[GRASS-SVN] r58307 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Mon Nov 25 11:54:18 PST 2013
Author: martinl
Date: 2013-11-25 11:54:18 -0800 (Mon, 25 Nov 2013)
New Revision: 58307
grass/trunk/vector/v.info/print.c
v.info: use Vect_get_finfo_topology_info()
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c 2013-11-25 19:53:58 UTC (rev 58306)
+++ grass/trunk/vector/v.info/print.c 2013-11-25 19:54:18 UTC (rev 58307)
@@ -228,8 +228,10 @@
else if (map_type == GV_FORMAT_POSTGIS) {
+ int topo_format;
+ char *toposchema_name, *topogeom_column;
const struct Format_info *finfo;
finfo = Vect_get_finfo(Map);
fprintf(stdout, "format=%s,%s\n",
@@ -242,11 +244,12 @@
finfo->pg.geom_column);
fprintf(stdout, "feature_type=%s\n",
Vect_get_finfo_geometry_type(Map));
- if (finfo->pg.toposchema_name) {
+ topo_format = Vect_get_finfo_topology_info(Map, &toposchema_name, &topogeom_column, NULL);
+ if (topo_format == GV_TOPO_POSTGIS) {
fprintf(stdout, "pg_topo_schema=%s\n",
- finfo->pg.toposchema_name);
+ toposchema_name);
fprintf(stdout, "pg_topo_column=%s\n",
- finfo->pg.topogeom_column);
+ topogeom_column);
else {
@@ -278,15 +281,13 @@
int i, map_type;
char line[1024];
- char tmp1[1024], tmp2[1024];
char timebuff[256];
struct TimeStamp ts;
int time_ok, first_time_ok, second_time_ok;
struct bound_box box;
- int utm_zone;
+ char tmp1[1024], tmp2[1024];
time_ok = first_time_ok = second_time_ok = FALSE;
- utm_zone = -1;
map_type = Vect_maptype(Map);
/* Check the Timestamp */
@@ -363,6 +364,10 @@
printline(line);
+ int topo_format;
+ int topo_geo_only;
@@ -378,6 +383,7 @@
sprintf(line, "%-17s%s", _("DB name:"),
Vect_get_finfo_dsn_name(Map));
printline(line);
sprintf(line, "%-17s%s", _("Geometry column:"),
printline(line);
@@ -385,14 +391,20 @@
sprintf(line, "%-17s%s", _("Feature type:"),
printline(line);
+ &toposchema_name, &topogeom_column,
+ &topo_geo_only);
sprintf(line, "%-17s%s (%s %s%s)", _("Topology:"), "PostGIS",
- _("schema:"), finfo->pg.toposchema_name,
- finfo->pg.topo_geo_only ? ", topo-geo-only: yes" : "");
+ _("schema:"), toposchema_name,
+ topo_geo_only ? ", topo-geo-only: yes" : "");
printline(line);
sprintf(line, "%-17s%s", _("Topology column:"),
+ topogeom_column);
else
sprintf(line, "%-17s%s", _("Topology:"), "pseudo (simple features)");
@@ -467,6 +479,8 @@
/* this differs from r.info in that proj info IS taken from the map here, not the location settings */
/* Vect_get_proj_name() and _zone() are typically unset?! */
if (G_projection() == PROJECTION_UTM) {
+ int utm_zone;
utm_zone = Vect_get_zone(Map);
if (utm_zone < 0 || utm_zone > 60)
strcpy(tmp1, _("invalid"));
