[GRASS-SVN] r58212 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Wed Nov 13 14:47:16 PST 2013
Author: wenzeslaus
Date: 2013-11-13 14:47:16 -0800 (Wed, 13 Nov 2013)
New Revision: 58212
grass/trunk/gui/wxpython/gui_core/forms.py
wxGUI/gui_core: fixing test for task and task frame (module dialog, form)
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-11-13 17:39:43 UTC (rev 58211)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-11-13 22:47:16 UTC (rev 58212)
@@ -2420,16 +2420,31 @@
return True
+USAGE_MESSAGE = """Usage:
+ {name} <grass module>
+ {name} <full path to file>
+ python {name} <grass module>
+Test:
+ python {name} test
+ python {name} g.region
+ python {name} "g.region -p"
+ python {name} temporal/t.list/t.list.py"""
if __name__ == "__main__":
if len(sys.argv) == 1:
- sys.exit(_("usage: %s <grass command>") % sys.argv[0])
+ sys.exit(_(USAGE_MESSAGE).format(name=sys.argv[0]))
if sys.argv[1] != 'test':
- q = wx.LogNull()
+ q = wx.LogNull()
+ from core.debug import Debug
+ Debug.msg(1, "forms.py called using command: %s" % sys.argv[1])
cmd = utils.split(sys.argv[1])
task = gtask.grassTask(gcmd.GetRealCmd(cmd[0]))
task.set_options(cmd[1:])
+ Debug.msg(1, "forms.py opening form for: %s" % task.get_cmd())
app = GrassGUIApp(task)
app.MainLoop()
else: #Test
@@ -2437,12 +2452,15 @@
if os.getenv("GISBASE") is not None:
task = gtask.grassTask("d.vect")
task.get_param('map')['value'] = "map_name"
- task.get_flag('v')['value'] = True
+ task.get_flag('i')['value'] = True
task.get_param('layer')['value'] = 1
task.get_param('bcolor')['value'] = "red"
- assert ' '.join(task.get_cmd()) == "d.vect -v map = map_name layer = 1 bcolor = red"
+ # the default parameter display is added automatically
+ assert ' '.join(task.get_cmd()) == "d.vect -i map=map_name layer=1 display=shape bcolor=red"
+ print "Creation of task successful"
# Test interface building with handmade grassTask,
# possibly outside of a GRASS session.
+ print "Now creating a module dialog (task frame)"
task = gtask.grassTask()
task.name = "TestTask"
task.description = "This is an artificial grassTask() object intended for testing purposes."
@@ -2452,30 +2470,42 @@
"name" : "text",
"description" : "Descriptions go into tooltips if labels are present, like this one",
"label" : "Enter some text",
+ "key_desc": ["value"],
+ "values_desc": []
"name" : "hidden_text",
"description" : "This text should not appear in the form",
- "hidden" : True
+ "hidden" : True,
+ "values_desc": []
"name" : "text_default",
"description" : "Enter text to override the default",
- "default" : "default text"
+ "default" : "default text",
+ "values_desc": []
"name" : "text_prefilled",
"description" : "You should see a friendly welcome message here",
- "value" : "hello, world"
+ "value" : "hello, world",
+ "values_desc": []
"name" : "plain_color",
"description" : "This is a plain color, and it is a compulsory parameter",
"required" : False,
"gisprompt" : True,
- "prompt" : "color"
+ "prompt" : "color",
+ "values_desc": []
"name" : "transparent_color",
"description" : "This color becomes transparent when set to none",
"guisection" : "tab",
"gisprompt" : True,
+ "values_desc": []
"name" : "multi",
"description" : "A multiple selection",
@@ -2485,40 +2515,52 @@
'multiple': u'yes',
'type': u'string',
'value': '',
- 'values': ['red', 'green', u'yellow', u'blue', u'purple', u'other']
+ 'values': ['red', 'green', u'yellow', u'blue', u'purple', u'other'],
+ "values_desc": []
"name" : "single",
"description" : "A single multiple-choice selection",
- "guisection" : "tab"
+ "guisection" : "tab",
+ "values_desc": []
"name" : "large_multi",
"description" : "A large multiple selection",
"gisprompt" : False,
"multiple" : "yes",
# values must be an array of strings
- "values" : utils.str2rgb.keys() + map(str, utils.str2rgb.values())
+ "values" : utils.str2rgb.keys() + map(str, utils.str2rgb.values()),
+ "values_desc": []
"name" : "a_file",
"description" : "A file selector",
"gisprompt" : True,
- "element" : "file"
+ "element" : "file",
+ "values_desc": []
task.flags = [
"name" : "a",
"description" : "Some flag, will appear in Main since it is required",
- "required" : True
+ "required" : True,
+ "value" : False,
+ "suppress_required": False
"name" : "b",
"description" : "pre-filled flag, will appear in options since it is not required",
- "value" : True
+ "value" : True,
"name" : "hidden_flag",
"description" : "hidden flag, should not be changeable",
"hidden" : "yes",
- "value" : True
+ "value" : True,
q = wx.LogNull()
