[GRASS-SVN] r58215 - grass/trunk/vector/v.what.rast
Wed Nov 13 22:52:26 PST 2013
Author: hamish
Date: 2013-11-13 22:52:25 -0800 (Wed, 13 Nov 2013)
New Revision: 58215
   grass/trunk/vector/v.what.rast/local_proto.h
   grass/trunk/vector/v.what.rast/main.c
   grass/trunk/vector/v.what.rast/v.what.rast.html
add flag to interpolate values from the nearest four cells instead of using nearest neighbor
Modified: grass/trunk/vector/v.what.rast/local_proto.h
--- grass/trunk/vector/v.what.rast/local_proto.h	2013-11-14 03:16:22 UTC (rev 58214)
+++ grass/trunk/vector/v.what.rast/local_proto.h	2013-11-14 06:52:25 UTC (rev 58215)
@@ -6,6 +6,7 @@
     int count;			/* nuber of points with category 'cat' */
     int row;
     int col;
+    double x, y;		/* used with interp flag */
     CELL value;
     DCELL dvalue;		/* used for FCELL and DCELL */
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c	2013-11-14 03:16:22 UTC (rev 58214)
+++ grass/trunk/vector/v.what.rast/main.c	2013-11-14 06:52:25 UTC (rev 58215)
@@ -20,12 +20,10 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include <grass/raster.h>
 #include <grass/dbmi.h>
 #include <grass/vector.h>
 #include <grass/glocale.h>
 #include "local_proto.h"
 int main(int argc, char *argv[])
@@ -33,11 +31,11 @@
     int i, j, nlines, type, field, cat;
     int fd;
-    /* struct Categories RCats; *//* TODO */
+    /* struct Categories RCats; */ /* TODO */
     struct Cell_head window;
     RASTER_MAP_TYPE out_type;
-    CELL *cell;
-    DCELL *dcell;
+    CELL *cell_row, *prev_c_row, *next_c_row;
+    DCELL *dcell_row, *prev_d_row, *next_d_row;
     int width;
     int row, col;
     char buf[2000];
@@ -45,7 +43,7 @@
 	struct Option *vect, *rast, *field, *col, *where;
     } opt;
-    struct Flag *print_flag;
+    struct Flag *interp_flag, *print_flag;
     int Cache_size;
     struct order *cache;
     int cur_row;
@@ -96,6 +94,11 @@
     opt.where = G_define_standard_option(G_OPT_DB_WHERE);
+    interp_flag = G_define_flag();
+    interp_flag->key = 'i';
+    interp_flag->description =
+	_("Interpolate values from the nearest four cells");
     print_flag = G_define_flag();
     print_flag->key = 'p';
     print_flag->description =
@@ -209,6 +212,10 @@
 	cache[point_cnt].row = row;
 	cache[point_cnt].col = col;
+	if (interp_flag->answer) {
+	    cache[point_cnt].x = Points->x[0];
+	    cache[point_cnt].y = Points->y[0];
 	cache[point_cnt].cat = cat;
 	cache[point_cnt].count = 1;
 	point_cnt++;
@@ -250,10 +257,23 @@
     /* Allocate space for raster row */
     if (out_type == CELL_TYPE)
-	cell = Rast_allocate_c_buf();
+	cell_row = Rast_allocate_c_buf();
     else
-	dcell = Rast_allocate_d_buf();
+	dcell_row = Rast_allocate_d_buf();
+	if (out_type == CELL_TYPE) {
+	    prev_c_row = Rast_allocate_c_buf();
+	    next_c_row = Rast_allocate_c_buf();
+	else {
+	    prev_d_row = Rast_allocate_d_buf();
+	    next_d_row = Rast_allocate_d_buf();
+	G_begin_distance_calculations();
     /* Extract raster values from file and store in cache */
     G_debug(1, "Extracting raster values");
@@ -264,18 +284,228 @@
 	    continue;		/* duplicate cats */
 	if (cur_row != cache[point].row) {
-	    if (out_type == CELL_TYPE)
-		Rast_get_c_row(fd, cell, cache[point].row);
-	    else
-		Rast_get_d_row(fd, dcell, cache[point].row);
+		Rast_get_c_row(fd, cell_row, cache[point].row);
+		    if (cache[point].row <= 0)
+			Rast_set_null_value(prev_c_row, window.cols,
+					    out_type);
+		    else
+			Rast_get_c_row(fd, prev_c_row, cache[point].row - 1);
+		    if (cache[point].row + 1 > window.rows - 1)
+			Rast_set_null_value(next_c_row, window.cols,
+					    out_type);
+		    else
+			Rast_get_c_row(fd, next_c_row, cache[point].row + 1);
+	    else {
+		Rast_get_d_row(fd, dcell_row, cache[point].row);
+			Rast_set_null_value(prev_d_row, window.cols,
+					    out_type);
+		    else
+			Rast_get_d_row(fd, prev_d_row, cache[point].row - 1);
+			Rast_set_null_value(next_d_row, window.cols,
+					    out_type);
+		    else
+			Rast_get_d_row(fd, next_d_row, cache[point].row + 1);
 	cur_row = cache[point].row;
-	if (out_type == CELL_TYPE) {
-	    cache[point].value = cell[cache[point].col];
+	if (!interp_flag->answer) {
+		cache[point].value = cell_row[cache[point].col];
+	    else
+		cache[point].dvalue = dcell_row[cache[point].col];
 	else {
-	    cache[point].dvalue = dcell[cache[point].col];
+	    /* do four-way IDW */
+	    /* TODO: optimize, parallelize, and function-ize! */
+	    double distance[4], weight[4];
+	    double weightsum, valweight;
+	    int col_offset, row_offset;
+	    weightsum = valweight = 0;
+	    if (cache[point].x <
+		Rast_col_to_easting(cache[point].col,
+				    &window) + window.ew_res / 2)
+		col_offset = -1;
+	    else
+		col_offset = +1;
+	    if (cache[point].y >
+		Rast_row_to_northing(cache[point].row,
+				     &window) - window.ns_res / 2)
+		row_offset = -1;
+	    else
+		row_offset = +1;
+	    distance[0] = G_distance(cache[point].x, cache[point].y,
+							 &window) +
+				     window.ew_res / 2,
+							  &window) -
+				     window.ns_res / 2);
+	    distance[1] = G_distance(cache[point].x, cache[point].y,
+				     Rast_col_to_easting(cache[point].col +
+							 col_offset,
+							 &window) +
+							  &window) -
+	    if (row_offset == -1) {
+		distance[2] = G_distance(cache[point].x, cache[point].y,
+							     col + col_offset,
+							     &window) +
+							      row - 1,
+							      &window) -
+		distance[3] =
+		    G_distance(cache[point].x, cache[point].y,
+						   &window) +
+			       Rast_row_to_northing(cache[point].row - 1,
+						    &window) -
+	    else {
+							     col + col_offset,
+							     &window) +
+							      row + 1,
+							      &window) -
+		distance[3] =
+						   &window) +
+			       Rast_row_to_northing(cache[point].row + 1,
+						    &window) -
+		CELL nearby_c_val[4];
+		/* avoid infinite weights */
+		if (distance[0] < GRASS_EPSILON) {
+		    continue;
+		nearby_c_val[0] = cell_row[cache[point].col];
+		if (cache[point].col + col_offset < 0 ||
+		    cache[point].col + col_offset >= window.cols)	/* UNTESTED */
+		    Rast_set_null_value(&nearby_c_val[1], 1, out_type);	/* UNTESTED */
+		else
+		    nearby_c_val[1] = cell_row[cache[point].col + col_offset];
+			Rast_set_null_value(&nearby_c_val[2], 1, out_type);
+		    else
+			nearby_c_val[2] =
+			    prev_c_row[cache[point].col + col_offset];
+		    nearby_c_val[3] = prev_c_row[cache[point].col];
+		else {
+		    else
+			nearby_c_val[2] =
+			    next_c_row[cache[point].col + col_offset];
+		    nearby_c_val[3] = next_c_row[cache[point].col];
+		for (i = 0; i < 4; i++) {
+		    if (!Rast_is_null_value(&nearby_c_val[i], out_type)) {
+			weight[i] = 1.0 / (distance[i] * distance[i]);
+			weightsum += weight[i];
+			valweight += weight[i] * nearby_c_val[i];
+		cache[point].value = valweight / weightsum;
+	    else {
+		DCELL nearby_d_val[4];
+		    continue;
+		nearby_d_val[0] = dcell_row[cache[point].col];
+		    Rast_set_null_value(&nearby_d_val[1], 1, out_type);
+		else
+		    nearby_d_val[1] =
+			dcell_row[cache[point].col + col_offset];
+			Rast_set_null_value(&nearby_d_val[2], 1, out_type);
+		    else
+			nearby_d_val[2] =
+			    prev_d_row[cache[point].col + col_offset];
+		    nearby_d_val[3] = prev_d_row[cache[point].col];
+		else {
+		    else
+			nearby_d_val[2] =
+			    next_d_row[cache[point].col + col_offset];
+		    nearby_d_val[3] = next_d_row[cache[point].col];
+		    if (!Rast_is_null_value(&nearby_d_val[i], out_type)) {
+			valweight += weight[i] * nearby_d_val[i];
+		cache[point].dvalue = valweight / weightsum;
     }				/* point loop */
     Rast_close(fd);
Modified: grass/trunk/vector/v.what.rast/v.what.rast.html
--- grass/trunk/vector/v.what.rast/v.what.rast.html	2013-11-14 03:16:22 UTC (rev 58214)
+++ grass/trunk/vector/v.what.rast/v.what.rast.html	2013-11-14 06:52:25 UTC (rev 58215)
@@ -3,16 +3,21 @@
 <em>v.what.rast</em> reads the raster value for each point in the vector map
 and updates <b>column</b> in the vector attribute table by this value. The
 column should be type number (integer, float, double, ... ).
-<br>
-If multiple points have the same category, the attribute value is set to NULL.
-If the raster value is NULL, then attribute value is set to NULL.
 <p>
 If the <b>-p</b> flag is used, then the attribute table is not updated
 and the results are printed to <tt>stdout</tt>.
+<p>
+If the <b>-i</b> flag is used, then the value to be uploaded to the database
+is interpolated from the four nearest raster cells values using an inverse
+distance weighting method (IDW). This is useful for cases when the vector
+point density is much higher than the raster cell size.
 <h2>NOTES</h2>
+If multiple points have the same category, the attribute value is set to NULL.
+If the raster value is NULL, then attribute value is set to NULL.
+<p>
 <em>v.what.rast</em> operates on the attribute table. To modify the vector
 geometry instead, use <em>v.drape</em>.
 <p>
@@ -20,23 +25,35 @@
 pipe the output of this module into the UNIX <tt>sort</tt> tool
 (<tt>sort -n</tt>). If you need coordinates, after sorting use
 <em>v.out.ascii</em> and the UNIX <tt>paste</tt> tool
-(<tt>paste -d'|'</tt>).
+(<tt>paste -d'|'</tt>). In the case of a NULL result, a "<tt>*</tt>"
+will be printed in lieu of the value.
+<p>
+The interpolation flag is only useful for continuous value raster maps,
+if a categorical raster is given as input the results will be nonsense.
+Since the search window is limited to four raster cells there may still
+be raster cell-edge artifacts visible in the results, this compromise
+has been made for processing speed. If one or more of the nearest four
+raster cells is NULL, then only the raster cells containing values will
+be used in the weighted average.
 <h2>EXAMPLES</h2>
-A) Reading values from raster map at position of vector points, writing these values
-   into a column of the attribute table connected to the vector map:
+A) Reading values from raster map at position of vector points,
+   writing these values into a column of the attribute table
+   connected to the vector map:
 <br>
 <div class="code"><pre>
 v.what.rast map=pnts raster=elevation column=heights
 </pre></div>
 <p>
 B) In case of a vector map without attached attribute table, first add
-a new attribute table. This table is then populated with values
-queried from the raster map:
+   a new attribute table. This table is then populated with values
+   queried from the raster map:
 <br>
 # create new random vector points map
 v.random pnts n=100
@@ -64,12 +81,14 @@
 <a href="v.drape.html">v.drape</a>,
 <a href="v.univar.html">v.univar</a>,
 <a href="v.rast.stats.html">v.rast.stats</a>,
+v.what.rast.buffer (AddOn module),
 <a href="v.what.vect.html">v.what.vect</a>
 </em>
-<h2>AUTHOR</h2>
-Radim Blazek
+<h2>AUTHORS</h2>
+Radim Blazek<br>
+Hamish Bowman (interpolation)
 <p>
 <i>Last changed: $Date$</i>
