:
# remove invalid GISRC file to avoid disturbing error messages:
try:
@@ -284,7 +300,7 @@
def read_gisrc():
kv = {}
try:
- f = open(gisrc, 'r')
+ f = openfile(gisrc, 'r')
except IOError:
return kv
@@ -298,7 +314,7 @@
def read_env_file(path):
kv = {}
for line in f:
k, v = line.split(':', 1)
kv[k.strip()] = v.strip()
@@ -307,7 +323,7 @@
def write_gisrc(kv):
- f = open(gisrc, 'w')
+ f = openfile(gisrc, 'w')
for k, v in kv.iteritems():
f.write("%s: %s\n" % (k, v))
f.close()
@@ -819,6 +835,10 @@
# Check for concurrent use
lockfile = os.path.join(location, ".gislock")
+ if enc:
+ lockfile = lockfile.encode(enc)
ret = call([gfile("etc", "lock"), lockfile, "%d" % os.getpid()])
if ret == 0:
msg = None
@@ -989,7 +1009,7 @@
try_remove(cshrc)
try_remove(tcshrc)
- f = open(cshrc, 'w')
+ f = openfile(cshrc, 'w')
f.write("set home = %s\n" % userhome)
f.write("set history = 3000 savehist = 3000 noclobber ignoreeof\n")
f.write("set histfile = %s\n" % os.path.join(os.getenv('HOME'),
@@ -1046,7 +1066,7 @@
bashrc = os.path.join(home, ".bashrc")
try_remove(bashrc)
- f = open(bashrc, 'w')
+ f = openfile(bashrc, 'w')
f.write("test -r ~/.alias && . ~/.alias\n")
if os.getenv('ISISROOT'):
f.write("PS1='ISIS-GRASS %s (%s):\w > '\n" % (grass_version, location_name))
@@ -1115,7 +1135,7 @@
def print_params():
plat = gfile(gisbase, 'include', 'Make', 'Platform.make')
- fileplat = open(plat)
+ fileplat = openfile(plat, 'r')
linesplat = fileplat.readlines()
fileplat.close()
@@ -1131,7 +1151,7 @@
sys.stdout.write("%s\n" % val[0].split('=')[1].strip())
elif arg == 'build':
build = os.path.join(gisbase,'include','grass','confparms.h')
- filebuild = open(build)
+ filebuild = openfile(build, 'r')
val = filebuild.readline()
filebuild.close()
sys.stdout.write("%s\n" % val.strip().strip('"').strip())
@@ -1140,7 +1160,7 @@
elif arg == 'revision':
rev = os.path.join(gisbase,'include','grass','gis.h')
- filerev = open(rev)
+ filerev = openfile(rev, 'r')
linesrev = filerev.readlines()
val = grep('#define GIS_H_VERSION', linesrev)
filerev.close()
@@ -1169,6 +1189,10 @@
pass
if not user:
user = "user_%d" % os.getuid()
+ if enc:
+ user = user.decode(enc)
def parse_cmdline():
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2013-11-12 02:30:59 UTC (rev 58199)
+++ grass/trunk/lib/python/script/core.py 2013-11-12 13:49:10 UTC (rev 58200)
@@ -88,7 +88,13 @@
return string
+def encode(string):
+ if enc:
+ return string.encode(enc)
+ return string
def _make_val(val):
if isinstance(val, types.StringType) or \
isinstance(val, types.UnicodeType):
@@ -324,6 +330,8 @@
if opt in _popen_args:
popts[opt] = val
else:
+ if isinstance(val, unicode):
+ val = encode(val)
options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
