[GRASS-SVN] r58239 - grass/trunk/gui/wxpython/iscatt
svn_grass at osgeo.org
Sat Nov 16 10:46:54 PST 2013
Author: turek
Date: 2013-11-16 10:46:53 -0800 (Sat, 16 Nov 2013)
New Revision: 58239
grass/trunk/gui/wxpython/iscatt/controllers.py
grass/trunk/gui/wxpython/iscatt/dialogs.py
grass/trunk/gui/wxpython/iscatt/iscatt_core.py
wx.iscatt: checks for input data
Modified: grass/trunk/gui/wxpython/iscatt/controllers.py
--- grass/trunk/gui/wxpython/iscatt/controllers.py 2013-11-16 18:12:21 UTC (rev 58238)
+++ grass/trunk/gui/wxpython/iscatt/controllers.py 2013-11-16 18:46:53 UTC (rev 58239)
@@ -30,10 +30,11 @@
import Queue
from core.gconsole import EVT_CMD_DONE
-from core.gcmd import GException, GError, GMessage, RunCommand
+from core.gcmd import GException, GError, GMessage, RunCommand, GWarning
from core.settings import UserSettings
from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
-from iscatt.iscatt_core import Core, idBandsToidScatt
+from iscatt.iscatt_core import Core, idBandsToidScatt, GetRasterInfo, GetRegion, \
+MAX_SCATT_SIZE, WARN_SCATT_SIZE, MAX_NCELLS, WARN_NCELLS
from iscatt.dialogs import AddScattPlotDialog, ExportCategoryRaster
from iclass.dialogs import IClassGroupDialog
@@ -148,8 +149,35 @@
else:
show_add=False
+ self.all_bands_to_bands = dict(zip(bands, [-1] * len(bands)))
+ self.all_bands = bands
+ self.region = GetRegion()
+ ncells = self.region["rows"] * self.region["cols"]
+ if ncells > MAX_NCELLS:
+ del self.busy
+ self.data_set = True
+ return
+ self.bands = bands[:]
+ self.bands_info = {}
+ valid_bands = []
+ for b in self.bands[:]:
+ i = GetRasterInfo(b)
+ self.bands_info[b] = i
+ if i is not None:
+ valid_bands.append(b)
+ for i, b in enumerate(valid_bands):
+ # name : index in core bands -
+ # if not in core bands (not CELL type) -> index = -1
+ self.all_bands_to_bands[b] = i
self.thread.Run(callable=self.core.SetData,
- bands=bands,
+ bands=valid_bands,
ondone=self.SetDataDone,
userdata={"show_add" : show_add})
@@ -157,6 +185,11 @@
del self.busy
+ todo = event.ret
+ self.bad_bands = event.ret
+ bands = self.core.GetBands()
+ self.bad_rasts = event.ret
self.cats_mgr.SetData()
if event.userdata['show_add']:
self.AddScattPlot()
@@ -183,16 +216,42 @@
# added_bands_ids.append[idBandsToidScatt(scatt_id)]
self.digit_conn.Update()
- dlg = AddScattPlotDialog(parent = self.guiparent,
- bands = bands,
- added_scatts_ids = self.plots.keys())
+ GError(_(parent=self.guiparent,
+ mmessage=_("Interactive Scatter Plot Tool can not be used.\n"
+ "Number of cells (rows*cols) <%d> in current region"
+ "is higher than maximum limit <%d>.\n\n"
+ "You can reduce number of cells in current region using <g.region> command."
+ % (ncells, MAX_NCELLS))))
+ return
+ elif ncells > WARN_NCELLS:
+ dlg = wx.MessageDialog(
+ parent=self.guiparent,
+ message=_("Number of cells (rows*cols) <%d> in current region is "
+ "higher than recommended threshold <%d>.\n"
+ "It is strongly advised to reduce number of cells "
+ "in current region bellow recommend threshold.\n "
+ "It can be done by <g.region> command.\n\n"
+ "Do you want to continue using "
+ "Interactive Scatter Plot Tool with this region?"
+ % (ncells, WARN_NCELLS)),
+ style=wx.YES_NO | wx.NO_DEFAULT | wx.ICON_WARNING)
+ ret = dlg.ShowModal()
+ if ret != wx.ID_YES:
+ return
+ dlg = AddScattPlotDialog(parent=self.guiparent,
+ bands=self.all_bands,
+ check_bands_callback=self.CheckBands)
if dlg.ShowModal() == wx.ID_OK:
scatt_ids = []
sel_bands = dlg.GetBands()
for b_1, b_2 in sel_bands:
transpose = False
if b_1 > b_2:
transpose = True
@@ -200,18 +259,76 @@
b_2 = b_1
b_1 = tmp_band
- scatt_id = idBandsToidScatt(b_1, b_2, len(bands))
+ b_1_id = self.all_bands_to_bands[self.all_bands[b_1]]
+ b_2_id = self.all_bands_to_bands[self.all_bands[b_2]]
+ scatt_id = idBandsToidScatt(b_1_id, b_2_id, len(bands))
if self.plots.has_key(scatt_id):
continue
self.plots[scatt_id] = {'transpose' : transpose,
'scatt' : None}
scatt_ids.append(scatt_id)
self._addScattPlot(scatt_ids)
dlg.Destroy()
+ def CheckBands(self, b_1, b_2):
+ added_scatts_ids = self.plots.keys()
+ b_2_id = self.all_bands_to_bands[self.all_bands[b_1]]
+ if scatt_id in added_scatts_ids:
+ GWarning(parent=self.guiparent,
+ message=_("Scatter plot with same band combination (regardless x y order) "
+ "is already displayed."))
+ return False
+ b_1_name = self.all_bands[b_1]
+ b_2_name = self.all_bands[b_2]
+ b_1_i = self.bands_info[b_1_name]
+ b_2_i = self.bands_info[b_2_name]
+ err = ""
+ for b in [b_1_name, b_2_name]:
+ if self.bands_info[b] is None:
+ err += _("Band <%s> is not CELL (integer) type.\n" % self.all_bands[b_1])
+ if err:
+ GMessage(parent=self.guiparent,
+ message=_("Scatter plot cannot be added.\n" + err))
+ return False
+ mrange = b_1_i['range'] * b_2_i['range']
+ if mrange > MAX_SCATT_SIZE:
+ "Multiple of bands ranges <%s:%d * %s:%d = %d> "
+ "is higher than maximum limit <%d>.\n"
+ % (b_1_name, b_1_i['range'], b_1_name, b_2_i['range'],
+ mrange, MAX_SCATT_SIZE)))
+ return False
+ elif mrange > WARN_SCATT_SIZE:
+ dlg = wx.MessageDialog(parent = self.guiparent,
+ message=_("Multiple of bands ranges <%s:%d * %s:%d = %d> "
+ "is higher than recommended limit <%d>.\n"
+ "It is strongly advised to reduce range extend of bands"
+ "(e. g. using r.rescale) bellow recommended threshold.\n\n"
+ "Do you really want to add this scatter plot?"
+ mrange, WARN_SCATT_SIZE)),
+ return False
+ return True
def _addScattPlot(self, scatt_ids):
self.render_mgr.NewRunningProcess()
self.thread.Run(callable=self.core.AddScattPlots,
@@ -283,11 +400,11 @@
sel_cat_id = self.cats_mgr.GetSelectedCat()
if not sel_cat_id:
- message = _("In order to select arrea in scatter plot, "
+ message=_("In order to select arrea in scatter plot, "
"you have to select class first.\n\n"
"There is no class yet, "
"do you want to create one?"),
- caption = _("No class selected"),
+ caption=_("No class selected"),
style = wx.YES_NO)
if dlg.ShowModal() == wx.ID_YES:
self.iclass_conn.EmptyCategories()
@@ -422,8 +539,6 @@
if self.scatt_mgr.pol_sel_mode[0]:
self._getSelectedAreas(cats, i_scatt_id, scatt_dt, cats_attrs)
scatt['scatt'].Plot(cats_order=cats,
scatts=scatt_dt,
ellipses=ellipses_dt,
@@ -513,8 +628,8 @@
return True
def _addCategory(self, cat_id):
- self.scatt_mgr.thread.Run(callable = self.core.AddCategory,
- cat_id = cat_id)
+ self.scatt_mgr.thread.Run(callable=self.core.AddCategory,
+ cat_id=cat_id)
def SetData(self):
@@ -522,8 +637,8 @@
return
for cat_id in self.cats_ids:
- cat_id = cat_id)
+ cat_id=cat_id)
def AddCategory(self, cat_id = None, name = None, color = None, nstd = None):
Modified: grass/trunk/gui/wxpython/iscatt/dialogs.py
--- grass/trunk/gui/wxpython/iscatt/dialogs.py 2013-11-16 18:12:21 UTC (rev 58238)
+++ grass/trunk/gui/wxpython/iscatt/dialogs.py 2013-11-16 18:46:53 UTC (rev 58239)
@@ -34,15 +34,16 @@
class AddScattPlotDialog(wx.Dialog):
- def __init__(self, parent, bands, added_scatts_ids, id = wx.ID_ANY):
+ def __init__(self, parent, bands, check_bands_callback, id = wx.ID_ANY):
wx.Dialog.__init__(self, parent, title = ("Add scatter plots"), id = id)
- self.added_scatts_ids = added_scatts_ids
self.bands = bands
self.x_band = None
self.y_band = None
+ self.chb_callback = check_bands_callback
self.added_bands_ids = []
self.sel_bands_ids = []
self._createWidgets()
@@ -185,19 +186,15 @@
GMessage(parent=self, message=_("Selected bands must be different."))
return
- scatt_id = idBandsToidScatt(b_x, b_y, len(self.bands))
- if scatt_id in self.added_scatts_ids:
- GMessage(parent=self,
- message=_("Scatter plot with same band combination (regardless x y order) "
- "is already displayed."))
- return
if [b_x, b_y] in self.sel_bands_ids or [b_y, b_x] in self.sel_bands_ids:
message=_("Scatter plot with same bands combination (regardless x y order) "
"has been already added into the list."))
return
+ if not self.chb_callback(b_x, b_y):
+ return
self.sel_bands_ids.append([b_x, b_y])
b_x_str = self.band_1_ch.GetStringSelection()
Modified: grass/trunk/gui/wxpython/iscatt/iscatt_core.py
--- grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2013-11-16 18:12:21 UTC (rev 58238)
+++ grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2013-11-16 18:46:53 UTC (rev 58239)
@@ -38,6 +38,11 @@
from core_c import CreateCatRast, ComputeScatts, UpdateCatRast, \
Rasterize, SC_SCATT_DATA, SC_SCATT_CONDITIONS
+MAX_SCATT_SIZE = 4100 * 4100
+WARN_SCATT_SIZE = 2000 * 2000
+MAX_NCELLS = 65536 * 65536
+WARN_NCELLS = 12000 * 12000
class Core:
"""!Represents scatter plot backend.
@@ -53,13 +58,17 @@
def SetData(self, bands):
"""Set bands for analysis.
- self.an_data.Create(bands)
+ ret = self.an_data.Create(bands)
+ if not ret:
+ return False
n_bands = len(self.GetBands())
self.scatts_dt.Create(n_bands)
self.scatt_conds_dt.Create(n_bands)
+ return True
def AddCategory(self, cat_id):
self.scatts_dt.AddCategory(cat_id)
return self.scatt_conds_dt.AddCategory(cat_id)
@@ -371,62 +380,26 @@
return self.region
def Create(self, bands):
- self.bands = bands
self.region = None
- ret, region, msg = RunCommand("g.region",
- flags = "gp",
- getErrorMsg = True,
- read = True)
+ if self.region["rows"] * self.region["cols"] > MAX_NCELLS:
+ GException("too big region")
- if ret != 0:
- raise GException("g.region failed:\n%s" % msg)
- self.bands_info = {}
- #TODO show some warning
- i = self._getRasterInfo(b)
- if not i:
- self.bands.remove(b)
- continue
+ if i is None:
+ GException("raster %s is not CELL type" % (b))
#TODO check size of raster
- self.region = self._parseRegion(region)
+ return True
- def _getRasterInfo(self, rast):
- ret, out, msg = RunCommand("r.info",
- map = rast,
- flags = "rg",
- read = True)
- if ret != 0:
- raise GException("r.info failed:\n%s" % msg)
- out = out.split("\n")
- raster_info = {}
- for b in out:
- if not b.strip():
- continue
- k, v = b.split("=")
- if k == "datatype":
- if v != "CELL":
- return None
- pass
- elif k in ['rows', 'cols', 'cells', 'min', 'max']:
- v = int(v)
- else:
- v = float(v)
- raster_info[k] = v
- raster_info['range'] = raster_info['max'] - raster_info['min'] + 1
- return raster_info
def GetBands(self):
return self.bands
@@ -434,21 +407,6 @@
band = self.bands[band_id]
return self.bands_info[band]
- def _parseRegion(self, region_str):
- region = {}
- region_str = region_str.splitlines()
- for param in region_str:
- k, v = param.split("=")
- if k in ["rows", "cols", "cells"]:
- v = int(v)
- else:
- v = float(v)
- region[k] = v
- return region
class ScattPlotsCondsData:
"""!Data structure for selected areas in scatter plot(condtions).
@@ -836,4 +794,61 @@
scatt_id = (band_1_id * (2 * n_b1 + 1) - band_1_id * band_1_id) / 2 + band_2_id - band_1_id - 1
- return scatt_id
\ No newline at end of file
+ return scatt_id
+def GetRegion():
+ ret, region, msg = RunCommand("g.region",
+ flags = "gp",
+ getErrorMsg = True,
+ read = True)
+ if ret != 0:
+ raise GException("g.region failed:\n%s" % msg)
+ return _parseRegion(region)
+def _parseRegion(region_str):
+ region = {}
+ region_str = region_str.splitlines()
+ for param in region_str:
+ k, v = param.split("=")
+ if k in ["rows", "cols", "cells"]:
+ v = int(v)
+ else:
+ v = float(v)
+ region[k] = v
+ return region
+def GetRasterInfo(rast):
+ ret, out, msg = RunCommand("r.info",
+ map = rast,
+ flags = "rg",
+ read = True)
+ if ret != 0:
+ raise GException("r.info failed:\n%s" % msg)
+ out = out.split("\n")
+ raster_info = {}
+ for b in out:
+ if not b.strip():
+ continue
+ k, v = b.split("=")
+ if k == "datatype":
+ if v != "CELL":
+ return None
+ pass
+ elif k in ['rows', 'cols', 'cells', 'min', 'max']:
+ v = int(v)
+ else:
+ v = float(v)
+ raster_info[k] = v
+ raster_info['range'] = raster_info['max'] - raster_info['min'] + 1
+ return raster_info
