[GRASS-SVN] r58314 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Nov 26 14:08:19 PST 2013
Author: martinl
Date: 2013-11-26 14:08:19 -0800 (Tue, 26 Nov 2013)
New Revision: 58314
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/pg: do not change constrains to deferrable in topo_geo_only mode
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2013-11-26 20:43:03 UTC (rev 58313)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2013-11-26 22:08:19 UTC (rev 58314)
@@ -862,17 +862,19 @@
/* change constraints to deferrable initially deferred */
- if (-1 == set_constraint_to_deferrable(pg_info, "node", "face_exists",
- "containing_face", "face", "face_id") ||
- -1 == set_constraint_to_deferrable(pg_info, "edge_data", "end_node_exists",
- "end_node", "node", "node_id") ||
- -1 == set_constraint_to_deferrable(pg_info, "edge_data", "left_face_exists",
- "left_face", "face", "face_id") ||
- -1 == set_constraint_to_deferrable(pg_info, "edge_data", "right_face_exists",
- "right_face", "face", "face_id") ||
- -1 == set_constraint_to_deferrable(pg_info, "edge_data", "start_node_exists",
- "start_node", "node", "node_id"))
- return -1;
+ if (!pg_info->topo_geo_only) {
+ if (-1 == set_constraint_to_deferrable(pg_info, "node", "face_exists",
+ "containing_face", "face", "face_id") ||
+ -1 == set_constraint_to_deferrable(pg_info, "edge_data", "end_node_exists",
+ "end_node", "node", "node_id") ||
+ -1 == set_constraint_to_deferrable(pg_info, "edge_data", "left_face_exists",
+ "left_face", "face", "face_id") ||
+ -1 == set_constraint_to_deferrable(pg_info, "edge_data", "right_face_exists",
+ "right_face", "face", "face_id") ||
+ -1 == set_constraint_to_deferrable(pg_info, "edge_data", "start_node_exists",
+ "start_node", "node", "node_id"))
+ return -1;
/* create additional tables in topological schema to store
GRASS topology in DB */
@@ -2748,7 +2750,7 @@
"FOREIGN KEY (%s) REFERENCES \"%s\".%s (%s) "
"DEFERRABLE INITIALLY DEFERRED",
pg_info->toposchema_name, table, constraint, column,
- pg_info->toposchema_name, ref_table);
+ pg_info->toposchema_name, ref_table, ref_column);
if (-1 == Vect__execute_pg(pg_info->conn, stmt)) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
return -1;
