[GRASS-SVN] r58339 - in grass/trunk: general/g.parser lib/python/script
svn_grass at osgeo.org
Sat Nov 30 05:41:58 PST 2013
Author: glynn
Date: 2013-11-30 05:41:58 -0800 (Sat, 30 Nov 2013)
New Revision: 58339
grass/trunk/general/g.parser/g.parser.html
grass/trunk/general/g.parser/main.c
grass/trunk/general/g.parser/parse.c
grass/trunk/general/g.parser/proto.h
grass/trunk/lib/python/script/core.py
Deal with newlines in option values (issue #2139)
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2013-11-30 12:11:46 UTC (rev 58338)
+++ grass/trunk/general/g.parser/g.parser.html 2013-11-30 13:41:58 UTC (rev 58339)
@@ -22,6 +22,8 @@
<dd>Print strings for translation</dd>
<dt><b>-s</b></dt>
<dd>Write option values to stdout instead of reinvoking script</dd>
+<dt><b>-n</b></dt>
+<dd>Write option values to stdout separated by nulls</dd>
</dl>
<h2>DESCRIPTION</h2>
@@ -34,7 +36,7 @@
<h2>OPTIONS</h2>
-Unless the <b>-s</b> switch is used, the arguments are stored in
+Unless the <b>-s</b> or <b>-n</b> switch is used, the arguments are stored in
environment variables for use in your scripts. These variables are
named "GIS_FLAG_<NAME>" for flags and "GIS_OPT_<NAME>" for
options. The names of variables are converted to upper case. For
@@ -47,7 +49,7 @@
For flags, the value will be "1" if the flag was given, and "0" otherwise.
<p>
-If the <b>-s</b> switch is used, the options and flags are written to
+If the <b>-s</b> or <b>-n</b> switch is used, the options and flags are written to
stdout in the form <em>opt_<name>=<value></em> and
<em>flag_<name>=<value></em>, preceded by the string
<b>@ARGS_PARSED@</b>. If this string doesn't appear as the first line
@@ -56,6 +58,10 @@
<em>g.parser</em> to stdout should be copied to the script's stdout
verbatim.
+If the <b>-s</b> switch is used, the options and flags are separated
+by newlines. If the <b>-n</b> switch is used, the options and flags
+are separated by null characters.
<p>
Typical header definitions are as follows:
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2013-11-30 12:11:46 UTC (rev 58338)
+++ grass/trunk/general/g.parser/main.c 2013-11-30 13:41:58 UTC (rev 58339)
@@ -32,6 +32,7 @@
struct context ctx;
const char *filename;
int standard_output;
+ int separator_nul;
ctx.module = NULL;
ctx.option = NULL;
@@ -40,8 +41,8 @@
ctx.first_flag = NULL;
ctx.state = S_TOPLEVEL;
- standard_output = translate_output = FALSE;
+ standard_output = translate_output = separator_nul = FALSE;
/* Detect request to get strings to translate from a file */
/* It comes BEFORE the filename to completely avoid confusion with parser.c behaviours */
if (argc >= 2 && (strcmp(argv[1], "-t") == 0)) {
@@ -56,6 +57,13 @@
argv++, argc--;
+ if (argc >= 2 && (strcmp(argv[1], "-n") == 0)) {
+ /* write to stdout with NUL as separator */
+ standard_output = TRUE;
+ separator_nul = TRUE;
+ argv++, argc--;
if ((argc < 2) || ((strcmp(argv[1], "help") == 0) ||
(strcmp(argv[1], "-help") == 0) ||
(strcmp(argv[1], "--help") == 0))) {
@@ -135,6 +143,6 @@
exit(EXIT_FAILURE);
return standard_output
- ? print_options(&ctx)
+ ? print_options(&ctx, separator_nul ? '\0' : '\n')
: reinvoke_script(&ctx, filename);
Modified: grass/trunk/general/g.parser/parse.c
--- grass/trunk/general/g.parser/parse.c 2013-11-30 12:11:46 UTC (rev 58338)
+++ grass/trunk/general/g.parser/parse.c 2013-11-30 13:41:58 UTC (rev 58339)
@@ -228,27 +228,29 @@
cmd, ctx->line);
-int print_options(const struct context *ctx)
+int print_options(const struct context *ctx, int sep)
struct Option *option;
struct Flag *flag;
const char *overwrite = getenv("GRASS_OVERWRITE");
const char *verbose = getenv("GRASS_VERBOSE");
- printf("@ARGS_PARSED@\n");
+ printf("@ARGS_PARSED@%c", sep);
if (overwrite)
- printf("GRASS_OVERWRITE=%s\n", overwrite);
+ printf("GRASS_OVERWRITE=%s%c", overwrite, sep);
if (verbose)
- printf("GRASS_VERBOSE=%s\n", verbose);
+ printf("GRASS_VERBOSE=%s%c", verbose, sep);
for (flag = ctx->first_flag; flag; flag = flag->next_flag)
- printf("flag_%c=%d\n", flag->key, flag->answer ? 1 : 0);
+ printf("flag_%c=%d%c", flag->key, flag->answer ? 1 : 0, sep);
for (option = ctx->first_option; option; option = option->next_opt)
- printf("opt_%s=%s\n", option->key,
- option->answer ? option->answer : "");
+ printf("opt_%s=%s%c", option->key,
+ option->answer ? option->answer : "", sep);
+ fflush(stdout);
return EXIT_SUCCESS;
Modified: grass/trunk/general/g.parser/proto.h
--- grass/trunk/general/g.parser/proto.h 2013-11-30 12:11:46 UTC (rev 58338)
+++ grass/trunk/general/g.parser/proto.h 2013-11-30 13:41:58 UTC (rev 58339)
@@ -7,7 +7,7 @@
void parse_flag(struct context *, const char *, const char *);
int parse_type(struct context *, const char *);
void parse_option(struct context *, const char *, const char *);
-int print_options(const struct context *);
+int print_options(const struct context *, int);
/* revoke.c */
int reinvoke_script(const struct context *, const char *);
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2013-11-30 12:11:46 UTC (rev 58338)
+++ grass/trunk/lib/python/script/core.py 2013-11-30 13:41:58 UTC (rev 58339)
@@ -595,7 +595,6 @@
options = {}
flags = {}
for line in lines:
- line = line.rstrip('\r\n')
if not line:
break
try:
@@ -645,11 +644,11 @@
else:
argv[0] = os.path.join(sys.path[0], name)
- p = Popen(['g.parser', '-s'] + argv, stdout=PIPE)
+ p = Popen(['g.parser', '-n'] + argv, stdout=PIPE)
s = p.communicate()[0]
- lines = s.splitlines()
+ lines = s.split('\0')
- if not lines or lines[0].rstrip('\r\n') != "@ARGS_PARSED@":
+ if not lines or lines[0] != "@ARGS_PARSED@":
sys.stdout.write(s)
sys.exit(p.returncode)
