[GRASS-SVN] r58302 - grass/trunk/db/drivers/postgres
svn_grass at osgeo.org
Mon Nov 25 02:48:06 PST 2013
Author: martinl
Date: 2013-11-25 02:48:06 -0800 (Mon, 25 Nov 2013)
New Revision: 58302
grass/trunk/db/drivers/postgres/listtab.c
db-pg: fix db__driver_list_tables() for tables which contain 'pg_' in the name
Modified: grass/trunk/db/drivers/postgres/listtab.c
--- grass/trunk/db/drivers/postgres/listtab.c 2013-11-25 10:30:11 UTC (rev 58301)
+++ grass/trunk/db/drivers/postgres/listtab.c 2013-11-25 10:48:06 UTC (rev 58302)
@@ -21,17 +21,18 @@
vschemacol;
dbString *list;
PGresult *rest, *resv;
- char buf[1000];
+ char buf[DB_SQL_MAX];
*tlist = NULL;
*tcount = 0;
/* Get table names */
- rest =
- PQexec(pg_conn,
- "select * from pg_tables where tablename !~ 'pg_*' order by tablename");
+ sprintf(buf, "SELECT * FROM pg_tables WHERE schemaname %s "
+ " ('pg_catalog', 'information_schema') ORDER BY tablename", system ? "IN" : "NOT IN");
+ G_debug(2, "SQL: %s", buf);
+ rest = PQexec(pg_conn, buf);
if (!rest || PQresultStatus(rest) != PGRES_TUPLES_OK) {
db_d_append_error("%s\n%s",
_("Unable to select table names."),
@@ -54,10 +55,11 @@
/* Get view names */
- resv =
- PQexec(pg_conn,
- "SELECT * FROM pg_views WHERE schemaname NOT IN ('pg_catalog','information_schema') AND viewname !~ '^pg_'");
+ sprintf(buf, "SELECT * FROM pg_views WHERE schemaname %s "
+ " ('pg_catalog', 'information_schema') ORDER BY viewname", system ? "IN" : "NOT IN");
+ resv = PQexec(pg_conn, buf);
if (!resv || PQresultStatus(resv) != PGRES_TUPLES_OK) {
_("Unable to select view names."),
