[GRASS-SVN] r58335 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Fri Nov 29 11:53:30 PST 2013
Author: martinl
Date: 2013-11-29 11:53:29 -0800 (Fri, 29 Nov 2013)
New Revision: 58335
grass/trunk/lib/python/script/vector.py
pythonlib: fix vector_what() for case when one of the attributes is 'Layer'
TODO: it would be nice if v.what would produce parsable format (eg. XML)
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py 2013-11-29 17:29:49 UTC (rev 58334)
+++ grass/trunk/lib/python/script/vector.py 2013-11-29 19:53:29 UTC (rev 58335)
@@ -366,6 +366,8 @@
if not ret:
return data
+ # parse `v.what -g` output is a nightmare
+ # TODO: change `v.what -g` format or add parsable format (e.g. XML)
dict_attrb = None
dict_map = None
dict_layer = None
@@ -389,13 +391,16 @@
dict_layer = None
dict_attrb = None
elif key == 'Layer':
- # attach the last the previous Layer
- if dict_layer is not None:
- dict_main = copy.copy(dict_map)
- dict_main.update(dict_layer)
- data.append(dict_main)
- dict_layer = { key: int(value) }
- dict_attrb = None
+ if not dict_attrb:
+ # attach the last the previous Layer
+ if dict_layer is not None:
+ dict_main = copy.copy(dict_map)
+ dict_main.update(dict_layer)
+ data.append(dict_main)
+ dict_layer = { key: int(value) }
+ dict_attrb = None
+ else:
+ dict_attrb[key] = value
elif key == 'Key_column':
dict_layer[key] = value
dict_attrb = dict()
