[GRASS-SVN] r58280 - grass/trunk/scripts/r.fillnulls
Fri Nov 22 05:58:44 PST 2013
Author: martinl
Date: 2013-11-22 05:58:44 -0800 (Fri, 22 Nov 2013)
New Revision: 58280
   grass/trunk/scripts/r.fillnulls/r.fillnulls.html
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
r.fillnulls: update manual (new methods)
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.html
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.html	2013-11-22 05:37:02 UTC (rev 58279)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.html	2013-11-22 13:58:44 UTC (rev 58280)
@@ -1,9 +1,12 @@
 <h2>DESCRIPTION</h2>
-<em>r.fillnulls</em> fills NULL pixels (no data areas) in input map and
-stores filled map to a new output map. The fill data are interpolated
-from the no data area boundaries buffer using <em>v.surf.rst</em>  or
-<em>v.surf.bspline</em> spline interpolation.
+<em>r.fillnulls</em> fills NULL pixels (no data areas) in input raster
+map and stores filled data to a new output raster map. The fill areas
+are interpolated from the no data area boundaries buffer
+using <em><a href="v.surf.rst.html">v.surf.rst</a></em> regularized
+spline interpolation with tension (<b>method=rst</b>) or
+<em><a href="r.resamp.bspline.html">r.resamp.bspline</a></em> cubic or
+linear spline interpolation with Tykhonov regularization.
 <h2>NOTES</h2>
@@ -26,29 +29,32 @@
 If interpolation fails, temporary raster and vector maps are left in place to allow
 unfilled map hole (NULL area) identification and manual repair.
-<h2>NOTES</h2>
+<p>
+When using the default RST method, the algorithm is based
+on <em><a href="v.surf.rst.html">v.surf.rst</a></em> regularized
+splines with tension interpolation module which interpolates the
+raster cell values for NULL data areas from the boundary values of the
+NULL data area. An eventual raster MASK is respected during the NULL
+data area(s) filling. The interpolated values are patched into the
+NULL data area(s) of the input map and saved into a new raster map.
-When using the default RST method, the algorithm is based on <em>v.surf.rst</em>
-regularized splines with tension interpolation module which interpolates the
-raster cell values for NULL data areas from the boundary values of the NULL
-data area. An eventual raster MASK is respected during the NULL data area(s)
-filling. The interpolated values are patched into the NULL data area(s) of
-the input map and saved into a new raster map.
+Otherwise, either the linear or cubic spline interpolation with
+Tykhonov regularization can be selected (based on
+<em><a href="r.resamp.bspline.html">r.resamp.bspline</a></em>).
-Otherwise, either the bilinear or bicubic method can be selected (based on
-<em>v.surf.bspline</em>).
 <h2>WARNING</h2>
 Depending on the shape of the NULL data area(s) problems may occur due to an
 insufficient number of input cell values for the interpolation process. Most
 problems will occur if a NULL data area reaches a large amount of the map
 boundary. The user will have to carefully check the result using
-<em>r.mapcalc</em> (generating a difference map to the
-input map and applying the "differences" color table with <em>r.colors</em>)
-and/or <em>d.what.rast</em> to query individual cell values.
+<em><a href="r.mapcalc.html">r.mapcalc</a></em> (generating a
+difference map to the input map and applying the
+"differences" color table
+with <em><a href="r.colors.html">r.colors</a></em>) and/or to query
+individual cell values.
-<h2>WARNING</h2>
+<p>
 RST method stores temporary maps on hard disk. It will require at least as much
 free space as one extra input raster map takes.
@@ -72,40 +78,41 @@
 d.rast elev_srtm_30m_complete
 </pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.fill.dir.html">r.fill.dir</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="v.surf.bspline.html">v.surf.bspline</a>,
-<a href="v.surf.rst.html">v.surf.rst</a>
-</em>
 <h2>REFERENCES</h2>
-<p> Mitas, L., Mitasova, H., 1999, Spatial Interpolation. In: P.Longley,
+<ul>
+<li> Mitas, L., Mitasova, H., 1999, Spatial Interpolation. In: P.Longley,
 M.F. Goodchild, D.J. Maguire, D.W.Rhind (Eds.), Geographical Information
 Systems: Principles, Techniques, Management and Applications, Wiley,
 pp.481-492
-<p>Mitasova H., Mitas L.,  Brown W.M.,  D.P. Gerdes, I.
+<li>Mitasova H., Mitas L.,  Brown W.M.,  D.P. Gerdes, I.
 Kosinovsky, Baker, T.1995, Modeling spatially and temporally distributed
 phenomena: New methods and tools for GRASS GIS. <i>International Journal of
 GIS</i>, 9 (4), special issue on Integrating GIS and Environmental modeling,
 433-446.
-<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps">Mitasova H.
+<li><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps">Mitasova H.
 and Mitas L. 1993</a>: Interpolation by Regularized Spline with Tension: I.
 Theory and Implementation, <i>Mathematical Geology</i> 25, 641-655.
-<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova H.
+<li><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova H.
 and Hofierka L. 1993</a>: Interpolation by Regularized Spline with Tension:
 II. Application to Terrain Modeling and Surface Geometry Analysis,
 <i>Mathematical Geology</i> 25, 657-667.
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.resamp.bspline.html">r.resamp.bspline</a>,
+<a href="v.surf.rst.html">v.surf.rst</a>
+</em>
 <h2>AUTHORS</h2>
-r.fillnulls: Markus Neteler, University of Hannover  and Fondazione Edmund Mach
-<p>and authors of v.surf.rst<br>
+Markus Neteler, University of Hannover  and Fondazione Edmund Mach<br>
 Improvement by Hamish Bowman, NZ
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2013-11-22 05:37:02 UTC (rev 58279)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2013-11-22 13:58:44 UTC (rev 58280)
@@ -34,6 +34,14 @@
 #%option G_OPT_R_OUTPUT
 #%end
 #%option
+#% key: method
+#% type: string
+#% description: Interpolation method
+#% required: yes
+#% options: linear,cubic,rst
+#% answer: rst
+#%end
+#%option
 #% key: tension
 #% type: double
 #% description: Spline tension parameter
@@ -76,14 +84,6 @@
 #% options : 2-10000
 #% guisection: RST options
 #%end
-#%option
-#% key: method
-#% type: string
-#% description: Interpolation method
-#% required : yes
-#% options : linear,cubic,rst
-#% answer : rst
-#%end
 import sys
 import os
