[GRASS-SVN] r58241 - sandbox/turek
Sat Nov 16 11:02:22 PST 2013
Author: turek
Date: 2013-11-16 11:02:22 -0800 (Sat, 16 Nov 2013)
New Revision: 58241
Added:
   sandbox/turek/i.mlpy.py
small experiment with  mlpy in grass
Added: sandbox/turek/i.mlpy.py
--- sandbox/turek/i.mlpy.py	                        (rev 0)
+++ sandbox/turek/i.mlpy.py	2013-11-16 19:02:22 UTC (rev 58241)
@@ -0,0 +1,281 @@
+#!/usr/bin/env python
+MODULE:    i.mlpy
+AUTHOR(S): Stepan Turek <stepan.turek AT seznam.cz>
+PURPOSE: Classifies segmented raster using mlpy library.
+COPYRIGHT: (C) 2012 Stepan Turek, and by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+#%module
+#% description: Classifies segmented raster.
+#% keywords: classification
+#% keywords: imaginery
+#% keywords: segmentation
+#%end
+#%option G_OPT_I_GROUP
+#%end
+#%option G_OPT_R_INPUT
+#% key: seg_raster
+#% description: Segmented raster
+#%end
+#%option G_OPT_V_INPUT
+#% key: training_points
+#%end
+#%option G_OPT_V_FIELD
+#% key: trlayer
+#% guidependency: class_column
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Output classified raster
+#%end
+#% required: no
+#% key: training_segments
+#% description: Output raster with training segments
+#%end
+#%option G_OPT_DB_COLUMN
+#% key: class_column
+#% type: string
+#% required: no
+#%end
+import os
+import sys
+import atexit
+import grass.script as grass
+from grass.pygrass.vector import Vector
+from grass.pygrass import raster
+import numpy as np
+import mlpy
+import string #TODO remove it
+def cleanup():
+   grass.run_command('g.remove', vect = 'i_mlpy_tmp_seg_vect', quiet = True)
+   grass.run_command('g.remove', vect = 'i_mlpy_tmp_vect_tr', quiet = True)
+def prepareTmpVector(seg_raster, temp_vect_seg, raster_maps, col_prefs):
+    """!Create vector map from segmentation raster and
+        compute statistics to it's table for every raster in group."""
+    if grass.run_command('r.to.vect',
+                          quiet = True,
+                          overwrite = True,
+                          input = seg_raster,
+                          output = temp_vect_seg,
+                          column = 'segment_id',
+                          type = 'area') != 0:
+            grass.fatal(_('%s failed') % 'r.to.vect')
+    for m in raster_maps:
+        if grass.run_command('v.rast.stats',
+                             quiet = True,
+                             vector = temp_vect_seg,
+                             raster = m,
+                             flags = 'e',
+                             column_prefix = col_prefs[m]) != 0:
+            grass.fatal(_('%s failed') % 'v.rast.stats')
+def prepareTrainingSegments(seg_raster, temp_vect_seg, tr_pts):
+    """!Get classes from training points into correspondent polygons in segmentation vecor map."""
+    seg_id_col = 'segment_id'
+    tr_pts_map = tr_pts['map']
+    tr_pts_cols = grass.vector_columns(tr_pts_map, 1).keys()
+    if seg_id_col in tr_pts_cols:
+        if grass.run_command('v.db.dropcol',
+                              map = tr_pts_map,
+                              columns = seg_id_col) != 0:
+            grass.fatal(_("Error creating column <%s>") % seg_id_col)
+    if grass.run_command('v.db.addcolumn',
+                          map = tr_pts_map,
+                          columns = ("%s INT" % seg_id_col)) != 0:
+    if grass.run_command('v.what.rast',
+                          quiet = True,
+                          map = tr_pts_map,
+                          raster = seg_raster,
+                          column = seg_id_col) != 0:
+        grass.fatal(_('%s failed') % 'v.what.rast')
+    if grass.run_command('v.db.join',
+                          quiet = True,
+                          map = temp_vect_seg,
+                          otable = tr_pts_map.split('@')[0],
+                          column = seg_id_col,
+                          ocolumn = seg_id_col,
+                          scolumns = tr_pts['class_col']
+                          ) != 0:
+        grass.fatal(_('%s failed') % 'v.db.join')
+def getClassDataCols(col_prefs, used_stats):
+    """!Get columns with data for classification."""
+    class_data_cols = []
+    for m, pref in  col_prefs.iteritems():
+        for stat in used_stats:
+            class_data_cols.append(pref + stat)
+    return class_data_cols
+def classify(temp_vect_seg, class_data_cols, class_col):
+    v_segs = Vector(temp_vect_seg)
+    v_segs.open()
+    link = v_segs.dblinks[1]
+    table = link.table()
+    # get training areas
+    table.filters.select( 'segment_id' + ', ' + class_col + ', ' + \
+                          ', '.join(class_data_cols))\
+                          .where('%s IS NOT NULL' % class_col)\
+                          .order_by('segment_id')
+    cur = table.execute()
+    tr_table = []
+    tr_classes = []
+    classes = [] # contains labels of classes, position in list is their id used in mlpy
+    classify_results = {}
+    tr_segs_classes = {}
+    row = cur.fetchone()
+    while row is not None:
+        if row[1] not in classes:
+            classes.append(row[1])
+        seg_id = row[0]
+        class_id = classes.index(row[1]) + 1
+        tr_segs_classes[seg_id] = class_id
+        tr_classes.append(class_id)
+        tr_table.append(row[2:])
+        classify_results[seg_id] = class_id
+    class_alg = mlpy.LDAC()
+    class_alg.learn(tr_table, tr_classes)
+    table.filters.select( 'segment_id' + ', ' + \
+                          .where('%s IS NULL' % class_col)\
+        pred_class_id = class_alg.pred(row[1:])
+        seg_id = row[0]
+        classify_results[seg_id] = pred_class_id
+    return classify_results, classes, tr_segs_classes
+    #TODO use raster numpy
+    seg = raster.RasterSegment(seg_raster)
+    seg.open()
+    out = raster.RasterSegment(output)
+    out.remove()
+    out.open('w', 'CELL')
+    tr_seg = raster.RasterSegment(tr_segments)
+    tr_seg.remove()
+    tr_seg.open('w', 'CELL')
+    for irow in xrange(seg.rows):
+        for icol in xrange(seg.cols):
+            out[irow, icol] = classify_results[seg[irow][icol]]
+            try:
+                tr_seg[irow, icol] = tr_segs_classes[seg[irow][icol]]
+            except KeyError:
+                pass
+    seg.close()
+    out.close()
+    tr_seg.close()
+    rules = ''
+    for id, cl in enumerate(classes):
+        rules += ('%d:%s\n' % (id + 1, cl))
+    temp_rules = grass.tempfile()
+    try:
+        temp_rules_o = open(temp_rules, 'w')
+        temp_rules_o.write(rules)
+        temp_rules_o.close()
+    except IOError:
+        grass.fatal(_("Unable to write data into tempfile."))
+    if grass.run_command('r.category',
+                         map = output,
+                         rules = temp_rules) != 0:
+        grass.fatal(_('%s failed') % 'r.category')
+def main():
+    output = options['output']
+    seg_raster = options['seg_raster']
+    tr_segments = options['training_segments']
+    group = options['group']
+    s = grass.read_command('i.group', flags='g', group = group, quiet = True)
+    raster_maps = s.splitlines()
+    if not raster_maps:
+        grass.fatal(_('Group <%s> contains no rasters.') % group)
+    col_prefs = {}
+    for i, m in enumerate(raster_maps):
+        col_prefs[m] = ('r%d_' % i)
+    vect_tr_pts = options['training_points']
+    trlayer = options['trlayer']
+    temp_vect_tr_pts = 'i_mlpy_tmp_vect_tr'
+    if grass.run_command('g.copy',
+                         vect = vect_tr_pts + ',' + temp_vect_tr_pts,
+                         overwrite = True) != 0:
+        grass.fatal(_('%s failed') % 'g.copy')
+    class_col = options['class_column']
+    tr_pts = {'map' : temp_vect_tr_pts,
+              'layer' : trlayer,
+              'class_col' : class_col}
+    temp_vect_seg = 'i_mlpy_tmp_seg_vect'
+    prepareTmpVector(seg_raster, temp_vect_seg, raster_maps, col_prefs)
+    prepareTrainingSegments(seg_raster, temp_vect_seg, tr_pts)
+    used_stats = ['_mean', '_variance', '_median', '_third_quartile', '_first_quartile']
+    class_data_cols = getClassDataCols(col_prefs, used_stats)
+    classify(temp_vect_seg, class_data_cols, class_col)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: sandbox/turek/i.mlpy.py
___________________________________________________________________
Added: svn:executable
