[GRASS-SVN] r57902 - grass-addons/grass7/raster/r.popgrowth
Tue Oct 1 02:23:56 PDT 2013
Author: jradinger
Date: 2013-10-01 02:23:55 -0700 (Tue, 01 Oct 2013)
New Revision: 57902
Added:
   grass-addons/grass7/raster/r.popgrowth/Makefile
   grass-addons/grass7/raster/r.popgrowth/r.popgrowth.html
   grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
New raster add-on: Set of time discrete population models in fisheries science (Exponential model, Ricker model)
Added: grass-addons/grass7/raster/r.popgrowth/Makefile
--- grass-addons/grass7/raster/r.popgrowth/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.popgrowth/Makefile	2013-10-01 09:23:55 UTC (rev 57902)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.popgrowth
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.popgrowth/r.popgrowth.html
--- grass-addons/grass7/raster/r.popgrowth/r.popgrowth.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.popgrowth/r.popgrowth.html	2013-10-01 09:23:55 UTC (rev 57902)
@@ -0,0 +1,24 @@
+<h2>DESCRIPTION</h2>
+<em>r.popgrow</em> calculates classical models of population growths. The module creates
+a new raster map of population size (abundance) after a specified number of time steps based
+on an intial populations size (input raster).
+<p>
+Available models for populations growth: Exponential growth and the Ricker model.
+<h2>EXAMPLES</h2>
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Johannes Radinger<br>
+<i>Leibniz-Institute of Freshwater Ecology and Inland Fisheries (IGB)<br>
+Berlin, Germany</i>
+<br>
+<p>
+<i>Last changed: $Date: 2013-09-30 10:38:44 +0200 (Mon, 30 Sep 2013)  $</i>
Added: grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
--- grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py	2013-10-01 09:23:55 UTC (rev 57902)
@@ -0,0 +1,249 @@
+#!/usr/bin/env python
+# MODULE:		Set of time discrete population models in fisheries science
+# AUTHOR(S):		Johannes Radinger
+# VERSION:
+# DATE:			2013-08-28
+#%Module
+#% description: Set of population models (fisheries science)
+#% keywords: Population growth model
+#%End
+#%option
+#% key: n_initial
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Map with number of individuals per cell at time t0 (initial population size)
+#% required: yes
+#%end
+#%option
+#% key: timesteps
+#% type: integer
+#% description: Number of time steps
+#% required: yes
+#% answer: 1
+#%end
+#%Option
+#% key: exponential_output
+#% type: string
+#% gisprompt: new,cell,raster
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name for exponential model output map
+#% guisection: Exponential
+#%end
+#%option
+#% key: r_exp_fix
+#% type: double
+#% description: Fixed value of intrinsic rate of increase, log(finite rate of increase, lambda)
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: r_exp_map
+#% type: string
+#% description: Map with intrinsic rate of increase, log(finite rate of increase, lambda)
+#% required: no
+#% multiple: no
+#%end
+#%Option
+#% key: ricker_output
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name for Ricker model output map
+#% guisection: Ricker
+#%end
+#%option
+#% key: k_fix
+#% type: integer
+#% description: Fixed value of carrying capacity of the environment
+#% required: no
+#%end
+#%option
+#% key: k_map
+#% type: string
+#% description: Map with carrying capacity of the environment
+#% required: no
+#%end
+#%option
+#% key: r_rick_fix
+#% type: double
+#% description: Fixed value of intrinsic rate of increase (Ricker)
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: r_rick_map
+#% description: Map with intrinsic rate of increase (Ricker)
+#% required: no
+#% multiple: no
+#%end
+#%Option
+#% key: seed
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: fixed seed for random rounding
+#% guisection: Optional
+#%End
+#%Flag
+#% key: i
+#% description: Calculate models with rounded integer values
+#%end
+# import required base modules
+import sys
+import os
+import atexit
+import math #for function sqrt()
+# import required grass modules
+import grass.script as grass
+import grass.script.array as garray
+# import required numpy/scipy modules
+import numpy
+def cleanup():
+	grass.message(_("This is the cleanup part"))
+def main():
+	############ DEFINITION CLEANUP TEMPORARY FILES ##############
+	#global variables for cleanup
+	global tmp_map_rast
+	global tmp_map_vect
+	tmp_map_rast = []
+	tmp_map_vect = []
+	############ PARAMETER INPUT ##############
+	# Check for correct input
+	if (str(options['exponential_output']) == '' and str(options['ricker_output']) == ''):
+		grass.fatal(_("Output name for a model is missing"))
+	#Model parameters input
+	t = int(options['timesteps'])
+	# Customized rounding function. Round based on a probability (p=digits after decimal point) to avoid "local stable states"
+	def prob_round(x, prec = 0):
+    		fixup = numpy.sign(x) * 10**prec
+    		x *= fixup
+		if options['seed']:
+			numpy.random.seed(seed=int(options['seed']))
+    		round_func = int(x) + numpy.random.binomial(1,x-int(x))
+    		return round_func/fixup
+	vprob_round = numpy.vectorize(prob_round)
+	################# Model Definiations #################
+	# Model definitions modified from R scripts (http://www.mbr-pwrc.usgs.gov/workshops/unmarked/Rscripts/script-state-space.R)
+	# Exponential Model
+	def exponential_mod(n0,r,t):
+		n = n0
+		for t in range(t):
+			n = 1.0*n*numpy.exp(r)
+			if flags['i']:
+				n = vprob_round(n)
+		return 	n
+	# Ricker Model
+	def ricker_mod(n0,r,k,t):
+		n = n0
+			n = 1.0*n*numpy.exp(r*(1-(n/k)))
+			if flags['i']:
+		return 	n
+	vricker_mod = numpy.vectorize(ricker_mod)
+	################# Exponential Model #################
+	if options['exponential_output']:
+		if (options['r_exp_fix'] and options['r_exp_map']):
+			grass.fatal(_("Provide either fixed value for r or raster map"))
+		# Define r
+		if options['r_exp_map']:
+			grass.message(_("r_exp_map provided"))
+			r = garray.array()
+			r.read(options['r_exp_map'])
+		elif options['r_exp_fix']:
+			r = float(options['r_exp_fix'])
+		else:
+			grass.fatal(_("No r value/map provided for exponential model"))
+		n0_map = garray.array()
+		n0_map.read(options['n_initial'])
+		exponential_map = garray.array()
+		exponential_map[...] = exponential_mod(n0_map,r,t)
+		exponential_map.write(options['exponential_output'])
+	################# Ricker Model #################
+	if options['ricker_output']:
+		if (options['r_rick_fix'] and options['r_rick_map']):
+		if (options['k_fix'] and options['k_map']):
+			grass.fatal(_("Provide either fixed value for carrying capacity (K) or raster map"))
+		# Define r
+		if options['r_rick_map']:
+			r.read(options['r_rick_map'])
+		elif options['r_rick_fix']:
+			r = float(options['r_rick_fix'])
+		else:
+			grass.fatal(_("No r value/map for Ricker model provided"))
+		# Define k
+		if options['k_map']:
+			k = garray.array()
+			k.read(options['k_map'])
+		elif options['k_fix']:
+			k = float(options['k_fix'])
+		else:
+			grass.fatal(_("No value/map for carrying capacity (k) provided"))
+		ricker_map = garray.array()
+		ricker_map[...] = ricker_mod(n0_map,r,k,t)
+		ricker_map.write(options['ricker_output'])
+	return 0
+if __name__ == "__main__":
+	options, flags = grass.parser()
+	atexit.register(cleanup)
+	sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
___________________________________________________________________
Added: svn:executable
