[GRASS-SVN] r58293 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Nov 24 10:47:07 PST 2013
Author: martinl
Date: 2013-11-24 10:47:07 -0800 (Sun, 24 Nov 2013)
New Revision: 58293
grass/trunk/lib/vector/Vlib/local_proto.h
grass/trunk/lib/vector/Vlib/pg_local_proto.h
vlib: fix compilation issue when configures without PostgreSQL support
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h 2013-11-24 18:01:26 UTC (rev 58292)
+++ grass/trunk/lib/vector/Vlib/local_proto.h 2013-11-24 18:47:07 UTC (rev 58293)
@@ -3,6 +3,10 @@
#include <grass/vector.h>
+/*! Cache type (see Format_info_cache) */
+#define CACHE_FEATURE 0
+#define CACHE_MAP 1
/* Internal vector library subroutines which are not part of public
API*/
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h 2013-11-24 18:01:26 UTC (rev 58292)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h 2013-11-24 18:47:07 UTC (rev 58293)
@@ -8,9 +8,6 @@
#define CURSOR_PAGE 500
-#define CACHE_FEATURE 0
-#define CACHE_MAP 1
/*! Topological access */
#define TOPO_SCHEMA "topology"
#define TOPO_ID "topology_id"
