[GRASS-SVN] r58272 - grass/trunk/imagery/i.landsat.toar
svn_grass at osgeo.org
Thu Nov 21 14:12:00 PST 2013
Author: neteler
Date: 2013-11-21 14:12:00 -0800 (Thu, 21 Nov 2013)
New Revision: 58272
grass/trunk/imagery/i.landsat.toar/landsat_met.c
i.landsat.toar: fixes for Landsat-8 metadata file support (author: E. Jorge Tizado)
Modified: grass/trunk/imagery/i.landsat.toar/landsat_met.c
--- grass/trunk/imagery/i.landsat.toar/landsat_met.c 2013-11-21 21:32:01 UTC (rev 58271)
+++ grass/trunk/imagery/i.landsat.toar/landsat_met.c 2013-11-21 22:12:00 UTC (rev 58272)
@@ -57,6 +57,7 @@
value[i] = '\0';
+/* future implementation
double get_metdouble(const char metadata[], char *format, int code, char value[])
char key[MAX_STR];
@@ -65,6 +66,7 @@
get_metformat(metadata, key, value);
return atof(value);
/* NEW Metadata Files */
@@ -85,6 +87,7 @@
value[i] = '\0';
double get_mtldouble(const char metadata[], char *format, int code, char value[])
char key[MAX_STR];
@@ -93,9 +96,9 @@
get_mtlformat(metadata, key, value);
return atof(value);
* PURPOSE: Read parameters from Landsat metadata files
@@ -106,9 +109,8 @@
char mtldata[METADATA_SIZE];
char key[MAX_STR], value[MAX_STR];
void (*get_mtldata) (const char[], char *, char[]);
- void (*get_mtlreal) (const char[], char *, int, char[]);
+ /* void (*get_mtlreal) (const char[], char *, int, char[]); */
int i, j, ver_mtl;
- double X2;
/* store metadata in ram */
if ((f = fopen(metafile, "r")) == NULL)
@@ -117,7 +119,8 @@
(void)fclose(f);
/* set version of the metadata file */
- /* get_mtldata = (strstr(mtldata, " VALUE ") != NULL) ? get_metformat : get_mtlformat; */
+ get_mtldata = (strstr(mtldata, " VALUE ") != NULL) ? get_metformat : get_mtlformat;
+ /* future implementation
if (strstr(mtldata, " VALUE ") != NULL)
get_mtldata = get_metformat;
@@ -128,6 +131,7 @@
get_mtldata = get_mtlformat;
get_mtlreal = get_mtldouble;
ver_mtl = (strstr(mtldata, "QCALMAX_BAND") != NULL) ? 0 : 1;
/* Fill with product metadata */
@@ -310,18 +314,20 @@
if (lsat->band[i].thermal) {
sprintf(key, "K1_CONSTANT_BAND_%d", lsat->band[i].code);
get_mtldata(mtldata, key, value);
- lsat->band[i].K1 = atof(value);
+ if (value[0] != '\0')
+ lsat->band[i].K1 = atof(value);
sprintf(key, "K2_CONSTANT_BAND_%d", lsat->band[i].code);
- lsat->band[i].K2 = atof(value);
+ lsat->band[i].K2 = atof(value);
else if (lsat->number == 8)
/* ESUN from REFLECTANCE and RADIANCE ADD_BAND */
sprintf(key, "REFLECTANCE_MAXIMUM_BAND_%d", lsat->band[i].code);
- X2 = atof(value);
- lsat->band[i].esun = (double)(PI * lsat->dist_es * lsat->dist_es * lsat->band[i].lmax) / X2;
+ lsat->band[i].esun = (double)(PI * lsat->dist_es * lsat->dist_es * lsat->band[i].lmax) / atof(value);
