[GRASS-SVN] r58208 - in grass-addons/grass7/raster/r.modis: r.modis.download r.modis.import
svn_grass at osgeo.org
Wed Nov 13 08:04:05 PST 2013
Author: wenzeslaus
Date: 2013-11-13 08:04:04 -0800 (Wed, 13 Nov 2013)
New Revision: 58208
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis: using get_lib_path function to find the library
tested for r.modis modules installed as addons with r.modis/r.modis directory in GRASS_ADDON_BASE
before r.modis.download was able to start but r.modis.import was not
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2013-11-13 09:59:08 UTC (rev 58207)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2013-11-13 16:04:04 UTC (rev 58208)
@@ -81,34 +81,18 @@
import sys
from datetime import *
import grass.script as grass
+from grass.pygrass.functions import get_lib_path
-# add the folder containing libraries to python path
-libmodis = None
-if os.path.isdir(os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')):
- libmodis = os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')
-elif os.getenv('GRASS_ADDON_BASE') and \
- os.path.isdir(os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc',
- 'r.modis')):
- libmodis = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc', 'r.modis')
- os.path.isdir(os.path.join(os.getenv('GRASS_ADDON_BASE'), 'r.modis',
- 'r.modis')):
- libmodis = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'r.modis',
- 'r.modis')
-elif os.path.isdir(os.path.join('..', 'libmodis')):
- libmodis = os.path.join('..', 'libmodis')
-if not libmodis:
- sys.exit("ERROR: modis library not found")
-# try to import pymodis (modis) and some class for r.modis.download
-sys.path.append(libmodis)
-try:
- from rmodislib import product
- from downmodis import downModis
-except ImportError, e:
- grass.fatal(e)
+path = get_lib_path(modname='r.modis', libname='libmodis')
+if path is None:
+ grass.fatal("Not able to find the modis library directory.")
+sys.path.append(path)
+from rmodislib import product
+from downmodis import downModis
def check(home):
""" Check if a folder it is writable by the user that launch the process
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2013-11-13 09:59:08 UTC (rev 58207)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2013-11-13 16:04:04 UTC (rev 58208)
@@ -94,33 +94,19 @@
import shutil
from datetime import date
-libmodis = None
- 'r.modis')):
-if not libmodis:
+if path is None:
# try to import pymodis (modis) and some classes for r.modis.download
-try:
- from rmodislib import resampling, product, projection
- grass.fatal(e)
-try:
- from convertmodis import convertModis, createMosaic
- grass.fatal(e)
-try:
- from parsemodis import parseModis
- grass.fatal(e)
+from rmodislib import resampling, product, projection
+from convertmodis import convertModis, createMosaic
+from parsemodis import parseModis
def list_files(opt, mosaik=False):
