[GRASS-SVN] r58263 - grass/trunk/vector/v.surf.bspline
svn_grass at osgeo.org
Thu Nov 21 07:13:46 PST 2013
Author: martinl
Date: 2013-11-21 07:13:46 -0800 (Thu, 21 Nov 2013)
New Revision: 58263
grass/trunk/vector/v.surf.bspline/main.c
v.surf.bspline: remove -z flag, synchronized with v.surf.rst
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c 2013-11-21 08:35:30 UTC (rev 58262)
+++ grass/trunk/vector/v.surf.bspline/main.c 2013-11-21 15:13:46 UTC (rev 58263)
@@ -70,7 +70,7 @@
struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *stepE_opt,
*stepN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt, *mask_opt,
*memory_opt, *solver, *error, *iter;
- struct Flag *cross_corr_flag, *spline_step_flag, *withz_flag;
+ struct Flag *cross_corr_flag, *spline_step_flag;
struct Reg_dimens dims;
struct Cell_head elaboration_reg, original_reg;
@@ -80,6 +80,7 @@
struct line_cats *Cats;
dbCatValArray cvarr;
+ int with_z;
int nrec, ctype = 0;
struct field_info *Fi;
dbDriver *driver, *driver_cats;
@@ -105,11 +106,6 @@
spline_step_flag->description =
_("Estimate point density and distance for the input vector points within the current region extends and quit");
- withz_flag = G_define_flag();
- withz_flag->key = 'z';
- withz_flag->description = _("Use z coordinates for approximation (3D vector maps only)");
- withz_flag->guisection = _("Settings");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
in_opt->label = _("Name of input vector point map");
@@ -173,10 +169,10 @@
lambda_f_opt->guisection = _("Settings");
col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- col_opt->key = "column";
col_opt->required = NO;
- col_opt->description =
- _("Name of attribute column with values to approximate");
+ col_opt->label =
+ _("Name of the attribute column with values to be used for approximation");
+ col_opt->description = _("If not given and input is 3D vector map then z-coordinates are used.");
col_opt->guisection = _("Settings");
solver = N_define_standard_option(N_OPT_SOLVER_SYMM);
@@ -256,20 +252,26 @@
if (1 > Vect_open_old(&In, in_opt->answer, mapset))
G_fatal_error(_("Unable to open vector map <%s> at the topological level"),
in_opt->answer);
- bspline_field = Vect_get_field_number(&In, dfield_opt->answer);
+ bspline_field = 0; /* assume 3D input */
bspline_column = col_opt->answer;
- /* check availability of z values */
- if (withz_flag->answer && !Vect_is_3d(&In)) {
- G_fatal_error(_("Input vector is not 3D, can not use z coordinates"));
+ with_z = !bspline_column && Vect_is_3d(&In);
+ if (Vect_is_3d(&In)) {
+ if (!with_z)
+ G_verbose_message(_("Input is 3D: using attribute values instead of z-coordinates for approximation"));
+ else
+ G_verbose_message(_("Input is 3D: using z-coordinates for approximation"));
- else if (!withz_flag->answer && (bspline_field <= 0 || bspline_column == NULL))
- G_fatal_error(_("Option '%s' with z values or '-%c' flag must be given"),
- col_opt->key, withz_flag->key);
+ else { /* 2D */
+ if (!bspline_column)
+ G_fatal_error(_("Input vector map is 2D. Parameter <%s> required."), col_opt->key);
- if (withz_flag->answer)
- bspline_field = 0;
+ if (!with_z) {
+ bspline_field = Vect_get_field_number(&In, dfield_opt->answer);
/* Estimate point density and mean distance for current region */
if (spline_step_flag->answer) {
@@ -364,6 +366,7 @@
/* read z values from attribute table */
if (bspline_field > 0) {
+ G_message(_("Reading values from attribute table..."));
db_CatValArray_init(&cvarr);
Fi = Vect_get_field(&In, bspline_field);
if (Fi == NULL)
@@ -388,7 +391,7 @@
if (nrec < 0)
G_fatal_error(_("Unable to select data from table"));
- G_message(_("[%d] records selected from table"), nrec);
+ G_verbose_message(_("%d records selected from table"), nrec);
db_close_database_shutdown_driver(driver_cats);
@@ -604,7 +607,7 @@
subregion_col++;
subregion++;
if (nsubregions > 1)
- G_message(_("Subregion %d of %d..."), subregion, nsubregions);
+ G_message(_("Processing subregion %d of %d..."), subregion, nsubregions);
P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
GENERAL_COLUMN);
