[GRASS-SVN] r58321 - grass/trunk/general/g.parser
svn_grass at osgeo.org
Wed Nov 27 13:00:52 PST 2013
Author: neteler
Date: 2013-11-27 13:00:51 -0800 (Wed, 27 Nov 2013)
New Revision: 58321
Added:
grass/trunk/general/g.parser/g_parser_test.png
grass/trunk/general/g.parser/g.parser.html
g.parser manual: GUI window screenshot added to example
Property changes on: grass/trunk/general/g.parser
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2013-11-27 21:00:30 UTC (rev 58320)
+++ grass/trunk/general/g.parser/g.parser.html 2013-11-27 21:00:51 UTC (rev 58321)
@@ -1,7 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
-<title>GRASS GIS manual: g.parser</title>
+<title>g.parser</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="grassdocs.css" type="text/css">
</head>
@@ -10,32 +10,23 @@
<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
<h2>NAME</h2>
-<em><b>g.parser</b></em> - Provides automated parser, GUI, and help support for GRASS scipts.
+<em><b>g.parser</b></em>
-<h2>KEYWORDS</h2>
-general, support, scripts, GUI
<h2>SYNOPSIS</h2>
-<div id="name"><b>g.parser</b><br></div>
<b>g.parser help</b><br>
-<div id="synopsis"><b>g.parser</b> [-<b>st</b>] <em>filename</em> [<em>argument</em>,...]
-</div>
+<b>g.parser</b> [-<b>s</b>] [-<b>t</b>] <em>filename</em> [<em>argument</em>,...]
-<div id="flags">
<h3>Flags:</h3>
<dl>
<dt><b>-t</b></dt>
<dd>Print strings for translation</dd>
<dt><b>-s</b></dt>
<dd>Write option values to stdout instead of reinvoking script</dd>
</dl>
-</div>
<h2>DESCRIPTION</h2>
-The <em>g.parser</em> module provides full parser support for GRASS GIS
+The <em>g.parser</em> module provides full parser support for GRASS
scripts, including an auto-generated GUI interface, help page
template, and command line option checking. In this way a simple
script can very quickly be made into a full-fledged GRASS module.
@@ -52,9 +43,11 @@
and the value of flag with key <b>f</b> will be available in variable
<b>GIS_FLAG_F</b>.
-<p>For flags, the value will be "1" if the flag was given, and "0" otherwise.
+<p>
+For flags, the value will be "1" if the flag was given, and "0" otherwise.
-<p>If the <b>-s</b> switch is used, the options and flags are written to
+<p>
+If the <b>-s</b> switch is used, the options and flags are written to
stdout in the form <em>opt_<name>=<value></em> and
<em>flag_<name>=<value></em>, preceded by the string
<b>@ARGS_PARSED@</b>. If this string doesn't appear as the first line
@@ -63,7 +56,8 @@
<em>g.parser</em> to stdout should be copied to the script's stdout
verbatim.
-<p>Typical header definitions are as follows:
+<p>
+Typical header definitions are as follows:
<div class="code"><pre>
#%module
@@ -101,20 +95,23 @@
done
</pre></div>
-<p>A "<tt>guisection</tt>" field may be added to each option and flag to specify
+<p>
+A "<tt>guisection</tt>" field may be added to each option and flag to specify
that the options should appear in multiple tabs in the auto-generated GUI.
Any options without a <tt>guisection</tt> field go into the "Options" tab.
For example:
<pre>#% guisection: tabname</pre>
would put that option in a tab named <i>tabname</i>.
-<p>A "<tt>key_desc</tt>" field may be added to each option to specify the text that
+<p>
+A "<tt>key_desc</tt>" field may be added to each option to specify the text that
appears in the module's usage help section. For example:
<pre>#% key_desc: filename</pre>
added to an <b>input</b> option would create the usage summary
<tt>[input=filename]</tt>.
-<p>If a script is run with --o, G_parser() will
+<p>
+If a script is run with --o, G_parser() will
set <tt>GRASS_OVERWRITE=1</tt>, which has the same effect as passing
--o to every module which is run from the script. Similarly, passing
--q or --v will set <tt>GRASS_VERBOSE</tt> to 0 or 3 respectively,
@@ -125,10 +122,6 @@
script should behave the same way regardless of whether they were set
by --o, --q or --v being passed to the script or set by other means.
-<p>In case that a GRASS module or script does not have any required
-options, executing the command without parameters will not open the
-respective parameter GUI dialog. The user can force a parameter dialog
-to be displayed using the --ui switch.
<h2>AUTOMATED SCRIPT CREATION</h2>
@@ -197,6 +190,12 @@
<h2>EXAMPLES</h2>
+All examples below autogenerate the graphical user interface when invoked
+without parameters of flags:
+<p>
+<img src="g_parser_test.png" alt="Autogenerated GUI window">
<h3>Example code for SHELL</h3>
@@ -260,7 +259,32 @@
</pre></div>
+To run properly, the script needs to be copied into $GISBASE/scripts/
+with the executable flag being set. The script will provide a GUI
+(as above) and the following usage help text:
+<div class="code"><pre>
+test.sh --help
+Description:
+ g.parser test script (python)
+Usage:
+ test.sh [-f] raster=string vector=string [option1=string]
+ [--verbose] [--quiet]
+Flags:
+ -f A flag
+ --v Verbose module output
+ --q Quiet module output
+Parameters:
+ raster Raster input map
+ vector Vector input map
+ option1 An option
+</pre></div>
<h3>Example code for Python</h3>
@@ -329,7 +353,8 @@
main()
</pre></div>
-The <tt>test.py</tt> script will provide following help text:
+The <tt>test.py</tt> script will provide a GUI (as above) and the
+following usage help text:
./test.py --help
@@ -429,22 +454,21 @@
<h2>SEE ALSO</h2>
<em>
-<a href="g.filename.html">g.filename</a>,
-<a href="g.findfile.html">g.findfile</a>,
-<a href="g.tempfile.html">g.tempfile</a>,
+ <a href="g.filename.html">g.filename</a>,
+ <a href="g.findfile.html">g.findfile</a>,
+ <a href="g.tempfile.html">g.tempfile</a>
</em>
and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
-<p>Related Wiki pages:
+<p>
+Related Wiki pages:
<a href="http://grasswiki.osgeo.org/wiki/Category:Linking_to_other_languages">Using GRASS with other programming languages</a>
<h2>AUTHOR</h2>
Glynn Clements
-<p><i>Last changed: $Date$</i>
-<hr>
-<p><a href="index.html">Main index</a> - <a href="general.html">General index</a> - <a href="topics.html">Topics index</a> - <a href="keywords.html">Keywords Index</a> - <a href="full_index.html">Full index</a></p>
-<p>© 2003-2013 <a href="http://grass.osgeo.org">GRASS Development Team</a>, GRASS GIS 7.0.svn Reference Manual</p>
+<p>
+<i>Last changed: $Date$</i>
</body>
</html>
Added: grass/trunk/general/g.parser/g_parser_test.png
(Binary files differ)
Property changes on: grass/trunk/general/g.parser/g_parser_test.png
Added: svn:mime-type
+ image/png
